Hardware watchdog on Netduino Plus
35 replies to this topic
#21 ToniA
ToniA
  • 40 posts
Posted 12 March 2013 - 08:18 AM
OK, I have been looking at the code, and my plan for fixing the MFDeploy issue is to use the onboard switch and led like this:
  • Short press on power-up -> onboard led lights up, then turns off -> watchdog disabled, CLR starts normally
  • Long press on power-up -> onboard led lights up, then blinks quickly a few times -> watchdog disabled, waits for firmware upload
  • No button press on power-up -> watchdog enabled, CLR starts normally
Additionally, I've been thinking how to feed the watchdog from the managed application side. If I introduce any new methods or properties etc. it means that all applications using those must also link with additional DLL's. I was thinking of this:
  • The CLR feeds the watchdog until the first time 'Watchdog.enabled = true' is called
  • After this, each call to 'Watchdog.enabled = true' would reset the watchdog counter and the CLR would not feed the watchdog any more
A bit ugly, but wouldn't require any extra DLL's. Now I just need to implement these :)
#22 Gavin G.
Gavin G.
  • 11 posts
Posted 12 March 2013 - 07:17 PM
What you said about [color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]feeding the watchdog from the managed application side. would probably provide a quick fix for the issues that I'm seeing in my setup.[/color]
[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]Setup:[/color]
  • Netduino plus works as a Client
  • Connects to locally hosted server application via TCP/IP socket communication
  • Once Netduino plus connects to server I use a GUI tied to the server to command and keep track of connections
Problem:
  • Once Netduino plus connects to the server, something causes the watchdog to kick in and reset the chip at set time intervals roughly 1 min 14 secs after the Netduino plus connects to the server.
  • Note 1: If I leave the Netduino there not connected the server the watchdog won't trigger a reset
  • ?Note 2: This doesn't happen with non custom firmware, with non custom firmware the problem comes from when I do something like manually disconnecting the Ethernet cable which causes it to hang.
What I wanted it do:
  • If there was ever a network disconnect for whatever reason (e.g. I unplug the Ethernet cable), if the Netduino plus couldn't resolve the socket connection to the server it would force a reset after a set time of hanging.
If some how you got the watchdog managed from the application side, I could kick it every X amount of seconds. Like you said ugly fix to the issue, but it will work until i can narrow down what's forcing the resets at set time intervals during connections.
Gavin G.
"The most important thing is to keep the most important thing the most important thing."
- From the book "Foundation design", by Coduto, Donald P.
#23 CW2
Posted 12 March 2013 - 07:30 PM
  It is also possible to add private fields and access them via reflection, in derived classes or extension methods. This has been done by Secret Labs for I2C (Custom_InternalAddress), SPI (Custom_BitsPerTransfer in ExtendedSpiConfiguration).
#24 OZ8ET
OZ8ET
  • 72 posts
  • LocationHundested, Denmark
Posted 16 March 2013 - 10:28 AM
There is a problem using the MF-Deploy tool to change Network configuration on NP Gen1 with this firmware.
It takes foreveer to get the Configuration window to show.
If I take power off-on, it shows.
#25 ToniA
ToniA
  • 40 posts
Posted 16 March 2013 - 12:06 PM
Yes, I noticed the same. Actually, I somehow got the firmware all messed up if I didn't follow this procedure:
  • You need to have the firmware deployed
  • Connect the Netduino Plus to USB while holding the onboard botton down
  • When you do a 'Ping' in MFDeploy, it should tell you it's running the tinybooter, not CLR
  • Now do the network setup
I already implemented the TinyBooter feature to react differently on short and long press on bootup, now I need to focus on the watchdog side. I also compiled the whole software with RVDS 4.1.
#26 OZ8ET
OZ8ET
  • 72 posts
Posted 17 March 2013 - 11:03 AM
Sorry - has the download a new bootloader? - if so when did you change it? is there any description on how to use?
Thanks again for your great work.
Erik
#27 ToniA
ToniA
  • 40 posts
Posted 17 March 2013 - 06:36 PM
Hi Erik, still working on it. I think I got it all done, but I need to do some more tests tomorrow evening. If I don't find any problems, I'll publish the binaries tomorrow.
#28 ToniA
ToniA
  • 40 posts
Posted 18 March 2013 - 04:48 PM
OK, here's my new 1-wire + watchdog firmware for Netduino Plus, based on official 4.2.0.1, with CW2's 1-wire, compiled with RVDS 4.1.
Flashing instructions:
    [*]Reset the NetduinoPlus by connecting 3.3V to the golden square
    [*]Disconnect and reconnect the USB
    [*]Install the TinyBooterDecompressor.bin with SAM-BA
    [*]Disconnect the USB cable and reconnect it while PRESSING AND HOLDING THE ONBOARD BUTTON until the onboard LED blinks quickly
    [*]Deploy the firmware using MFDeploy
    [*]Disconnect and reconnect the USB AGAIN while PRESSING AND HOLDING THE ONBOARD BUTTON until the onboard LED blinks quickly
    [*]Set the network configuration with MFDeploy
    [*]Disconnect and reconnect the USB (don't press the button), and you're done
    [/list]
    The Tinybooter has three modes:
    • Onboard button is not touched -> boot up with watchdog enabled
    • Press the onboard button while connecting the USB -> release the button after the LED turns off but before it starts blinking -> boot up with watchdog disabled -> can use MFDeploy to deploy large applications
    • Press and hold the onboard button while connecting the USB until the onboard LED first turns off and then blinks -> boots to TinyBooter for firmware upload and for setting the network configuration
    The watchdog also has three modes on the application
    • 'Watchdog.enabled' is not set in the program -> watchdog is active and is automatically fed by the CLR
    • 'Watchdog.enabled = false' -> watchdog is explicitly disabled -> same functionality as in the stock firmware
    • 'Watchdog.enabled = true' -> watchdog is explicitly enabled and cannot be disabled -> the watchdog must be fed by the application by calling 'Watchdog.enabled = true' periodically. If this is not done, or if the application crashes, a watchdog reset will happen
    A sample application
    • Please note that the watchdog is not active when connected to the debugger -> stop debugging and reconnect the USB
    • To verify the functionality, comment out the 'Watchdog.enabled' row in FeedWatchdog and see the board doing a reset after a short while
    using System;using System.Net;using System.Threading;using Microsoft.SPOT;using Microsoft.SPOT.Hardware;using SecretLabs.NETMF.Hardware;using SecretLabs.NETMF.Hardware.NetduinoPlus;namespace WatchdogDemo{    public class Program    {        static void FeedWatchdog(object o)        {            // Each time the watchdog is enabled, it's also fed            // This is a bit of a workaround, but at least it didn't            // require any interface changes            Watchdog.Enabled = true;        }        public static void Main()        {            OutputPort led = new OutputPort(Pins.ONBOARD_LED, false);            // When the watchdog is enabled, it also must be fed from the managed app            Watchdog.Enabled = true;            Timer WatchdogTimer = new Timer(new TimerCallback(FeedWatchdog), null, 1000, 1000);            while (true)            {                Thread.Sleep(50);                led.Write(!led.Read());            }        }    }}
    The firmware source code is here: https://github.com/T...tduino-watchdog
#29 OZ8ET
OZ8ET
  • 72 posts
Posted 18 March 2013 - 07:59 PM
Thank you Toni - great job!
Erik
#30 strent
strent
  • 34 posts
Posted 31 March 2013 - 12:33 AM
Latest version is much more stable, thanks ToniA!
Unfortunately my SD Card that worked fine in 4.1, doesn't work in 4.2 :(
Throws the Unsupported Exception in System.IO
#31 mohammad
mohammad
  • 79 posts
Posted 14 May 2013 - 07:47 PM
Is your SD card more than 2GB? The firmware 4.2 only knows the SD cards 2GB and 1GB.
#32 mohammad
mohammad
  • 79 posts
Posted 21 May 2013 - 11:46 PM
This might be useful for your watchdog prodecures: http://forums.netdui...-netduino-plus/ (although it is a software reboot).
#33 ToniA
ToniA
  • 40 posts
Posted 23 May 2013 - 01:15 PM
That's not a watchdog, it's a scheduled reboot.
have you tried out my firmware build? What are the problems you mention in the other thread ('I had a problem for 1 month to use a Watchdog mechanism in Netduino Plus') ?
#34 mohammad
mohammad
  • 79 posts
Posted 23 May 2013 - 07:39 PM
 You are right, so I should not consider them interchangeably.
No, since the firmware of your library was different from mine.
The watchdog problem :) to reboot the Netduino Plus after a specific time.
#35 CyberChris
CyberChris
Posted 18 August 2013 - 05:56 PM
Hello,
today I tried to flash my Netduino Puls with the 4.2.0 + CW2 OneWire. As it looks, the firmware is properly installed.
HalSystemInfo.halVersion:               4.2.0.0HalSystemInfo.halVendorInfo:            Netduino Plus (v4.2.0.1) by Secret Labs LLC [CW2 mod]HalSystemInfo.oemCode:                  34HalSystemInfo.modelCode:                177HalSystemInfo.skuCode:                  4097HalSystemInfo.moduleSerialNumber:       00000000000000000000000000000000HalSystemInfo.systemSerialNumber:       0000000000000000ClrInfo.clrVersion:                     4.2.0.0ClrInfo.clrVendorInfo:                  Netduino Plus (v4.2.0.1) by Secret Labs LLC [CW2 mod]ClrInfo.targetFrameworkVersion:         4.2.0.0SolutionReleaseInfo.solutionVersion:    4.2.0.0SolutionReleaseInfo.solutionVendorInfo: Netduino Plus (v4.2.0.1) by Secret Labs LLC [CW2 mod]SoftwareVersion.BuildDate:              Mar 15 2013SoftwareVersion.CompilerVersion:        410713FloatingPoint:                          TrueSourceLevelDebugging:                   TrueThreadCreateEx:                         TrueLCD.Width:                              0LCD.Height:                             0LCD.BitsPerPixel:                       0AppDomains:                             TrueExceptionFilters:                       TrueIncrementalDeployment:                  TrueSoftReboot:                             TrueProfiling:                              FalseProfilingAllocations:                   FalseProfilingCalls:                         FalseIsUnknown:                              False
DeviceInfo:  HAL build info: 4.2.0.0, Netduino Plus (v4.2.0.1) by Secret Labs LLC [CW2 mod]  OEM Product codes (vendor, model, SKU): 34, 177, 4097  Serial Numbers (module, system):    00000000000000000000000000000000    0000000000000000  Solution Build Info: 4.2.0.0, Netduino Plus (v4.2.0.1) by Secret Labs LLC [CW2 mod]  AppDomains:    default, id=1  Assemblies:    mscorlib,4.2.0.0    Microsoft.SPOT.Native,4.2.0.0    Microsoft.SPOT.Hardware,4.2.0.0    Microsoft.SPOT.Net,4.2.0.0    System,4.2.0.0    Microsoft.SPOT.Hardware.SerialPort,4.2.0.0    Microsoft.SPOT.IO,4.2.0.0    System.IO,4.2.0.0    Microsoft.SPOT.Hardware.PWM,4.2.0.1    Microsoft.SPOT.Hardware.OneWire,4.2.0.0    SecretLabs.NETMF.Diagnostics,4.2.0.0    SecretLabs.NETMF.Hardware.Netduino,4.2.1.0    SecretLabs.NETMF.Hardware.NetduinoPlus,4.2.2.0    OneWireTestApp,1.0.0.0    CW.NETMF.OneWire,1.0.0.0    SecretLabs.NETMF.Hardware,4.2.0.0
But CW2 sample application does not work. If I start it, using the Debugger I get an [font="arial, helvetica, sans-serif;"]'System.NotSupportedException' occurred in OneWireTestApp.exe'[/font]
when the follwing line is executed:
oneWire = new OneWire(Pins.GPIO_PIN_D8);
Any ideas what goes wrong here? For me it Looks as the CLR can't find the entrypoint for CW2 OneWire functions. But why?
#36 ToniA
ToniA
  • 40 posts
Posted 18 August 2013 - 06:10 PM
This is .NET Micro 4.2. You should use the native .NET Micro 1-wire interfaces. The low-level code is CW2's code.
