Disappointed - Netduino Go - Netduino Forums
Disappointed
Best Answer fxpa, 24 February 2013 - 07:16 PM
Hi
Tks For your rapid answer.
I'm just trying to create a first project.
I've reset everyhting
Update NGo and the shield (but I dont need it for the moment )
I've just the netduigo connected on usb The button and the RGB led
I've found a code in VB it seems to work now :-)
#1 fxpa
fxpa
  • 3 posts
  • LocationBordeaux FR
Posted 24 February 2013 - 09:41 AM
Hi All
I've decide to invest in a ArduinoGo Kit to start my first project.
The choice between Netduino and ARduino was hard to do be .Net is friendly for me so it has helped me to make my choice.
I've receive My and I've try to send My first project copied from this forum " Blinking led"
Nothing Works..
I've upgrade it 4.2.2.2, downgrade it but
HalSystemInfo.halVersion:               4.2.0.0
HalSystemInfo.halVendorInfo:            Netduino Go (v4.2.0.2) by Secret Labs LLC
HalSystemInfo.oemCode:                  34
HalSystemInfo.modelCode:                177
HalSystemInfo.skuCode:                  4099
HalSystemInfo.moduleSerialNumber:       00000000000000000000000000000000
HalSystemInfo.systemSerialNumber:       0000000000000000
ClrInfo.clrVersion:                     4.2.0.0
ClrInfo.clrVendorInfo:                  Netduino Go (v4.2.0.2) by Secret Labs LLC
ClrInfo.targetFrameworkVersion:         4.2.0.0
SolutionReleaseInfo.solutionVersion:    4.2.0.2
SolutionReleaseInfo.solutionVendorInfo: Netduino Go (v4.2.0.2) by Secret Labs LLC
SoftwareVersion.BuildDate:              Oct  9 2012
SoftwareVersion.CompilerVersion:        410894
FloatingPoint:                          True
SourceLevelDebugging:                   True
ThreadCreateEx:                         True
LCD.Width:                              0
LCD.Height:                             0
LCD.BitsPerPixel:                       0
AppDomains:                             True
ExceptionFilters:                       True
IncrementalDeployment:                  True
SoftReboot:                             True
Profiling:                              False
ProfilingAllocations:                   False
ProfilingCalls:                         False
IsUnknown:                              False
[font="arial, helvetica, sans-serif;"]When I was on 4.2.2 the module was turning on the blue led when the button was push but nothing else[/font]
[font="arial, helvetica, sans-serif;font-size:8.5px;"]I've Tried VB.NET C#, VS EXPRESS, VS 2010 ultimate, when a star the project, the module reboot but nothing [/font]after...
I've also tried other computer. Now i'm working on a macbook with //desktop but i've also tested on a xp machine.
I've install all SDK/KIT etc...
Everything seems to be ok and I dont know what to try more...
This is the last project I'm trying tu upload :
[color=#0433ff;]using[/color] System;
[color=#0433ff;]using[/color] System.Threading;
[color=#0433ff;]using[/color] Microsoft.SPOT;
[color=#0433ff;]using[/color] Microsoft.SPOT.Hardware;
[color=#0433ff;]using[/color] SecretLabs.NETMF.Hardware;
[color=#0433ff;]using[/color] SecretLabs.NETMF.Hardware.NetduinoGo;
[color=#0433ff;]namespace[/color] ButtonApp
[color=#000000;]    [/color]public[color=#000000;] [/color]class[color=#000000;] [/color][color=#33a2bd;]Program[/color]
        [color=#0433ff;]public[/color] [color=#0433ff;]static[/color] [color=#0433ff;]void[/color] Main()
[color=#000000;]            [/color]// write your code here
            [color=#33a2bd;]OutputPort[/color] led = [color=#0433ff;]new[/color] [color=#33a2bd;]OutputPort[/color]([color=#33a2bd;]Pins[/color].ONBOARD_LED, [color=#0433ff;]false[/color]);
            [color=#33a2bd;]InputPort[/color] button = [color=#0433ff;]new[/color] [color=#33a2bd;]InputPort[/color]([color=#33a2bd;]Pins[/color].ONBOARD_SW1, [color=#0433ff;]false[/color], [color=#33a2bd;]Port[/color].[color=#33a2bd;]ResistorMode[/color].Disabled);
            [color=#0433ff;]bool[/color] buttonState = [color=#0433ff;]false[/color];
            [color=#0433ff;]while[/color] ([color=#0433ff;]true[/color])
                buttonState = button.Read();
                led.Write(!buttonState);
Debug windows on build :
Found debugger!
Create TS.
Loading start at 8056cf0, end 806e864
Assembly: mscorlib (4.2.0.0)
Assembly: System.IO (4.2.0.0)
Assembly: SecretLabs.NETMF.IO (4.2.0.0)
Attaching deployed file.
Assembly: NetduinoGo.RgbLed (1.0.2.0)
Assembly: SecretLabs.NETMF.Hardware.Netduino (4.2.1.0)
Assembly: SecretLabs.NETMF.Hardware.NetduinoGo (4.2.2.0)
Assembly: ButtonApp (1.0.0.0)
Assembly: SecretLabs.NETMF.Hardware (4.2.0.0)
Assembly: GoBus (1.0.0.0)
Resolving.
Ready.
Target Framework is micro 4.2
Référence are ok
I'm lost...
Netduino Beginner...
Posted 24 February 2013 - 01:00 PM
Hi fxpa, Welcome to the Netduino community. There's a lot of information in that post, but I'm a little bit lost as to what you tried. It sounds like you've run through a number of scenarios. So first, let's get you upgraded to the latest Netduino Go firmware. There's no reason, really, to be on the old firmware. Second of all...if you're going to use Pins.ONBOARD_LED, you'll want to change the "SecretLabs.Hardware.NetduinoGo.dll" out for "SecretLabs.NETMF.Hardware.Netduino.dll" instead. Also make sure that you upgrade your Shield Base to the latest firmware. Then when you press the pushbutton, the LED on the Shield Base's GoPort should turn on. Release the pushbutton and it should turn off. Because you're using the beta Shield Base auto-detect feature...it'll take a few seconds to connect when the board reboots. Does that help you get off in the right direction? We're here to help; we just need to know what you're seeing and doing. Chris
#3 fxpa
fxpa
  • 3 posts
Posted 24 February 2013 - 07:16 PM   Best Answer
Hi
#4 desowen
desowen
Posted 25 September 2013 - 06:51 PM
Hi fxpa,Welcome to the Netduino community.There's a lot of information in that post, but I'm a little bit lost as to what you tried. It sounds like you've run through a number of scenarios.So first, let's get you upgraded to the latest Netduino Go firmware. There's no reason, really, to be on the old firmware.Second of all...if you're going to use Pins.ONBOARD_LED, you'll want to change the "SecretLabs.Hardware.NetduinoGo.dll" out for "SecretLabs.NETMF.Hardware.Netduino.dll" instead. Also make sure that you upgrade your Shield Base to the latest firmware.Then when you press the pushbutton, the LED on the Shield Base's GoPort should turn on. Release the pushbutton and it should turn off. Because you're using the beta Shield Base auto-detect feature...it'll take a few seconds to connect when the board reboots.Does that help you get off in the right direction? We're here to help; we just need to know what you're seeing and doing.Chris
I'd been trying to work out why the inboard led wouldn't do anything, so this answers that question, thanks
