Salt Water Aquarium Controller
9 replies to this topic
#1 zemuss
zemuss
  • 69 posts
Posted 11 February 2013 - 06:03 PM
Ok I have done a ton of research and it is time to start my project.
The controller will be based on the NetDuino Go board and the project will start off very basic with a temperature sensor for display tank and sump temperature sensor.
Temperature sensor will be: https://www.sparkfun.../products/11050
Future plans:
Ph sensor from Atlas-Scientific: http://www.atlas-sci...its/ph-kit.html
Light Controller for LED lighting system.
#2 zemuss
zemuss
  • 69 posts
Posted 11 February 2013 - 06:05 PM
I am looking for some feed back on the Temperature sensor.
If I hook that directly to the shield base module should I use some type of breakout board? Meaning use a three prong connector instead of hooking it directly to the shield base board?
"Z"
#3 jeittreim
jeittreim
  • 12 posts
Posted 11 February 2013 - 06:51 PM
Some pics of my setup (will add more pics of my controller and electronics soon)
Attached File  tank.jpg   46.17KB   39 downloadsAttached File  1Month-old.jpg   57.71KB   55 downloadsAttached File  LCD.jpg   32.9KB   54 downloadsAttached File  sump.jpg   44.68KB   50 downloadsAttached File  drillout.jpg   32.96KB   45 downloads
#4 zemuss
zemuss
  • 69 posts
Posted 11 February 2013 - 09:54 PM
I will take some screen shots of the GUI I am creating.
Do you know any free gauge controls that I can use?
#5 zemuss
zemuss
  • 69 posts
Posted 13 February 2013 - 04:42 PM
Using the Agauge controls I created this GUI.
Took some of my lunch time and dialed in the graphics better.
#6 jeittreim
jeittreim
  • 12 posts
Posted 13 February 2013 - 06:47 PM
I like what you got so far.  I would recommend changing the scale a bit for your dials (ph range from 7-9 and temp from 60-90 would give you a more accurate display that would be easier to read).  you could also throw up a digital readout next to or below each dial.  this would give you a better at-a-glance appeal.
#7 zemuss
zemuss
  • 69 posts
Posted 13 February 2013 - 07:56 PM
Yes I think I will create a digital read out, however if I go that route then the gauges are not required.
I am going to make another mock up with digital and see which I like.
#8 zemuss
zemuss
  • 69 posts
Posted 13 February 2013 - 09:28 PM
Check it out...
#9 mcinnes01
mcinnes01
  • 325 posts
  • LocationManchester UK
Posted 15 February 2013 - 06:59 PM
Good work guys, I would be interested to know how you are passing your values to your web server and storing them? I take it you are using a web server?
Many thanks,
Andy
#10 zemuss
zemuss
  • 69 posts
Posted 16 February 2013 - 04:40 AM
Haven't gotten that far. These are just mock ups.
Waiting for the Temp Sensors.
