GO! Module - Potentiometer specs
Posted 30 November 2012 - 09:19 PM
Posted 30 November 2012 - 09:26 PM
The potentiometer module uses a Pro Audio-grade analog potentiometer. The ADC on the module's SAM8S chip then converts this to a 10-bit digital value (0-1023) which is then passed to the module driver on your mainboard.I was wondering if the Go Potentiometer is an actual analog potentiometer that I can measure its resistance in ohms or it is just a digital potentionmeter that returns values from 0 to 255?
Here is the exact part:
Bourns PTV09A-4020U-B103
Posted 30 November 2012 - 09:29 PM
If you see it from the code running on a netduino go it's a potmeter that returns a value from 0 to 1
If you see it from the GoBus socket on the module it's a digital potmeter that transfers it's state using the GoBus protocol over SPI.
If you look at the potmeter on the module, it's just an ordinary potmeter, and you can measure resistance, however this potmeter is connected to a STM8 micro controller, so measuring it's resistance does not make much sense.
- Ulrik Lunddahl
Posted 30 November 2012 - 10:06 PM
Posted 30 November 2012 - 10:12 PM
Giuliano,Thanks for your replies. So that said, if I am planning to use the Potentiometer as an analog potentiometer itself I would have to remove the chip first, right? I am also curious of the resitance of the potentiometer when in full open position. (Sorry no eletronic savvy)
Connecting to just the pot would be difficult and also waste a module why not just buy a potentiometer like the one that likely came with the LCD display (10K ohm) or Radio Shack has some larger ones that you can solder wires onto for a few bucks.
Chuck
Posted 30 November 2012 - 10:37 PM
Giuliano,
Chuck
Totally agree Chuck, no I am not waisting a Potentiometer module for that, I was just curious about the electronics.
Posted 01 December 2012 - 04:36 AM
I think then it's time for you to pick up a Netduino or Netduino Plus 2. They are better suited for arbitrary tinkering
Posted 20 November 2013 - 02:35 AM
Posted 13 December 2013 - 04:34 AM
Try "NetduinoGo.RgbLed" instead of "Netduino.RgbLed". Does that work? Also, be sure to add "NetduinoGo.RgbLed.dll" as a reference to your project (right-click on your project listing in Solution Explorer, select "Add references...". Finally, be sure that you created a "Netduino Go Application" rather than a "Netduino Application". That will pull GoBus into your project. Does that get you started? ChrisNetduino.RgbLed led = new Netduino.RgbLed(); Is giving me an error: The Name 'NetduinoGo' does not exist in the current context.
