I'm trying to get my LCD display working.
Using:
http://www.amazon.co...ils_o00_s00_i02
Wiring:
http://www.dfrobot.c...ect_DFR0154.png
Also looking for .NET code to run this....
Eric
17 replies to this topic
Posted 17 January 2013 - 11:16 PM I'm trying to get my LCD display working.
Using: http://www.amazon.co...ils_o00_s00_i02
Wiring: http://www.dfrobot.c...ect_DFR0154.png
Thanks, Eric
Posted 18 January 2013 - 02:24 PM Are you connecting directly to the LCD or using something in between? I have these working on a N+2:
I think it is the same LCD. I will be posting a code sample this weekend and will up date you as to were you can find it.
Also - if you are using I2C as your hookup diagram shows you need to go into the N+2 ports SC and SD.
Posted 18 January 2013 - 03:03 PM Wiring:
You are connecting wrong input (yellow and green). Try digital pins
Posted 18 January 2013 - 04:03 PM Hi eschneider999 and welcome to the forums.
First, with the ND+2 you need to use the SDA and SCL pins instead of A4 & A5 pins for I2C, so you cannot use the diagram, it will not work.
One of the best libraries I've found for LCDs is the Microliquidcrystal library at CodePlex. There are good examples in the download for using I2C. If you are still stumped, let us know and we'll get you some example.
Good Luck and Happy Coding.
Posted 18 January 2013 - 05:01 PM Thanks guys, I will review all this and give it a try.
FYI: I'm a Software Engineer, but seems everything is broke for Netdruino plus 2. Seems I have to fix alot of things, and still can't get some things to build.
Also why didn't my posts show-up yesterday? Very frustrating...
Posted 18 January 2013 - 10:23 PM Thanks guys, I will review all this and give it a try.
Not sure about the posts. Never had a problem posting here so far and I've posted some 566 times.
What do you mean by "everything is broke for Netduino Plus 2". Most ND+2 stuff is working now. If you describe what you feel is broken perhaps we can point you in the right direction or if it is a real issue with the ND+2, perhaps this will help Chris fix the issues knowing more of your details.
Posted 19 January 2013 - 03:03 AM Can anyone give me a wiring diagram?
Also; my version is 4.2
All the code points to 4.1 and changing to 4.2 seems to be an issue. Some classes are missing in 4.2 (SecretLabs)
Posted 19 January 2013 - 03:21 AM Can anyone give me a wiring diagram?
Wiring isn't that hard. 5V goes to 5V, GND to GND, SDA to SD and SCL to SC.
Posted 19 January 2013 - 05:11 AM Also why didn't my posts show-up yesterday? Very frustrating...
Hi eschneider888 and welcome to the community! I'm sorry to hear you were having some troubles posting. Unfortunately our forums have been hit in the past with a lot of spam bots and so now before anyone can post, their membership has to be approved by a moderator. I suspect that your account was just in the process of being verified and I highly doubt you'll have any future troubles posting.
Cheers, Steve Twiiter: https://twitter.com/Gutworks
Posted 19 January 2013 - 05:19 AM Can anyone give me a wiring diagram? Yes there have been some changes with the jump from 4.1 to 4.2 but with some small changes you should be able to get your 4.1 examples working after converting them to the 4.2 framework. There was a lot of work done with latest firmware (4.2.2.0) to make the Secret Labs classes more consistent and backwards compatible. If you can provide some examples where you're having some troubles, we'd be more than willing to give you hand and getting your code working again.
Posted 19 January 2013 - 05:40 AM Sounds like I have it wired correctly.
Keep getting errors when starting:
A first chance exception of type 'System.IO.IOException' occurred in MicroLiquidCrystal.dll
Posted 22 January 2013 - 01:49 PM Sounds like I have it wired correctly. What using statements do you have and what is in your references?
Also, I have found it best to NOT use a compiled DLL, but instead to use the source and include it as part of my solution. That way the DLL gets compiled for MY specific project. So, maybe try using the source for MicroLiquidCrystal.dll instead of referencing it directly.
Posted 31 May 2013 - 09:14 AM Hello All, I get the IO exception error on N+ with 4.2 update. Has anyone tried the code on N+ only?. TIA
Posted 12 June 2013 - 08:08 PM Hello All,
I had the same error. The compiled DLL has also worked with my N+1, but not on the N+2. I have tried a few things, but now my 16x2-Display is working with both boards. I've simply Re-Compiled the DLL under Micro Framework 4.2 (Change it in the Project-Properties). The Code is available at Codeplex.
Hope it helps.
General →
Project Showcase →
Adafruit RGB LCD ShieldStarted by giawa, 19 Jul 2015 ![]() |
General →
General Discussion →
Anyone used a ST7565 GLCD????Started by david98xp, 28 Nov 2014 ![]() |
Hardware →
Netduino 2 (and Netduino 1) →
N2 + I2C 1602 LCDStarted by FredOrJoeBlogs, 11 Aug 2014 ![]() |
General →
Driver for LCD with I2C backpackStarted by Esben, 08 Aug 2014 ![]() |
Hardware →
LCD Native Driver?Started by tonofsteel, 25 Jul 2014 ![]() |
home hardware projects downloads community where to buy contact | Copyright © 2016 Wilderness Labs Inc. | Legal  | |
