Components for Netdunio Plus 2
#1 yetanothernetduino
yetanothernetduino
  • 7 posts
Posted 01 February 2013 - 02:42 PM
HI All,
I am coming from a .net background so programming won't be hard.
I just got hooked into Netduino about 3 hours ago. Immediately, I just want to build a computerized controlled watering system (now) and control some lights (near future)
Can you please suggest me what's the relay module for Netdunio Plus 2? I saw there are a couple on eBay/Amazon and I am a bit confused and not sure if they are compitable, and what else do I need in order build this system?
I am starting with two empty hands, and the items I have in mind so far are
1. solenoid wavles, pipe, drippers
2. netduino plus 2
Thank you in advance :)
#2 Lunddahl
Lunddahl
  • 152 posts
  • LocationEurope, Denmark
Posted 01 February 2013 - 10:40 PM
You should start here:
http://wiki.netduino...lay-Module.ashx
http://wiki.netduino...rrent-load.ashx
http://lmgtfy.com/?q...ontroller relay
A good advice would be to select the solenoid valve's first, then a relay that is fit to drive it, then a circuit that can drive that relay.
- Ulrik
#3 yetanothernetduino
yetanothernetduino
  • 7 posts
Posted 02 February 2013 - 04:25 AM
Thanks Ulrik, Sorry for a newbie question. I have zero knowledge in electronic So if the valve is 12v that means I need 12v relay board? Do you know anyone selling just a kit so all I do is put them together to archive this project. I am mostly interested in programming. Or do you know any website that list out exact items to buy for this type of project? Thanks again for your reply
#4 Lunddahl
Lunddahl
  • 152 posts
Posted 02 February 2013 - 08:01 PM
I'm not an electronic eagle either, but I think the valves will be the hardest to get, a suitable relay or whatever is smart to drive it will be easy to select when you have the valve datasheet. I have no clue as to where you can buy valves. - Ulrik Lunddahl
#5 yetanothernetduino
yetanothernetduino
  • 7 posts
Posted 12 February 2013 - 05:43 AM
Hi All,
After doing some research for watering controlled system
1. netduino plus 2 - because I am familiar with .NET
2. solenoid valve http://www.alpha-cru...0386509971.html
3. 12V Relay Board
4. Breadboard
5. LED lights (indicator)
6. Wires/jumpers
Anything I need? What type of resisters do I need? Can you some of us kindly list out the items I've missed out? :)
To be franky, I just want to buy a kit - but there are none. I am just interested in programming side and that's all.
