I2C on Netduino 1 not working
netduino i2c
23 replies to this topic
#21 kersten
kersten
  • 9 posts
  • LocationGermany
Posted 18 March 2013 - 08:59 PM
The processing of the 3 bytes in 3 transactions was only to test. The first transaction returns as Return Code: 0 bytes transfers. In the original code, all 3 bytes processed in one transaction but only with the Return Code: 0 Bytes The SCL line has at times no pulse on the instrument but always 4.85V even after the end of the transaction. Next I change my test back to one transaktion.
#22 kersten
kersten
  • 9 posts
  • LocationGermany
Posted 18 March 2013 - 09:16 PM
My new test with the code: always count is 0: public static void Main(){ var device = new I2CDevice(new I2CDevice.Configuration(0x50, 100)); I2CDevice.I2CTransaction[] actionsWrite; uint adresse = 0x01; byte[] data = new byte[] { 0x42 }; byte[] buffer = new byte[3]; buffer[0] = (byte)(adresse >> 8); buffer[1] = (byte)adresse; data.CopyTo(buffer, 2); uint i = 0; do { actionsWrite = new I2CDevice.I2CTransaction[] { I2CDevice.CreateWriteTransaction(buffer) }; int count1 = device.Execute(actionsWrite, 1000); Thread.Sleep(1000); i++; Debug.Print(i.ToString()+" Count: " + count1.ToString()); } while (true); } I think the board is defective!
#23 Chris Walker
Posted 30 March 2013 - 05:59 PM
Hi kersten, What does the signal look like on a logic analyzer? Are you using Netduino gen1 or Netduino gen2? Which pins are you using? Finally...what value are you using for your pull-up resistors? Chris
#24 kersten
kersten
  • 9 posts
  • LocationGermany
Posted 04 April 2013 - 03:38 PM
Hi Chris, I currently have no logic analyzer. My board is a "Netduino 2". Through the change of the pull-ups on 1.2 k, my problem currently is solved with the I2C . The board is working correctly. The bus line I first kept short. Am now going to test the OneWire DS 2482-100 with 1 DS18S20 on the I2C Bus. But I find no code example. The onewire functions are new in the 4.2 framework? Where can I get help for Microsoft.SPOT.Hardware.OneWire class?
