Get files from SD card via usb connection. Is it possible?
#1 zmuro
zmuro
  • 4 posts
Posted 03 January 2013 - 01:26 PM
Hi.
I have N+ for about two weeks now. I use N+ to take readings from load cell and strore data in to file on SD card. How can I transffer these files to my PC without taking SD card from N+?
And another question. What should I do to make my N+ run for 10s, taking readings from load cell and then write those reading to SD card?
Regards
#2 NooM
NooM
  • 490 posts
  • LocationAustria
Posted 03 January 2013 - 01:47 PM
via usb is not possible, but you can use uart (serial ports) ((edit: maybe its possible, but very hard todo.. switch deployment to serial, and i bet writing an usb driver)
with or without cable, doesent matter.
or if you have a plus or plus 2 you could use ethernet also
#3 zmuro
zmuro
  • 4 posts
Posted 03 January 2013 - 07:38 PM
I have N+ with ethernet, how can I access the content on SD card? Do I need Http Server running on it?
#4 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 03 January 2013 - 09:44 PM
Doesn't need to be an http server but that does work.  You just need to implement some Ethernet enabled protocol to access it.  You can also use serial communications using one of the COM ports on the ND+.
