Here is a video of it, and the code which follows.
http://youtu.be/wneXYjR5GEY?hd=1
using System; using System.Threading; using Microsoft.SPOT; using Microsoft.SPOT.Hardware; using SecretLabs.NETMF.Hardware; using SecretLabs.NETMF.Hardware.Netduino; namespace NetduinoApplication1 { public class Program { static InterruptPort button; static PWM motor = new PWM(Pins.GPIO_PIN_D6); static OutputPort led = new OutputPort(Pins.ONBOARD_LED, false); public static void Main() { // write your code here button = new InterruptPort(Pins.ONBOARD_SW1, true, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeBoth); button.OnInterrupt += new NativeEventHandler(button_OnInterrupt); Thread.Sleep(Timeout.Infinite); } static void button_OnInterrupt(uint data1, uint data2, DateTime time) { led.Write(data2 == 0); if (data2 == 0) { motor.SetDutyCycle(100); } else { motor.SetDutyCycle(0); } } } }
Here is the diagram
I would also like to thanks Chris, Oz, CW2, Denver(Not a member), and Bill.French.
Sincerely,
Cwbh
EDIT: Schematic (Sorry, my first time?):
