This firmware requires use of the .NET Micro Framework v4.2 SDK (QFE2) and Netduino 4.2.2.0 SDK.
384KB Flash
100KB+ RAM
1. Bug fix: SPI clock 'idle high' setting now supported
This firmware also includes the previous updates:
1. Netduino Plus 1 projects can be upgraded without changing HardwareProvider
2. Now compatible with legacy SecretLabs AnalogInput and PWM classes
3. Bug fix: SPI chip select timing corrected
4. Bug fix: PWM frequency corrected
5. New: more reliable rebooting during deployment
6. Static IP now works (in addition to DHCP default)
7. MAC Addresses are now loaded by TinyCLR
8. Additional I2C bug fix--pins now forced into proper configuration
To flash this firmware:
1. Detach your Netduino
3. Erase the firmware on your Netduino using the STDFU Tester application
> d. Press the "Go" button
4. Flash the attached .DFU file using the ST DfuSe Demonstrator application (included with STDFU Tester)
After flashing, to set your network settings using MFDeploy:
1. Select the Target > Configuration > Networking menu. Re-enter your IP address settings and MAC address.
