Non-reponsive Plus 2: bricking 2 of them now...
Posted 15 November 2012 - 07:33 AM
Posted 15 November 2012 - 09:16 AM
Posted 15 November 2012 - 05:18 PM
Posted 15 November 2012 - 06:55 PM
Just to verify...did you ERASE the board using STDFU Tester before reflashing it DFUSE Demo?In the two STMicro Tool (Tester and Demo), the board shows up fine and I can follow the firmware upgrading procedures without any problem. Also, verify was fine too. In MFDeploy, it can see the board under USB selection (though sometime needs to keep moving between available USB ports to make it shows up) but connect, ping, network, and checking device capabilities failed with no response from the board. Trying to deploy anything from VS 2010 gets a deployment failure.
After that, try rebooting your PC and then try to ping the board via MFDeploy one more time.
Are you running in a VM or anything? If the above fails, we may want to have you try manually switching to the MFUSB drivers.
Posted 15 November 2012 - 09:34 PM
Hi Ron,
Yes, I used STDFU Tester to erase and the DFUSE Demo to load the firmware and the fireware was from the pinned thread. I've rebooted multiple times including switching to my mlaptop instead but it does the same thing (not answering ping in MFDeploy).
How do I switch the driver manually?
--Ron
Posted 15 November 2012 - 09:46 PM
Here you go; please let me know how this works for you:How do I switch the driver manually?
http://forums.netdui...-mfusb-drivers/
Posted 16 November 2012 - 05:45 AM
Hi Ron,
Changing the driver, erasing, and reloading the firmware help. Both boards are now alive again. I will try to port my app next.
--Ron
Posted 17 November 2012 - 07:10 AM
--Ron
Removing references to PWM, Analog, and NetduinoPlus make porting app my from Plus to Plus2 works with all the ifdef code compiled in. I am going to switch from my own NTP code out to using TimeServer and hopes it works now.
This is great stuff my multi-thread websever is much more responsive to web browsers now.
Thanks for the improvement.
--Ron
Posted 17 November 2012 - 06:14 PM
Hi Ron,
Did you try running a "blinky" type app on either board first?
When deploying your existing application to Netduino Plus 2, you'll need to swap out the current hardware provider assembly (SecretLabs.NETMF.Hardware.NetduinoPlus.dll) for the new unified one (SecretLabs.NETMF.Hardware.Netduino.dll). And remove any references to the old AnalogInput and PWM classes. Otherwise NETMF will go a bit nuts with the pin conflicts.
Based on initial feedback, we're working on updates to those three assemblies as well...so that you can redeploy existing Netduino Plus 1 projects without any changes. These boards have radically different hardware than the first gen--but one of our major goals is to ensure smooth forward upgradeability.
About your bricked boards...they're most likely fine. They're tough little guys. Can you see them in DFUSE? Does the flashing verify properly? If so, please try rebooting your PC and then plugging them in again. And see if they show up in Device Manager and also in MFDeploy.
We'll help get you up on your feet here; I want to see your observatory run at full steam!
I'm having simmilar experinces and I can't see the board in DFUSE or in MFDeploy. I've also switched to the older USB drivers to no avail. Help! The Netduino Plus 2 never replices to a Ping after builing a project with the PWM library.
Geoffrey
Posted 18 November 2012 - 02:18 AM
Netduino Plus 2 uses .NET MF 4.2 with the new Microsoft.SPOT.Hardware.PWM classes, rather than the legacy SecretLabs PWM classes.I'm having simmilar experinces and I can't see the board in DFUSE or in MFDeploy. I've also switched to the older USB drivers to no avail. Help! The Netduino Plus 2 never replices to a Ping after builing a project with the PWM library.
That said...we know that legacy support is important to you, so we're working on an update which will enable using the legacy PWM classes. We're aiming to have them ready next weekend.
Are you holding down your Netduino Plus 2's pushbutton while plugging it in via USB...before looking in DFUSE? What does it show up in Device Manager as?
Sorry for the troubles; let's get you back up and running and then we'll get you a software update to enable legacy PWM code.
