new AnalogInput() throws ArgumentException
#1 Nicky
Nicky
  • 78 posts
  • LocationDenmark
Posted 15 October 2012 - 07:56 AM
Hi
I have problem creating an AnalogInput on the Shieldbase...
using AnalogInput = SecretLabs.NETMF.Hardware.AnalogInput;
namespace MyNamespace
    public class MyClass : MyBaseClass
        private AnalogInput input;
        public MyClass(NetduinoGo.ShieldBase shieldbase)
            : base(shieldbase)
            this.input = new AnalogInput(this.shieldbase.Pins.GPIO_PIN_A0);
The abowe throws ArgumentException. The code is exceuted immediately after another instace of "MyClass" is created with digital pins. The Pin has value 1014.
Running Netduino Go firmware 4.0.0.2.
Thanks in adavance ;)
ntools
http://ntools.codeplex.com/
#2 Nevyn
Nevyn
  • 1072 posts
  • LocationNorth Yorkshire, UK
Posted 15 October 2012 - 08:24 AM
You can only grab hold of a pin once. So the second instance of MyClass will fail as the first instance is still referencing A0.
#3 Nicky
Nicky
  • 78 posts
  • LocationDenmark
Posted 15 October 2012 - 08:28 AM
Hi Mark
Thanks, but it's not.. I've simplified the code by removing parameters and replaced pin variable with actual value.
ntools
#4 Chris Walker
Posted 15 October 2012 - 09:19 AM
Hi Nicky, Are you okay with switching to the new NETMF AnalogInput class? Then instead of the shieldBase.Pins enumeration, you can use the shieldBase.AnalogChannels enumeration.
#5 Nicky
Nicky
  • 78 posts
  • LocationDenmark
Posted 15 October 2012 - 09:27 AM
Hi Nicky,
Nice! Works like a charm!
I actually tried using it, and deleted the using AnalogInput in the top, but apparently VS didn't change the reference. using AnalogInput = Microsoft.SPOT.Hardware.AnalogInput did the magic.
ntools
