Javascript Disabled Detected
You currently have javascript disabled. Several functions may not work. Please re-enable javascript to access full functionality.
The Netduino forums have been replaced by new forums at
community.wildernesslabs.co .
12 replies to this topic
Posted 30 December 2012 - 09:53 PM
I am trying to send email from my Netduino Plus 2 using the Toolbox.NETMF.NET framework but I get a System.ArgumentOutOfRangeException no matter what I do.
My code:
using Toolbox.NETMF.NET;namespace SendMail{ public class Program { public static void Main() { // write your code here SMTP_Client.MailContact from = new SMTP_Client.MailContact("test@test.net"); SMTP_Client.MailContact receiver = new SMTP_Client.MailContact("test@test.net"); SMTP_Client.MailMessage message = new SMTP_Client.MailMessage("test"); message.Body = "Hello World!"; IntegratedSocket integratedSocket = new IntegratedSocket("smtp.gmail.com", 587); SMTP_Client client = new SMTP_Client(integratedSocket, SMTP_Client.AuthenticationTypes.None, "test@test.net", "test"); client.Send(message, from, receiver); } }}
In the line where I create the "client" the following error is thrown:
A first chance exception of type 'System.ArgumentOutOfRangeException' occurred in mscorlib.dll
An unhandled exception of type 'System.ArgumentOutOfRangeException' occurred in mscorlib.dll
Uncaught exception
The thread '<No Name>' (0x1) has exited with code 0 (0x0).
Any ideas where I go wrong?
Using NETMFToolbox 21098, rel 4.2
Regards, Larre
Stefan
Location Breda, the Netherlands
Posted 30 December 2012 - 10:30 PM
Well, you're using SMTP_Client.AuthenticationTypes.None but still using a user/pass. That's a bit odd really.
Also, GMail doesn't support SMTP over plain text with authentication.
I read a possible work-around here: http://cavewall.jagu...out-ssl-part-1/
But it's not really supported by google from what I understand.
Posted 30 December 2012 - 11:35 PM
Sorry, the SMTP_Client.AuthentcationTypes.None was just a rest from my experiments, didn't tidy up the code before posting.
I have tried the following line also to no avail:
SMTP_Client client = new SMTP_Client(integratedSocket, SMTP_Client.AuthenticationTypes.Login, "test@test.net", "test");
And now also tried this one with server and port according to your suggested work-around:
SMTP_Client client = new SMTP_Client(integratedSocket, SMTP_Client.AuthenticationTypes.None);
I get the same error using either line. Do you think it can be related to my email server? I'll do some more tests tomorrow with another email server.
Thanks, Larre
Posted 31 December 2012 - 08:37 AM
I tried setting up an account with GMX as suggested in a few other posts but I still got the error so I suspect that I have done something else wrong.
Full output trace:
Create TS. Loading start at 806a328, end 808443cAssembly: mscorlib (4.2.0.0)Assembly: Microsoft.SPOT.Native (4.2.0.0)Assembly: Microsoft.SPOT.Hardware (4.2.0.0)Assembly: Microsoft.SPOT.Net (4.2.0.0)Assembly: System (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.SerialPort (4.2.0.0)Assembly: Microsoft.SPOT.IO (4.2.0.0)Assembly: System.IO (4.2.0.0)Assembly: Microsoft.SPOT.Hardware.PWM (4.2.0.1)Assembly: Microsoft.SPOT.Hardware.Usb (4.2.0.0)Assembly: SecretLabs.NETMF.Diagnostics (4.2.0.0)Assembly: SecretLabs.NETMF.Hardware.Netduino (4.2.1.0)Assembly: Microsoft.SPOT.Hardware.OneWire (4.2.0.0)Assembly: Microsoft.SPOT.Time (4.2.0.0)Loading Deployment Assemblies.Attaching deployed file.Assembly: Toolbox.NETMF.NET.SMTP_Client (4.2.0.0)Attaching deployed file.Assembly: Toolbox.NETMF.Core (4.2.0.0)Attaching deployed file.Assembly: SendMail (1.0.0.0)Attaching deployed file.Assembly: Toolbox.NETMF.NET.Core (4.2.0.0)Attaching deployed file.Assembly: SecretLabs.NETMF.Hardware (4.2.0.0)Attaching deployed file.Assembly: Toolbox.NETMF.NET.Integrated (4.2.0.0)Resolving.The debugging target runtime is loading the application assemblies and starting execution.Ready.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2Assemblieslemscorlib.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Native.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Net.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleSystem.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.SerialPort.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.IO.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleSystem.IO.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.PWM.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.Usb.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Secret LabsNetduino SDKAssembliesv4.2leSecretLabs.NETMF.Diagnostics.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Secret LabsNetduino SDKAssembliesv4.2leSecretLabs.NETMF.Hardware.Netduino.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Hardware.OneWire.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Microsoft .NET Micro Frameworkv4.2AssembliesleMicrosoft.SPOT.Time.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'D:DownloadNetduinonetmftoolbox-21098Release (4.2)leToolbox.NETMF.Core.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'D:DownloadNetduinonetmftoolbox-21098Release (4.2)leToolbox.NETMF.NET.Core.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'D:DownloadNetduinonetmftoolbox-21098Release (4.2)leToolbox.NETMF.NET.SMTP_Client.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'D:DownloadNetduinonetmftoolbox-21098Release (4.2)leToolbox.NETMF.NET.Integrated.dll', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'D:CodeNetduinoSendMailSendMailbinDebugleSendMail.exe', Symbols loaded.'Microsoft.SPOT.Debugger.CorDebug.dll' (Managed): Loaded 'C:Program Files (x86)Secret LabsNetduino SDKAssembliesv4.2leSecretLabs.NETMF.Hardware.dll', Symbols loaded.The thread '<No Name>' (0x2) has exited with code 0 (0x0).A first chance exception of type 'System.ArgumentOutOfRangeException' occurred in mscorlib.dllAn unhandled exception of type 'System.ArgumentOutOfRangeException' occurred in mscorlib.dll Uncaught exception The thread '<No Name>' (0x1) has exited with code 0 (0x0).Done.Waiting for debug commands...The program '[14] Micro Framework application: Managed' has exited with code 0 (0x0).
OZ8ET
Location Hundested, Denmark
Posted 27 March 2013 - 02:51 PM
I have the same problem - is it a v4.2 problem? I cannot get it to accept "IntegratedSocket".
I installed toolbox,
included Toolbox.NETMF.NET.SMTP_Client
IntegratedSocket integratedSocket = new IntegratedSocket("<smtp-server>", 587);SMTP_Client client = new SMTP_Client(integratedSocket, SMTP_Client.AuthenticationTypes.Login, "<username>", "<password>");client.Send(message, from, receiver); ?
jbrowne
Members
Posted 12 April 2013 - 03:51 PM
I have also tried the various examples above, and am also getting the ArgumentOutOfRangeException. It's not just Gmail either, because I've tried with a local smtp email server that accepts Auth, plaintext, and none.
auggieben
Members
Posted 20 April 2013 - 01:04 AM
I'm getting the same error too, so I stepped into the code for 'SMTP_Client( )' and found the following suspicious code.
string Hostname = Tools.HardwareProvider.ToString();
this sets 'Hostname' to "Netduino". (so far so good).
int LastDot = Hostname.LastIndexOf('.');
this sets LastDot to -1 (what's it looking for, a version number?)
this._LocalHostName = Hostname.Substring(0, LastDot); <---- Exception thrown
I don't think the Substring method likes the -1 argument "LastDot"
Does anyone know how to correct this? Can we rebuild the library ourselves or is someone else in charge of this? Any workarounds?
Stefan
Posted 21 April 2013 - 09:38 AM
Ahh that looks familiar. I'll fix it later today and publish an update.
corythompson
Members
Posted 01 May 2013 - 06:34 PM
BUMP...
Hey guys.
I'm also looking for the solution to this problem.
Please help.
Posted 13 May 2013 - 09:30 AM
Stefan did you modified the code? It seems not in last 23314.
In the meanwhile this is my working code:
public SMTP_Client(SimpleSocket Socket, AuthenticationTypes AuthenticationType = AuthenticationTypes.None, string Username = "", string Password = "")
// Copies all parameters to the global scope
this._Socket = Socket;
this._SMTP_User = Username;
this._SMTP_Pass = Password;
this._SMTP_Auth = AuthenticationType;
// By default we fill the hostname with the name of the hardware itself. We need this to identify ourself
//JJ start
if (LastDot > 0)
//JJ end
this._LocalHostname = Hostname.Substring(0, LastDot);
//JJ start
else
this._LocalHostname = Hostname;
//JJ end
ChrisII
Members
Posted 22 May 2013 - 06:42 PM
I am having the exact same problem.
Has this issue been fixed?
herron
Members
Posted 02 July 2013 - 04:44 PM
Trying to fix the same problem. any solutions? still getting "An unhandled exception of type 'System.ArgumentOutOfRangeException' occurred in mscorlib.dll"
brikesh987
Members
Posted 21 June 2014 - 06:46 AM
I am also getting this error. Looks like this bug is not fixed. Did you guys find any other ways to send email?
Also tagged with one or more of these keywords: Toolbox.NETMF.NET, Netduino Plus 2, SMTP_Client, 4.2.1.2
Reply to quoted posts Clear
Netduino Forums
→ Hardware
→ Netduino Plus 2 (and Netduino Plus 1)
Privacy Policy
