Steps to restore an Erased Netduino
#21
Posted 29 September 2010 - 09:55 PM
#22
Posted 29 September 2010 - 10:04 PM
URL its sending me to: http://forums.netdui...e-v410-patch-1/
Here's the latest firmware:
http://forums.netdui...e-v410-patch-3/
Posted 29 September 2010 - 10:05 PM
#24
Posted 29 September 2010 - 11:00 PM
#25
Posted 30 September 2010 - 05:31 PM
#26
Posted 30 September 2010 - 10:31 PM
#27
Posted 30 September 2010 - 10:43 PM
3) Load the ATMEL SAM-BA app.
- enable boot from flash.
- enable flash access.
- Send File (TinyBooterDecompressor.bin)
- NO to "Do you want to lock involved regions."
4)Unplug and replug of USB it now shows up as Netduino. Woohoo I think this is good..
- The LED still stays on.
- I try to ping no luck... hangs over time, never comes back.. have to kill app.
- I select ER_CONFIG and ER_FLASH..
- Deploy... Same thing, app hangs/never reports anything, I have to kill in task manager.
Hi Shane,
Wait two seconds before clicking "NO' to the "want to lock regions?" question. Then, add two zeros to the "compare bytes" value--and verify that the bootloader was flashed correctly.
After that, unplug and replug your Netduino. If you press PING in MFDeploy, it _should_ say "Pinging...TinyBooter | Netduino by Secret Labs". If it doesn't, please PM me with a way to contact you and we'll get you up and running. If it turns out to be a defect of some sort, we can replace it for you.
Posted 01 October 2010 - 07:19 PM
Thanks for the help! It's nice to see you guys are responsive and helpful, gives me even more hope for the development and success of the product, woohoo!
OK so I think I did the adding two zeros thing right in SAM-BA.(see screen shot)
- I then disconnected and reconnected the netduino.
- Opened MFDeploy.exe
- Selected netduino under USB.
- Ping.... (No dice)
- MFDeploy seems to hang but in Task manager it dose not state "not responding" if I let it set for about 20 min it will come back that it can not ping..
Note: I m now loading all the tools on another PC, who know maybe my MFDeploy or USB drivers are jacked...
-Will report my findings-
Shane
#29
Posted 01 October 2010 - 07:23 PM
#30
Posted 01 October 2010 - 09:32 PM
#31
Posted 03 February 2011 - 01:21 AM
In case it's helpful:
3. (**WARNING.. no turning back after this point.) Using a jumper, Connect the 3V3 power header to the ERASE pin (gold pad directly underneath digital pin 0) for about 2-3 seconds. After doing this, disconnect the Netduino from your PC.
5. Run SAM-BA. Select the COM port that your device is connected to. In my case this was COM4. Select AT91SAM7X512-ex from the dropdown.
for step 3, here's a pic of the erase pad on my netduino plus:
and for step 5, did not have AT91SAM7X512-ex, but a -ek, so I picked that and it seemed to work fine.
#32
Posted 17 February 2011 - 05:53 AM
#33
Posted 24 April 2011 - 05:35 PM
#34
Posted 09 June 2011 - 12:21 PM
#35
Posted 09 June 2011 - 01:01 PM
It can take some time. Also, I've read people having troubles on 64-bit machines. Any chance you can try a 32-bit machine?What if, once selected port and device type and pressed "connect" samba window disappears, process is still running, but nothing moves ?
Screw it, I', thru it
#36
Posted 12 July 2011 - 08:05 PM
Didn't notice the reply.
I managed using xp VM with Windows Xp Mode.
#37
Posted 13 July 2011 - 08:28 AM
In that mode the driver is still loaded in the 64-bit environment, which is the actual problem.Didn't notice the reply.
I wrote an article about the driver in Windows 7 x64, how I got it working, perhaps it helps?
http://wiki.netduino...y-Netduino.ashx
