ADC Question / Issue
8 replies to this topic
#1 QuantumPhysGuy
QuantumPhysGuy
  • 30 posts
  • LocationKentucky, USA
Posted 14 October 2012 - 02:49 AM
I am trying to get a reading from a TMP36 temperature sensor from my Netduino Go. I currently have my breadboard setup where I see the reading from the TMP36 on my multimeter and also have the signal sent to the NGO.
One thing I am noticing right off is the difference from the voltage my multimeter is reading versus the NGO. Currently my multimeter is showing 0.72V coming from the TMP36, but my NGO is showing 0.685v - 0.690v.
Here is my conversion for the ADC:
ShieldBase shieldBase = new ShieldBase(GoSockets.Socket8);
AnalogInput aiTemp = new AnalogInput(shieldBase.AnalogChannels.ANALOG_PIN_A0);
Double dVolts = aiTemp.Read() * (3300 / 1024F);
So you can see when I do the math to convert the volt reading to degrees I am coming up with not so acurate readings. Using the multimeter the temp would be 22° C which is correct for the room I am in, but the NGO shows ~66° C.
Does anyone have any tips on this?
Posted 14 October 2012 - 02:54 AM
Hi QuantumPhysGuy,
What voltage are you measuring on the 3V3 header of your Shield Base?
Also, just curious: why multiply by 3300 and then divide by 1024?
#3 QuantumPhysGuy
QuantumPhysGuy
  • 30 posts
Posted 14 October 2012 - 02:57 AM
Hi QuantumPhysGuy,
Voltage is showing 3.35.
I was doing that to account for the 3.3V and also the bits from the ADC. Is that not correct?
#4 QuantumPhysGuy
QuantumPhysGuy
  • 30 posts
Posted 14 October 2012 - 03:00 AM
Here is something odd, once I removed the terminal and jumper wires I had on the breadboard the readouts from the NGO went to normal and they are close to what my multimeter said by about ~0.01 volts... Is it possible it was causing "noise" on the ADC?
#5 Gutworks
Gutworks
  • 363 posts
  • LocationOttawa, Ontario
Posted 14 October 2012 - 03:27 AM
Hi QuantumPhysGuy,
You may have found some sample code for this sensor that was written using the 4.1 .Net MF. The 4.2 .Net MF has introduced some changes to the AnalogInput class. The Read() function in 4.2 behaves much differently than it's predecessor, and it now returns a value between 0.0 and 0.9999, which technically provides you with better precision. The shield base is also using a 12 bit ADC unlike the Netduino Plus which is 10 bit. The old Read() returned the raw AD value, a number between 0-1023, and so if you wanted to replicate this value you can use the new to 4.2 ReadRaw() function. The ReadRaw() will return a value in the range of 0-4095.
If you read this post over, you will see some of the work carb has done using this sensor and a Touch Display. A little further down I converted his sample to C#. Hopefully you can find a couple hints or useful snippets to help you along the way, such as the formula used and a way to average the sample to filter out some of the ADC noise.
Cheers,
Steve
#6 QuantumPhysGuy
QuantumPhysGuy
  • 30 posts
Posted 14 October 2012 - 03:44 AM
Hi QuantumPhysGuy,
Cheers,
Steve
Thanks! That makes much more sense. The sample I was looking at was from the 2010-2011 time frame.
#7 QuantumPhysGuy
QuantumPhysGuy
  • 30 posts
Posted 14 October 2012 - 03:56 AM
Ok, now that I made the change. My readings are off by 3.5°. Here is my code:
    	private static AnalogInput aiTemp;
        	SevenSegmentDisplay ssDisplay = new SevenSegmentDisplay(GoSockets.Socket2);
        	Double dTemp;
            	dTemp = GetAverageTemperature() * 9 / 5 + 32;
            	ssDisplay.SetValue(dTemp.ToString("N1") + "F");
            	Thread.Sleep(1500);
    	private static Double GetAverageTemperature()
        	Double dTotalTemp = 0;
        	Double dAverageTemp;
        	for (Int32 i = 0; i <= 19; i++)
            	dTotalTemp += GetTemperature(aiTemp.Read());
            	Thread.Sleep(50);
        	dAverageTemp = dTotalTemp / 20;
        	return dAverageTemp;
    	private static Double GetTemperature(Double dReadValue)
        	Double voltage = dReadValue * 3.3;
        	Double temp = voltage - 0.5;
        	return temp * 100;
Suggestions?
#8 QuantumPhysGuy
QuantumPhysGuy
  • 30 posts
Posted 14 October 2012 - 03:59 AM
Suggestions?
Maybe I should check circuits before asking questions.
I added a 0.1uF ceramic disk capacitor on the out pin of the TMP36 and my readings match the multimeter...
Thanks for the help Chris and Gutworks.
#9 Geancarlo2
Geancarlo2
  • 70 posts
Posted 14 October 2012 - 05:55 AM
In any case, if you still have problems you can use linear regression for calibration.
