SD Card cannot get basic example working
10 replies to this topic
#1 Julian de Wit
Julian de Wit
  • 6 posts
Posted 13 December 2010 - 02:38 PM
Hi I want to try my SD card on de the netduino plus.
I downloaded the SDK from this website yesterday.
I could not find documentation so I figured out the following code.
However it gives "CLR_E_VOLUME_NOT_FOUND".. What do I do wrong ?
I read something online about mounting and a certain dll (SecretLabs.NETMF.IO.dll ) but I cannot find that dll.
Can anybody help me getting started ?
            var dir = Directory.GetCurrentDirectory();
            var fileName = Path.Combine(dir, "test.txt");
            Debug.Print(fileName);
            byte[] testBytes = new byte[] { 1,2,3,4 };
            File.WriteAllBytes(fileName, testBytes);
Output :
\test.txt
#### Exception System.IO.IOException - CLR_E_VOLUME_NOT_FOUND (1) ####
#### Message:
#### System.IO.Path::NormalizePath [IP: 0070] ####
#### System.IO.Path::GetFullPath [IP: 001a] ####
#### System.IO.FileStream::.ctor [IP: 0009] ####
#### System.IO.File::WriteAllBytes [IP: 0012] ####
#### NetduinoPlusApplication1.Program::Main [IP: 0025] ####
A first chance exception of type 'System.IO.IOException' occurred in System.IO.dll
An unhandled exception of type 'System.IO.IOException' occurred in System.IO.dll
#2 AlfredBr
AlfredBr
  • 137 posts
  • LocationConnecticut, USA
Posted 13 December 2010 - 05:41 PM
What size SD card are you using?
#3 Chris Walker
  • 6119 posts
Posted 13 December 2010 - 05:44 PM
Hi Julian,
Welcome to the Netduino community.
Three quick things:
1. The MicroSD card will be mounted at \SD\ rather than \
2. MicroSD cards up to 2GB are generally supported.
3. SecretLabs.NETMF.IO is only needed for manually mounting and dismounting--on the regular Netduino. The Netduino Plus automatically mounts and dismounts MicroSD Cards.
Does that help?
#4 Julian de Wit
Julian de Wit
  • 6 posts
Posted 13 December 2010 - 07:11 PM
Thanks for the fast replies...
I needed to write to the "\SD\" map... That was it...
I'm still wondering if there is any documentation about this in the wild ?
But I can go on with my project !!
#5 Chris Walker
  • 6119 posts
Posted 13 December 2010 - 08:00 PM
Hi Julian,
It works exactly like the file IO commands on the desktop... Card is auto-mounted. Would you like us to recommend a few good pointers on .NET file system code?
#6 nturpin77
nturpin77
  • 42 posts
  • LocationNewfoundland, Canada
Posted 19 January 2011 - 05:30 PM
are there any examples of sending data from the serial lines to a file on the SD card?
#7 Govind
Govind
  • 5 posts
Posted 14 November 2012 - 06:47 PM
when i try to read a text file from sd card i am getting the below error
Exception:
Exception was thrown: System.IO.IOException
StackTrace:
Microsoft.SPOT.IO.NativeIO::GetAttributes
System.IO.StreamReader::.ctor
NetduinoPlusApplication1.Program::ReadTextFile
can someone let me know what is wrong in this code.
Code:
        public static void ReadTextFile()
            try
                using (var reader = new StreamReader(@"\SD\" + "Sample1.txt"))
                    string line;
                    while ((line = reader.ReadLine()).Length != 0)
            catch (Exception ex)
Edited by Chris Walker, 14 November 2012 - 06:50 PM.
added [code][/code] tags
#8 Coyttl
Coyttl
  • 54 posts
  • LocationSilver Spring, MD, USA
Posted 14 November 2012 - 06:50 PM
Try reformatting your card (to be safe, FAT, not FAT32) and making sure the file exists.. :)
#9 Govind
Govind
  • 5 posts
Posted 22 November 2012 - 06:42 PM
Thanks for your help. After formatting the sd card i was able to read the file.
Now I am trying to read every pixel value of a bitmap file present in sd car, but got struck could you please give some links or sample code?
Below is what i tried
using (var filestream = new FileStream(@"\SD\Sample.bmp", FileMode.Open))
StreamReader sr = new StreamReader(filestream);
Stream strm = sr.BaseStream;
int len = int.Parse( strm.Length.ToString());
Byte[] bt = new Byte[len];
strm.Read(bt, 0, len);
strm.Close();
sr.Close();
bt will have only 346 elements where as my bitmap file has 24*19 => 456 pixels.
Please help me to read every pixel(all 456 pixel) value of a bitmap.
Thanks in advance for your help.
#10 Govind
Govind
  • 5 posts
Posted 26 November 2012 - 04:44 PM
Can any one help me on the above post?
Thanks in Adavance
Srinivas R
#11 tim c
tim c
  • 28 posts
Posted 26 November 2012 - 06:33 PM
Thanks in Adavance
Srinivas R
What happens if you replace all your code with this:
Byte[] bt = File.ReadAllBytes(@"\SD\Sample.bmp");
