LCD connected on GPIO and another GPIO / Analog port use corrupts displayed text
LCD HD44780
Best Answer ross-cz, 06 March 2013 - 09:39 AM
I figured out issue myself:
- calling to AnalogInput input = new AnalogInput(AnalogChannels.ANALOG_PIN_A1) corrupted digital signal
- using this SecretLabs.NETMF.Hardware.AnalogInput input = new SecretLabs.NETMF.Hardware.AnalogInput(Pins.GPIO_PIN_A1) works without problem
There should be some table to disambiguate the use of these simple things for each framework version. I already have problems and waste a lot of my time with incorrectly use Cpu.Pin vs Pins. Problems like simple line of code (using Cpu.Pin.GPIO_Pin11/12) locked whole netduino program and I had to reflash it.
1 reply to this topic
#1 ross-cz
ross-cz
Posted 05 March 2013 - 07:56 AM
I have strange problem. I use LCD connected using GPIO ports like in this article: http://10rem.net/blo...th-the-netduino It works without any problem. Than I add use of Analog or GPIO port and display changes to black bars / boxes.
Can you direct me? What is the cause of signal desync on those ports?
My HW:
  • Netduino Plus 2 Firmware v4.2.2 (update 2)
  • cheap LCD (http://www.hwkitchen...x20-characters/) with set contrast using 330 Ohm resistor to GND, without powering to backlight and without pull-up resistors
Thanks for help.
#2 ross-cz
ross-cz
Posted 06 March 2013 - 09:39 AM   Best Answer
Also tagged with one or more of these keywords: LCD, HD44780
