4.2.0.0 one-wire
Posted 06 November 2012 - 05:51 PM
Posted 06 November 2012 - 05:58 PM
Posted 06 November 2012 - 05:59 PM
Posted 10 November 2012 - 12:27 AM
Posted 10 November 2012 - 12:46 AM
What version is the firmware with native support which I assume will not fit on a first gen Netduino Plus?
The firmware on the Netduino Plus 2 is incompatable with the first gen Netdunio Plus.
Posted 10 November 2012 - 01:02 AM
To add to what KodeDaemon said...Chris, when you wrote that post a few days ago was it before Netduino Plus 2 was released? From the release notes it looks like then Plus 2 will support native Onewire out of the box?? "And because there's so much room in flash, we've added OneWire and Time Server directly into the NETMF firmware. We've left quite a bit of space for future features. " What version is the firmware with native support which I assume will not fit on a first gen Netduino Plus?
There are only a few KB of flash left on the original Netduino Plus, so we have to reduce the size of the code deployment sector to fit OneWire on there.
With Netduino Plus 2, there is over 100KB of extra space left for firmware features (and 384KB for your code on top of that). So we were able to add the NETMF OneWire feature there without any problems.
We're going to create a special build of NETMF 4.2 with OneWire for the original Netduino Plus. We'd like to wait a week or so and make sure OneWire is working properly on Netduino Plus 2 first, as it is really really hard to debug on Netduino Plus 1 if OneWire runs into any troubles.
Posted 13 January 2013 - 04:18 PM
Hello - any news here? I've moved towards 4.2 version for my NetDuino, but did not expect that one of the most used feature - OneWire - would be missing. If there is no chance to have iot back in 4.2 (either special build or standaerd build) - there is no other possibility than to rollback to 4.1
Posted 13 January 2013 - 05:30 PM
Posted 19 January 2013 - 02:48 PM
Any update on this, i'll love to use OneWire on NP1.
Is it a solution for u guys to build the OneWire as a seperate DLL and save that on the SD card and load it ?
Posted 29 January 2013 - 09:27 PM
Small update regarding downgrade to 4.1.0.6 (special 1-wire build). Seems like it is not the option for me, I've converted the project to MF 4.1 (had my netduino flashed with tinybootloader 4.1, also flashed with 4.1.0.6 firmware) and how surprised I was to see, that tiny-essential line of code fetching IP address to print out on console - generates an Exception:
Debug.Write("IP: " + Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces()[0].IPAddress.ToString());
No matter if I used DHCP option as before or set the static IP address.
Removing all the references and bringing them back in 4.1 version changed nothing.
