2 potentiometers
Posted 22 November 2012 - 09:45 AM
Posted 22 November 2012 - 01:13 PM
Andi,Hi All,
is it possible to use 2 potentiometers?
Im getting the following error:
"An unhandled exception of type 'System.ArgumentException' occurred in NetduinoGo.Potentiometer.dll"
on this last line
NetduinoGo.RgbLed led1 = new RgbLed(GoSockets.Socket1);
NetduinoGo.Potentiometer pot1 = new Potentiometer(GoSockets.Socket2);
-> NetduinoGo.Potentiometer pot2 = new Potentiometer(GoSockets.Socket6);
Maybe Im overlooking something obvious.
Ive tested different sockets.
Best wishes
Andi ;-)
Do you have a shieldbase plugged in also? If so it will still take up a channel (i.e. sockets 5 - 8).
Try moving the 2nd Pot to 3 or 4 instead.
I have 2 Pots, 1 RGBLed, 1 LCD display and a shieldbase (for TMP35 sensor input) connected to my Go with no problem.
The freeing of the sockets is coming soon, I think.
Chuck
Posted 22 November 2012 - 04:35 PM
Posted 23 November 2012 - 03:16 PM
Posted 23 November 2012 - 04:59 PM
Not sure what the status is, Did you get it working?
If not I will try to help but without knowing a little more information on what is connected to the Netduino Go and something about how you have written the code it is difficult to help correct the problem.
If you are not working on a super secret project, it would help to know:
- What modules you have plugged in and where.
- What references and firmware you are using.
- The code you are trying to run.
- It sounds like you have a shieldbase for the serial, which com port (you can't use com1 on pins D0 & D1 yet)
Chuck
Posted 23 November 2012 - 05:02 PM
What do you have on Port5? There is no Serial module for GoBus yet.Port5: serial comm serial serial serial
If you disable the GoBus channel (GoPorts 5-8) then you can use the UART pins on any of those ports directly. Otherwise they're reserved for GoBus.
Posted 27 November 2012 - 09:39 AM
Andi,
If you are not working on a super secret project, it would help to know:The more you can share the easier it is to help identify the problem. It will also help show others how to do something they may be looking for.
Chuck
Hi Chuck,
this are the 4 differenz port distributions I have used
Successful, Failing, Failing, Failing
Port1: LED, -, -, -
Port2: Poti1, Poti1, Poti1 ,Poti1
Port3: NWAZET, LCD, LCD, LCD
Port4: Poti2, LED, -, -
Port5: serial, comm, serial, serial,
Port6: -, -, -, LED
Port7: button, button, button, button
Port8: -, Poti2, LED, -
for
[*]What references and firmware you are using.
[*]The code you are trying to run.
[*]It sounds like you have a shieldbase for the serial, which com port (you can't use com1 on pins D0 & D1 yet)[/list]The more you can share the easier it is to help identify the problem. It will also help show others how to do something they may be looking for.
I will come back in the next days as I dont have my program currently in front of me ;-)
Cheers and thanks a lot for your help
Andi
Posted 27 November 2012 - 09:41 AM
Hi Andi,
I am using UART for serial comm on port 5. I assume I havent disabled the GoBus channel. Thats a great hint. Sorry for the stupid question, how can I do this?
Many thanks for helping out
Andi
Posted 27 November 2012 - 05:27 PM
Andi
Simply by using the UART you've disabled the other ports. Those pins are shared among all 4 ports. Same goes for ports 1-4 if you use the UART there you disable all of those ports as well.
Posted 28 November 2012 - 11:57 AM
Hi Arron,
great. Thanks for this important info!
As I need more than 5 ports, I would go now for the shield base, correct?
Andi ;-)
Posted 28 November 2012 - 01:57 PM
Hi Andi,
just a quick one.
As Im using more than 5 ports, and I would use the button module, is there any timeline for the GoBus Hub on the horizon?
Andi ;-)
Posted 30 November 2012 - 09:04 AM
Yes, that's a good strategy. The UARTs in the GoBus ports are there for reflashing modules. You can hack into them and use them if you're willing to give up GoBus--but for 99% of serial circumstances we do recommend using a GoBus module with a UART.As I need more than 5 ports, I would go now for the shield base, correct?
The Shield Base has 3 UARTs...so you should have lots of room to play
Posted 30 November 2012 - 09:05 AM
We're doing layout on the first GoBus hub hardware now. We're targeting the spring. There's lots of code and testing to do--and we want to make sure we give priority to the Ethernet and SD modules first.As Im using more than 5 ports, and I would use the button module, is there any timeline for the GoBus Hub on the horizon?
