Using both Analog and Digital on same pin
Posted 02 December 2012 - 11:20 PM
A little background information;
I'm currently working on a project that uses a Analog/Digital MUX breakout from SparkFun.
The main problem I'm having is that each of these boards have 1 'signal' i/o pin. Since the board can handle both analog and digital signals, I would like to make use of one of the analog pins on the N+.
I tried some short code to switch accordingly between analog and digital, disposing the previous instance of the port before initializing a new one.
After a few times of switching I'm getting 'An unhandled exception of type 'System.Exception' occurred in Microsoft.SPOT.Hardware.dll'
I'm properly disposing the port object AFTER I've retrieved the state/value of the input using the Dispose method of the ports. Im suspecting that somewhere along the way, the object isnt disposed properly in code that is out of my reach (in the .NET framework perhaps).
So my main question is,is there any limitation (think speed wise, number of times, or other..) using this method?
Is this possible at all ( I know it works a few times, but is it possible to have this as permanent solution?)
Posted 03 December 2012 - 12:40 AM
- Arron Chapman likes this
Posted 03 December 2012 - 02:34 AM
you can just use analog, it can read digital signals too... digital is 0v and 3.3v
//edit do not use more than 3.3v on analog pins
//edit iam also not sure if you can connect gnd to analog. someone can confrim this?
I'll echo what NooM said about <= 3.3V anything higher is likely to cause damage to the ADC resulting in poor readings in the future. Regarding GND; Connecting GND to an analog input is fine, it should read 0.0 or just 0 depending on your framework version when you read from the port.
Posted 03 December 2012 - 08:29 AM
Posted 04 December 2012 - 07:18 PM
My project needs to become a central place to hook up sensors using RJ45 plugs and UTP cable. It also should allow me to control SPI and I2C devices connected to it.
Basic setup is;
N+,
2 bit shift registers.
2 SparkFun Mux/Demux boards.
Some other components that do not have any effect on the above (PWM driver from AdaFruit, a Nokia 5110 display, a RFID reader, etc.).
I'm using the bit shift registers to control the 2 sparkfun boards, that part works as intended.
My code allows me to put in a integer (1-32, it's 16 pins a board) and it enables the appropriate board, and selects the correct port (32 enables board 2, select pin 15).
At that point, I'll look up what type of sensor or piece of hardware is attached, from a list of custom 'port objects'.
Those objects contain a type (analog or digital) and some other information (IN/OUT/SPI/I2C/PWM, a port number, memory value for the last read value, etc.)
I need (want) to initiate a AnalogInput, InputPort or OutputPort at that point, allowing me to read a analog value, read a digital value or write a digital value.
That value will be logged (storage card, webservice and if needed, texted to my phone). If the device attached to the port is a SPI device, and action needs to be taken, it should write true (high) to the same pin, as that port will be used as CS pin.
Since I have 2 SparkFun boards, I need to connect 2 wires (1 wire per board) from the signal pin to a pin on the N+. I want to use the A pins here, as the SparkFun boards allow both analog, digital and data to be connected to the boards.
In code, there is a Thread that runs a loop (no interrupt on the sparkfun boards) to set the port number (that is in a list, enabled and needs to perform 'a' action at that time)
I'll paste some pseudo code to demonstrate what I'm doing.
while(thePortWatcherIsEnabled) { switchExpanderBoard(toNextPortThatIsDigital); Thread.Sleep(10); using (InputPort d = new InputPort(Pins.GPIO_PIN_A1, false, Port.ResistorMode.Disabled)) { d.Read(); } switchExpanderBoard(toNextPortThatIsAnalog); Thread.Sleep(10); using (AnalogInput a = new AnalogInput(Microsoft.SPOT.Hardware.Cpu.AnalogChannel.ANALOG_1)) { a.Read(); } switchExpanderBoard(toNextPortThatIsDigitalAgain); Thread.Sleep(10); using (OutputPort d = new OutputPort(Pins.GPIO_PIN_A1, false)) { d.Write(true); } }
After a few loops of this, the error as mentioned in the start post is thrown, and it continues throwing it at 'random' intervals (sometimes it works, most of the time it doesn't after the first exception is thrown).
