Trouble flashing Netduino Mini
#1 George C
George C
Posted 26 November 2012 - 06:55 PM
Hi All, Having a bit of trouble flashing my Netduino Mini to 4.2.0.1. What I have done: 1) Reset the Mini by pushing 5V to the reset pad. 2) Flashed TinyBooterDecompressor.bin with SAM-BA This seems to work ok. If I flash the RS-232 version, then hook PUTTY up to the serial port, I get: TinyBooter v4.2.0.0 NetduinoMini Build Date: Sep 19 2012 19:39:48 ARM Compiler version 410894 MSdbgV1 ÿ׶-@Ó If I flash with the TTL version and try to connect to the TTL pins, I don't get anything back. Regardless, when I try to flash the firmware, I cannot ping the Netduino Mini with MFDeploy. I get "Error: No response from device." I've tried re-booting the Mini while pushing 5V to the DTR pin, without effect. I've tried the steps here http://forums.netdui...-netduino-mini/ but no luck. Any ideas?
#2 George C
George C
Posted 26 November 2012 - 11:18 PM
Bit of an update here... I was able to successfully flash. What I did: 1) Open MF Deploy 2) "Connect" to the COM port I was using (RS-232). 3) Select "Erase" 4) Flash new files as normal. I've flashed the TTL version of the firmware, and can confirm that I can connect via PuTTY. I see the framework components load. I've not flashed an application, but I would assume that will work. However, I still cannot ping the device. Whenever I try, I get "Error: No response from device." Am I doing something way wrong? What state does the device/MFDeploy need to be in in order to ping?
#3 Chris Walker
Posted 30 November 2012 - 09:34 AM
Hi George,
If you can deploy via MFDeploy, you should be able to ping the board.
If you deploy TTL firmware, the "pingable" port will be the TTL port (pins 11/12). Otherwise it'll remain on pins 1/2.
