I just completed the investigation of the issue and here's what I have observed and my recommendations to move forward.
Congrats on your findings, and thank you for taking the time to write it all up and sharing it.
- Ulrik
![]() 4.2.1 with Nwazet DAQ and Touch Screen
Started by theTroll, Nov 11 2012 05:56 PM
63 replies to this topic
#41
Posted 12 November 2012 - 11:05 AM
Congrats on your findings, and thank you for taking the time to write it all up and sharing it. - Ulrik
#42
Posted 12 November 2012 - 04:12 PM
Tested the 10MHz fix for the DAQ and Touch Pad. They work great now. Quick find Fabian, thanks. Thanks for everyone working to find the problems. Now I am going to see if I can make my thermometer work.
tt.
#43
Posted 12 November 2012 - 05:21 PM
Hi Lunddahl,
Good questions. First, here's a link to the latest GoBus 1.5 spec: http://forums.netdui...ucing-gobus-15/ With GoBus SPI transport, the initial frame size is 18 bytes and CRC8. This allows a frame size up to 63 bytes. If you switch to CRC16, you can have a frame size of up to 16383 bytes. The hubs can handle SPI transport at up to 18 mbps. This is the maximum SPI speed of the STM32F0 microcontrollers. Normal communication will probably happen around 10mbps, which is still really fast, but we can tune this.
from page 2 of the spec: "No data stream interruptions: Up to 15 simultaneous outstanding frames per device, ACKs included with every frame" Frames as switched. Up to 15 frames can be sent to a device before the mainboard puts further frames to the device on hold. In most circumstances the mainboard will have received an ACK for the first frame long before then. But if your module is a few hubs down, for instance, you could bump up against this 15 frame limit. The 15 frames are also awesome for asynchronous which have some latency. GoBus modules use their /INT (/IRQ) pin to let the mainboard (or the hub they're plugged into, which sends the alert upstream) know that they have data to send. Chris
#44
Posted 12 November 2012 - 05:23 PM
Hi neslekkim,
We have netduino.codeplex.com. There is a CodePlex bug which is prohibiting us from uploading the latest firmware. It will be fixed by switching the CodePlex site to Git. We're working on it. In the meantime, we post the latest source on the Downloads page. 4.1.1 should be up soon. Chris
#45
Posted 12 November 2012 - 05:44 PM
ok, so that repo is actually alive?
"This CodePlex repository is being updated with .NET MF 4.2 beta sources. It will become an official repository a few weeks after the release of .NET Micro Framework v4.2 (expected in October 2011)."
The last commit also seems to be from august 2011?
I think I discarded it due to that, and due to no folder for Netduino Go.
But this will be very good if you start using it properly, that should be of good use for the rest of us. (is this supposed to be complete, or things to be merged with the official .netmf code?)
#46
Posted 12 November 2012 - 05:47 PM We've been trying to upload the full repo for about a year, but CodePlex (using Hg) crashes on large uploads. One of our community members (nakchak) has built a new repo using Git and it seems to work well. Once we get through any required bugfixes for the new 4.2.1 release we'll be coordinating with Microsoft to switch the repo over. I'm really looking forward to it. Chris
#47
Posted 12 November 2012 - 05:50 PM
Ah, but the plan is to actually use this repo actively also?, not something that is going to be updated like now an then?
Hm, I thought Hg was kinda good on big uploads?, I'm using Svn here, and svn doesnt like big uploads/downloads so much.
But Git is maybe better anyway, if people is not complaining about tooling
#48
Posted 12 November 2012 - 08:04 PM
I'm very familiar with the complexity of the ARM Cortex clock tree and I know how easy it is to mis-configure a peripheral's clock divider / pre-scaler. Per your request, I have attached two Logic captures running on firmware 4.2.1, with the SPI bus (socket 5) configured at 10Mhz and 5Mhz respectively. As you can see, the SPI clock frequency is half of what it should be, which explains the regression. This did not happen with firmware 4.2.0 where the actual SPI clock frequency matched the frequency requested by the application (give or take the rounding delta introduced by the configuration of the peripheral's divider / pre-scaler). You should be able to reproduce my findings and do regression-testing on your own ARM-based modules (SD, Ethernet and ShieldBase), assuming that they are configured to use the SPI buses on the Go at frequencies above 16MHz. Regarding GoBus: adaptive bus speed negotiation will be useful when dealing with runtime bandwidth issues. However this 4.2.1 firmware bug would impact GoBus just the same because it affects the configuration of the ARM Cortex clock tree for the SPI peripheral, systematically cutting the maximum frequency in half. I certainly look forward to your native reference implementation of GoBus 1.x+. While we wait for a firmware revision addressing this SPI frequency regression, we'll document the mitigation on our site. -Fabien. Attached Files
#49
Posted 13 November 2012 - 03:54 PM
Since this is already a discussion about the nwazet products, and Fabien is active in this topic:
Does the nwazet display module, have some sort of response/idle timing between executing commands? It seems to me, that it often, doesn't do the Execute(), even through its told to do so, if two update cycles runs immediately after each other.
Currently it happends during the my initializing-phaze, where I want to show a progressbar showing the progress step by step.
It changes from load to load, even without any codechanges. But it seems to be having something to do with updating to frequently.
Note: It happends with both 4.2.0.* and 4.2.1.0 firmware. The SPI is running at 10 MHz.
ntools
#50
Posted 13 November 2012 - 04:58 PM
I might be able to help, mainly because I broke stuff on mine. Are you doing any of this in multiple threads?
#51
Posted 13 November 2012 - 05:06 PM
There's multiple threads running, and after it's completely initialized, worker threads can call Screen updates if needed. But at the initilization-process, only the main thread is calling the screen. ntools
#52
Posted 13 November 2012 - 05:32 PM
What was causing my problem is that I had two threads trying to talk to the device at one time. Very bad. You might want to make sure that you are not somehow sending multiple commands to the hardware before the other command is finished. Beside that I would have to see your code and test it.
#53
Posted 13 November 2012 - 05:55 PM
Yeah, thats why I was wondering, if it had some responsetime or something. Couldn't find anything about it on the nwazet site.
Sure, I'll post some code when I get home. I don´t have it here at the moment. ntools
#54
Posted 13 November 2012 - 08:45 PM
Hi Nicky.
The VirtualCanvas class interfacing with the Touch Display hardware abstracts away the communication details, which is a good thing. However, the communication is still taking place over shared hardware resources: in this case, an SPI channel and an interrupt port for signaling readiness / command completion. If multiple execution threads need to access the shared hardware resources, they must be synchronized and serialized. Various methods can be used to synchronize threads on the .Net MF such as the lock(object) {} statement, event objects such as ManualResetEvent() and implementing a work queue to serialize hardware access requests. To simplify the design, improve application performance and reliability, I'd recommend dedicating a single thread to the management of the display and handling touch events. What I'm describing here is true of any shared resource and in the context of a microcontroller, where there's no OS to queue I/O requests of behalf of application threads, it's up to the developer to orchestrate the show. I hope this helps clarifying things a bit. Cheers, -Fabien.
#55
Posted 14 November 2012 - 04:50 PM
Thanks for the answer Fabien.
I have no excuse for my stupidity here - I've forgot to make the code threadsafe.
Two quick questions:
a. Can the nwazet screen be replaced?
b. Is it normal that the screen flickers when it updates?
ntools
#56
Posted 14 November 2012 - 05:09 PM
Hi Nicky,
No worries
#57
Posted 14 November 2012 - 05:19 PM
Ah that wasn't exactly what I meant.. it's the yellow screen when it initializes i was referring to ![]()
Ah I see.. and this is the case for all Go Modules, right? ntools
#58
Posted 14 November 2012 - 05:46 PM Sorry, I misunderstood you. It can be replaced by recompiling the module's firmware with your own. You can do it using a variety of tool chains on Windows, Linux, Mac. I use IAR WorkBench but OpenOCD works too. You can then reflash the module serially using ST's own Windows utilities or if you're under Linux, a bunch of STLinkv2 alternatives such as http://code.google.com/p/qstlink2/ among others.
Yes, the SPI latency aspect is unavoidable with Go modules: it's akin to sending a network packet from one computer to another. In the case of the touch display, the packet size is fixed at 8KB to accommodate sending bitmaps relatively quickly. Depending on your main scenario, you could change the default 8KB packet size to something smaller to reduce latency (that requires a firmware change too btw). What happens on the module itself with that packet is yet another story... A good strategy to help reduce flickering during screen updates is to only update the zones of the screen that need to be refreshed. That will reduce the amount of data that needs to be processed each time. I hope this helps. Cheers, -Fabien.
#59
Posted 14 November 2012 - 06:07 PM
Thank you for your answers. In this case, it would mean to the Netduino is rendering a bitmap, and then sends it to the module, which updates it immediately?
For research purpose only: If need, would it be possible to order a batch of screens with custom logos?
ntools
#60
Posted 14 November 2012 - 06:17 PM
Yes, same method used today for rendering bitmaps. Just keep in mind that bitmaps get quite large at 16-bit / pixel and will eat up your flash / RAM in a hurry ![]()
Yup, it would be possible. You should email me at contact <at> nwazet <dot> com to discuss the details. Cheers, -Fabien. 1 user(s) are reading this topic0 members, 1 guests, 0 anonymous users | ||||||||||||||
