Best Answer Chris Walker, 06 January 2013 - 06:16 AM
Quick note: this has been fixed, and the fix is currently in testing.
![]() Confusion of PWN Pins on ShieldBase
Started by halobox, Dec 31 2012 01:41 AM
![]() Best Answer Chris Walker, 06 January 2013 - 06:16 AM
5 replies to this topic
Posted 31 December 2012 - 01:41 AM Hi,
I'm experimenting with an arduino motor shield on the Netduino Go Shieldbase and come to confusing results... I hope any of you can help me out :-)
I'm trying to activate the necessary PWNs.
If I activate for example sb.PWMChannels.PWM_PIN_D3 I get a signal at pin2 on the ShieldBase
CodeExample:
using System;using System.Threading;using Microsoft.SPOT;using Microsoft.SPOT.Hardware;using SecretLabs.NETMF.Hardware;using SecretLabs.NETMF.Hardware.NetduinoGo;using NetduinoGo;namespace NetduinoGoApplication2{ public class Program { public static ShieldBase sb; public static Microsoft.SPOT.Hardware.PWM pow0; public static void Main() { // write your code here sb = new ShieldBase(GoSockets.Socket4); double freq = 50; double dutyc = 0.5; pow0 = new Microsoft.SPOT.Hardware.PWM(sb.PWMChannels.PWM_PIN_D3, 50, 0.5, false); pow0.Start(); //pow0.Stop(); while (true) { Thread.Sleep(3000); } } }}
If I activate the PWN pins in code I get the following results (measured by a buzzer I connected to the pins on the ShieldBase via cable ;-): pin 3 = ShieldBase pin 2 activated
I expected the PWNs to be activated on the Shield as labeled in code and as described by Gutworks (http://forums.netdui...uino-go-shield- base-pinout/)
The current setting would make it necessary to bend the pins to different pins on the motorshield although they should be the same in specs.
Do I make a mistake or is there a bug?
Regards halobox
Posted 06 January 2013 - 05:20 AM Hi halobox,
Sorry it has taken me a while to respond. I tried reproducing your sample, and I found the same sort of issues using a logic analyzer. These are bugs to the current beta version of the Shield Base and they have been passed along to the Secret Labs team.
I don't advise bending any pins just yet, as I'm sure these issues will be fixed in an upcoming firmware update. I don't know when the update will be, but I don't expect that it will be a long wait.
Which motor shield are you using? I have plans for my Shield Base and a motor shield as well.
Cheers, Steve Twiiter: https://twitter.com/Gutworks
Posted 06 January 2013 - 06:16 AM Best Answer
Posted 06 January 2013 - 01:25 PM Quick note: this has been fixed, and the fix is currently in testing. Chris Awesome!
Halobox, when the new firmware has been posted, I'd love to see your motor shield working. Perhaps we can compare notes
Posted 14 January 2013 - 06:45 PM Thanks to the new firmware it seems to work now.
halobox 1 user(s) are reading this topic0 members, 1 guests, 0 anonymous users | ||||||||||||||
