Is my Netduino fried?
#1 Arian
Arian
  • 18 posts
Posted 04 February 2013 - 07:02 PM
I had troubles with updating my Netduino on Windows 8 x64 and ended up shorting the gold dot and 3v to reflash the firmware.  I can't seem to do anything with it now.  When I plug it in with the reset switch down, then select the GPS Camera Detect driver, it installs but says that the device can't start (code 10).  Of course from there I can't do anything else.  Is there anything else I can try to even get it a COM port to update with Sam-ba or is that enough info to indicate that it's fried?
I should also point out that this is on multiple USB ports, and not through a USB hub.  Also, I find it interesting that Device Manager shows the hardware ID as USBDEVICE_DESCRIPTOR_FAILURE.  Maybe that's normal before the driver is installed though...
Posted 04 February 2013 - 07:06 PM
Hi Arian, If the device appears as "GPS Camera Detect" when you plug it in, it's likely fine. That means that it's booting into the Atmel SAM-BA bootloader. Are you running the latest SAM-BA (2.12 with patches)? If so, I would also try "uninstall driver and remove it from my computer" on the "GPS Camera Detect" device. Chris
#3 Arian
Arian
  • 18 posts
Posted 04 February 2013 - 07:21 PM
I had to manually assign it the GPS Camera Detect driver (based on other forum posts).  When I uninstall and delete drivers, then plug it back in again, I go back to unknown device.  I can download and install the GPS Camera Detect drivers again, but the device still won't start.
#4 Chris Walker
Posted 04 February 2013 - 07:53 PM
Hi Arian, If it doesn't auto-detect the "GPS Camera Detect" drivers, then there may be something wrong. Try erasing it again, carefully, by applying 3.3V to the ERASE pad for about a second. Do you have any other computers, by any chance? Chris
#5 Arian
Arian
  • 18 posts
Posted 04 February 2013 - 08:10 PM
I do, but they are all Windows 8, x64.  I suppose it could be the USB ports though.  I tried a second Netduino that I have and it looks ok, so it's not the USB cable anyway.
