hi,
i have a problem in coding the netduino!!!!!!!!!!
i have to design the mobile controlled robot as described in the following document:
http://raghueee.110m...te_Document.pdf
or
find the attachment of the same.
but i have the following two problems:
1) how should i replace the microcontroller with netduino.
2) i want an equivalent c# code for the embedded c code given in the document
equivalent c# code for a embedded c code
Started by Beowolf, Dec 02 2010 07:05 PM
1 reply to this topic
Posted 02 December 2010 - 07:05 PM
Posted 03 December 2010 - 07:24 AM
I'm just going to post code for a generic DTFM chip. This specific code is for an MT8870. Probably overkill, but I'm still getting used to writing for the NETMF and microcontrollers.
If your using the HT9170 like in the PDF you linked to, you'll want to connect them something like:
Note: 10 = '0'; 11 = '*'; 12 = '#'
HT9170 Netduino ======== ========== Pin 11 D6 Pin 12 D7 Pin 13 D8 Pin 14 D9
public class DTFM : IDisposable { private Thread ListenThread; private bool Listening; private int LastValue; private InputPort Binary1; private InputPort Binary2; private InputPort Binary4; private InputPort Binary8; public delegate void OutputHandler(object sender, int value); public event OutputHandler Output; public DTFM(Cpu.Pin Binary1, Cpu.Pin Binary2, Cpu.Pin Binary4, Cpu.Pin Binary8) { // Initialize the local InputPort's utilized by the DTFM this.Binary1 = new InputPort(Binary1, false, Port.ResistorMode.Disabled); this.Binary2 = new InputPort(Binary1, false, Port.ResistorMode.Disabled); this.Binary4 = new InputPort(Binary1, false, Port.ResistorMode.Disabled); this.Binary8 = new InputPort(Binary1, false, Port.ResistorMode.Disabled); // Initialize the listener thread Listening = true; ListenThread = new Thread(new ThreadStart(Listen)); ListenThread.Start(); } public void Dispose() { // Make the thread expire Listening = false; Thread.Sleep(10); // Force the thread dead just in case if (ListenThread.IsAlive) ListenThread.Abort(); // Free the InputPort's Binary1.Dispose(); Binary2.Dispose(); Binary4.Dispose(); Binary8.Dispose(); } void Listen() { while (Listening) { // Don't execute if nothing is attached to the event if (Output != null) { int CurrentValue = 0; // Build the current value from the DTFM if (Binary1.Read()) CurrentValue += 1; if (Binary2.Read()) CurrentValue += 2; if (Binary4.Read()) CurrentValue += 4; if (Binary8.Read()) CurrentValue += 8; // If the value has changed, throw a new event if (CurrentValue != LastValue) { LastValue = CurrentValue; Output(this, CurrentValue); } } // Wait Thread.Sleep(100); } } }
