TristatePort Issue
19 replies to this topic
#1 QuantumPhysGuy
QuantumPhysGuy
  • 30 posts
  • LocationKentucky, USA
Posted 09 October 2012 - 12:16 AM
I am trying to get the Parallax Ping))) Sensor working with the Netduino GO and the Shield Base. I am using the Ping class that was created by afulki which can be found here.
Whenever I try to run the code I get an error that states:
An unhandled exception of type 'System.Exception' occurred in GoBusSerialTransport.dll
This is my Program.cs:
            ShieldBase shieldbase = new ShieldBase(GoSockets.Socket1);
            Thread.Sleep(5000);
            ParallaxSensors.Ping pPing = new ParallaxSensors.Ping(shieldbase.Pins.GPIO_PIN_D5, 1000, true);
            pPing.RangeEvent += new ParallaxSensors.Ping.RangeTakenDelegate(pPing_RangeEvent);
        public static void pPing_RangeEvent(object sender, ParallaxSensors.PingEventArgs e)
            Debug.Print("Range: " + e.Distance + " cm");
It seems to be failing on line 72 of the code posted by afulki, but I can't figure out why.
_port = new TristatePort(pin, false, false, ResistorModes.Disabled);
This is the stack trace information for the error:
Exception was thrown: System.Exception
GoBus.GoBusSerialTransport::CallFunction
NetduinoGo.ShieldBase::CreateTristatePort
System.Reflection.MethodBase::Invoke
Microsoft.SPOT.Hardware.TristatePort::.ctor
PINGSensor.Program::Main
Does anyone have any ideas?
Edited by QuantumPhysGuy, 09 October 2012 - 12:19 AM.
#2 QuantumPhysGuy
QuantumPhysGuy
  • 30 posts
Posted 10 October 2012 - 03:33 AM
I have narrowed it down a bit. It appears what is actually failing is the GoBus.GoBusSerialTransport.CallFunction.
I finally tracked the exception down to line 1098 of GoBusSerialTransport.cs but not 100% sure why it threw an exception.
Line 1098:
if (functionResponse.Exception != null)
throw functionResponse.Exception;
Any ideas?
#3 Chris Walker
Posted 10 October 2012 - 03:42 AM
Hi QuantumPhysGuy, Is the pin being used already, by any chance? We're passing exceptions via GoBus--but only the root Exception class. We'll be adding the others soon as well so you can get full exception details. If you create a TristatePort for that pin directly from your code...do you also get the exception? Chris
#4 QuantumPhysGuy
QuantumPhysGuy
  • 30 posts
Posted 10 October 2012 - 03:44 AM
Hi QuantumPhysGuy,
D5 isn't being used except for trying to create the TristatePort.
Currently this throws the same exception:
TristatePort _port = new TristatePort(shieldbase.Pins.GPIO_PIN_D5, false, false, ResistorModes.Disabled);
#5 Chris Walker
Posted 10 October 2012 - 03:50 AM
Okay, that's very interesting. This is with beta 4?
If you create it as an InputPort do you get the same issue?
#6 QuantumPhysGuy
QuantumPhysGuy
  • 30 posts
Posted 10 October 2012 - 03:59 AM
Yes this is with beta 4, but I was having this same problem with beta 3. The below code worked without error:
InputPort ipPort = new InputPort(shieldbase.Pins.GPIO_PIN_D5, false, Port.ResistorMode.Disabled);
#7 Chris Walker
Posted 10 October 2012 - 04:28 AM
Okay, we may have introduced a bug with TristatePort with the GoBus 1.5 transition. I know we tested it but I will check our test code to see what we missed... Chris
#8 Nicky
Nicky
  • 78 posts
  • LocationDenmark
Posted 16 October 2012 - 08:35 AM
I get nearly the same error: this.portOut = new TristatePort(this.pinOut, true, false, Port.ResistorMode.Disabled); Throws System.Exception in GoBusSerialTransport.dll Callstack: GoBusSerialTransport.dll!GoBus.Utility.CRC8.SendDataPacket Line 1009 + 0xcf bytes NetduinoGo.ShieldBase.dll!NetduinoGo.ShieldBase.CreateTristatePort(Microsoft.SPOT.Hardware.Cpu.Pin portId, bool initialState, bool glitchFilter, Microsoft.SPOT.Hardware.Port.ResistorMode resistor) Line 316 + 0x5d bytes [External Code] MyCode The line that throws exception is the closing bracket in SendDataPacket... And this time I checked the dll-versions: Shieldbase Beta 4 GoBusSerialTransport 1.4.1.0 NetduinoGo.Shieldbase 0.3.0.0 GoBus 1.0 Running .NET MF 4.2 QFE2 edit: The pin is not in use. I've tried several different pins - D6, D7, D11, D12 to be specific. edit 2: It's the same scenario when I have nothing else initlialized on the Shieldbase.
ntools
http://ntools.codeplex.com/
#9 halobox
halobox
  • 5 posts
  • LocationEurope, Germany
Posted 30 December 2012 - 10:16 PM
Is there any workaround available for this bug right now? Perhaps any kind of beta library?
Greetings halobox
#10 halobox
halobox
  • 5 posts
Posted 15 January 2013 - 07:57 PM
Is there any news to this bug?
Regards
halobox
#11 Lunddahl
Lunddahl
  • 152 posts
  • LocationEurope, Denmark
Posted 16 January 2013 - 07:08 PM
Is it still there with ShieldBase Beta5 ?
#12 halobox
halobox
  • 5 posts
Posted 16 January 2013 - 07:53 PM
Yes it is.
halobox
#13 eplaksienko
eplaksienko
  • 112 posts
Posted 03 May 2013 - 02:12 PM
Chris any news about it?
#14 Chris Walker
Posted 03 May 2013 - 04:54 PM
Hi eplaksienko, No resolution on this one quiet yet. This is in our issue tracking system and on the list but hasn't made it all the way to the top quite yet. Chris
#15 eplaksienko
eplaksienko
  • 112 posts
Posted 03 May 2013 - 06:10 PM
Chris, is it related to the issue with can not dispose OutportPort?
#16 cgoss
cgoss
Posted 11 May 2013 - 06:43 AM
Chris, do you have any idea on when this will be worked on? I have a DHT22 and DHT11 that I am using the Tristate port to communicate with the device on.
Is there another alternative avalible?
Thanks in advance.
#17 Arron Chapman
Arron Chapman
  • 289 posts
  • LocationOregon, USA
Posted 15 May 2013 - 12:20 AM
Greetings halobox
Regards
halobox
Thanks in advance.
I'm sure that the second there is a solution Chris will post about it, until then probing him for updates simply requires him to spend time answering you rather than working to solve the problem.
If your needs are pressing I'd like to suggest you have a look at either Netduino, Netduino 2, Netduino Plus, Netduino Plus 2, Netduino Mini or perhaps the ProtoModule.
Let me also take this opportunity to remind you all that the Shield Base is a beta product, and clearly labeled as such, don't expect it to work 100% until such time as it is no longer Beta.
#18 Chris Walker
Posted 15 May 2013 - 12:31 AM
Thanks in advance.
Hi cgoss,
I'm not by my Shield Base at the moment, but what happens if you create an OutputPort and Dispose it and then create an InputPort when you need to switch (and vice-versa)?
This is near the top of our bugfix list.  We're working our way to it, and if anyone else wants to attack it we can pull in that fix...
#19 eplaksienko
eplaksienko
  • 112 posts
Posted 15 May 2013 - 01:35 AM
Chris I personally first tried to dispose OutputPort with the exception, then I tried to use TristatePort, and get the same kind of unknown exception. I am just trying to play with CharliePlexing
#20 eplaksienko
eplaksienko
  • 112 posts
Posted 12 June 2013 - 02:25 PM
Chris, any updates on this issue?
