I just got my netduino go and I was playing around a bit.
I think I destroyed it
If I plug in the device, I can hear the usb plug and unplug sound in approx. 1s interval in a infinite loop.
I think the last code I played around with, was something like this.
public static void Main() { var temp = PowerState.CurrentPowerLevel; var temp2 = PowerState.Uptime; PowerState.RebootDevice(true); }
If I try to deploy a empty solution like this, the usb plug sound disappears but VS2010 stuck at the state "Pepairing to deploy assemblies to the device."
public class Program { public static void Main() { } }
VS2010 Output
Create TS.
Loading start at 8056cd0, end 806dbf8
Assembly: mscorlib (4.2.0.0)
Assembly: System.IO (4.2.0.0)
Assembly: SecretLabs.NETMF.IO (4.2.0.0)
Attaching deployed file.
Assembly: NetduinoGo.Button (1.0.1.0)
Assembly: NetduinoGoApplication2 (1.0.0.0)
Assembly: SecretLabs.NETMF.Hardware (4.2.0.0)
Assembly: GoBus (1.0.0.0)
Assembly: SecretLabs.NETMF.Hardware.NetduinoGo (4.2.0.0)
Resolving.
Ready.
Found debugger!
Can anyone please help me!
Greetings
Daniel
