Mcp23s17 (SPI) with NP2+
#1 Xtrophic
Xtrophic
  • 9 posts
  • LocationSweden
Posted 31 January 2013 - 12:07 AM
I am trying to get an Mcp23s17 interfaced with my NP2 to eventually drive an LCD screen.
I am not having much success getting the Mcp23s17 to work. The first simple scenario I was thinking was to just light up a simple LED using one of the GPIOs on the Mcp.
I have updated to the latest firmware in hopes that there were some issues there.
I am attaching a pic of how it's wired, in case something is wrong there (but I hope not).
I have modified the MFToolbox code for Mcp23017 to basicly use SPI instead, and I have tried manually just sending the commands to the device via SPI write. But so far no luck what so ever.
When using SPI directly:
            spiConfig = new SPI.Configuration(Pins.GPIO_PIN_D10, false, 0, 0, false, true, 1000, SPI_Devices.SPI1);            Microsoft.SPOT.Hardware.SPI spi = new SPI(spiConfig);            spi.Write(new byte[] { 0x40 });     // Adress            spi.Write(new byte[] { 0x00, 0x00 });   // Set bank A to output            spi.Write(new byte[] { 0x01, 0x00 });   // Set bank B to output            spi.Write(new byte[] { 0x12, 0xff });   // Set bank A outputs to high            spi.Write(new byte[] { 0x13, 0xff });   // Set bank B outputs to high            spi.Dispose();
Or when using the quickly modified mcp23017 code:
            spiConfig = new SPI.Configuration(Pins.GPIO_PIN_D10, false, 0, 0, false, true, 1000, SPI_Devices.SPI1);            var mux = new Toolbox.NETMF.Hardware.Mcp23s17(spiConfig);            for (int i = 0; i < 16; i++) {                mux.Pins[i].Write(true);            }
Any help or suggestion on the matter would be appreciated :)
#2 Xtrophic
Xtrophic
  • 9 posts
  • LocationSweden
Posted 31 January 2013 - 08:02 PM
It was missing a 10k ohm pullup on the reset pin, plus the code was a bit off. But now I got a simple command working so I will continue to tune the class to get it complete :) Once it's complete I'll share the code.
#3 Xtrophic
Xtrophic
  • 9 posts
  • LocationSweden
Posted 01 February 2013 - 07:49 PM
So one step done, in that I can sucessfully set pin outputs to values. But when I attempt to query the device for information I do not get anything back.
Here is the code I am using:
            spiConfig = new SPI.Configuration(Pins.GPIO_PIN_D10, false, 0, 0, false, true, 10000, SPI_Devices.SPI1);            Microsoft.SPOT.Hardware.SPI spi = new SPI(spiConfig);            spi.Write(new byte[] { 0x40, 0x00, 0x00 });   // Set bank A to output            spi.Write(new byte[] { 0x40, 0x01, 0x00 });   // Set bank B to output            spi.Write(new byte[] { 0x40, 0x12, 0x0f });   // Set bank A outputs to high            spi.Write(new byte[] { 0x40, 0x13, 0xff });   // Set bank B outputs to high            byte[] readBuffer = new byte[1];            byte[] readBuffer2 = new byte[1];            spi.WriteRead(new byte[] { 0x41, 0x14 }, readBuffer, 1);    // Attempt to query OLATA            spi.WriteRead(new byte[] { 0x41, 0x12 }, readBuffer2, 1);   // Attempt to query GPIOA            // buffer & buffer2 are still 0 or if I run it at 1MHz it's 255 ...            Debug.Print("");            spi.Dispose();
Am I doing something wrong in the code, or I am still missing a pullup somewhere? Any suggestions on how to proceed would be appreciated! :)
#4 hanzibal
hanzibal
  • 1287 posts
  • LocationSweden
Posted 02 July 2013 - 02:01 PM
Hi, did you get this driver working eventually?
#5 k_madsen
k_madsen
  • 22 posts
  • LocationEsbjerg Denmark
Posted 30 July 2014 - 08:13 AM
Hi
This simple code works with no interrupt and porta as out and port b as in adresse is 64 write and 65 read (all low)
setRegister(register , value);
byte readRegister(register);
//using SecretLabs.NETMF.Hardware;
namespace addonkm
    class MCP23S17
        const byte IODIRA = 0x00; //iodirektion register 1 = in  0 = out default = 1
        const byte IODIRB = 0x10;
        const byte IPOLA = 0x01; // invert pin om port   1 = invert  default = 0
        const byte IPOLB = 0x11;
        const byte GPINTNA = 0x02; //int on change 1 = aktiv  default = 0
        const byte GPINTNB = 0x12;
        const byte DEFVALA = 0x03; //def comp reg on chage ved int on def change der genereres et int hvis 1 bit ikke har samme polaritet som dette register hvis enablet(intcon)
        const byte DEFVALB = 0x13;
        const byte INTCONA = 0x04; // int control register  1 = compare with DEFVALA 0 = compare with last pin value
        const byte INTCONB = 0x14;
        const byte IOCON = 0x05;  // io expander config register bit 7 = bank mirror seqop disslw haen odr intpol 0
        const byte GPPUA = 0x06;    // pullup ressistors
        const byte GPPUB = 0x16;
        const byte INTFA = 0x07;    //int flag register 1 = pin that coursed the interrupt
        const byte INTFB = 0x17;
        const byte INTCAPA = 0x08; // interrupt captured value
        const byte INTCAPB = 0x18;
        const byte GPIOA = 0x09;  //Port register read port value read
        const byte GPIOB = 0x19;
        const byte OLATA = 0x0a;    // output latch register   write
        const byte OLATB = 0x1a;
        private byte adresse;
        private byte adrread;
        static SPI.Configuration spiNormal = new SPI.Configuration(Pins.GPIO_PIN_D7,
        false,
        0,
        0,
        false,
        true,
        10000,
        SPI_Devices.SPI1
        SPI SPIBus = new SPI(spiNormal);
        public void setRegister(byte register, byte value)
            byte[] buff = new byte[3];
            buff[0] = adresse;
            buff[1] = register;
            buff[2] = value;
            SPIBus.Write(buff);
        public byte readRegister(byte register)
            byte[] readbuff = new byte[3];
            buff[0] = adrread;
            buff[1] = register;
            buff[2] = 0; //spi dummy
            SPIBus.WriteRead(buff, readbuff);
            return readbuff[2];
        private MCP23S17()
        public MCP23S17(byte adress)
            adresse = (byte)(adress << 1);
            adrread = (byte)(adresse | 1);
            //saet port a til out og port b ind
            setRegister(IODIRA, 0); // alle bit out
            setRegister(GPPUA , 0xff); // alle pull op trans on
            setRegister(GPPUB, 0xff);
            setRegister(IOCON, 0xe2);
