Hi.
This is Kevin.
I am now trying to port .net mf 4.3 for hardware soldered with AT91SAM7X512.
My Step to try are follows
1. To install .net mf 4.3 SDK & .net mf porting kit 4.3. : To make sure the installation of .net framework 3.5, 4.0, and 4.5.
2. After that, I open the porting kit with basename "AT91SAM7X", CPU "AT91SAM7X", Debug "USART", Memory="Minimum", Address already had the value for AT91SAM7X.
3. I also open another copy clone to follow with Netduino Plus.
4. I check same or similar HAL, PAL and Library for TinyCLR, and Bootloader such as TinyBooter and PortBooter on my AT91SAM7X
5. After checking, I make the code for AT91SAM7X by Porting Kit 4.3.
6. To Run Command "msbuild /t:build /p:flavor=release;tcp_ip_stack=lwip /v:m /m" with RVDS 4.0 Compiler.
7. I encounter the error such as "there is no symbol "PORT" or look like Type mismatch with RVDS 4.0 Compiler with source which was generated by Porting Kit 4.3
Question.
1. Is there any method to clear above mentioned?
2. I think there is document to describe how to make port with example to follow. where is it now?
Thanks.
Regards
Kevin Page
To port for hardware of AT91SAM7X512
Started by yiulsup, Oct 24 2012 11:42 PM
No replies to this topic
