Trying to get VS2012 Pro working
9 replies to this topic
#1 John Feeney
John Feeney
  • 55 posts
  • LocationAuburn, ON, Canada
Posted 28 September 2012 - 02:35 AM
I have VS2010 Professional and I have had the NetduinoPlus template working for some time. Today I installed VS2012 Professional without taking VS2010 off my computer (both are on my machine). When I first opened VS2012 there is no Micro Net Framework templates under the Visual C# New projects templates. I tried rerunning the NetduinoPlus sdk but nothing happeded. I then found that under MyDocuments there is a folder called Visaul Studio 2010 and another folder called Visual Studio 2012. A subfolder of these is another folder called templates. Inside Visual Studio 2010 templates was a folder called Micro Framework and had a NetduinoPlus template in it. I copied the folder from Visual Studio 2010 to Visual Studio 2012. When I opened a new project in Visual Studio 2012 from the (copied) NetduinoPlus template I got the error message that is: The project file 'c:\Users\John\AppData\Local\Temp\bcwvmcqi.3zi\Temp\NetduinoPlusApplication1.csproj' canot be opened. There is a missing project subtype. Subtype: '{b69e3092-b931-443c-abe7-7e7b65fa37f} is unsupported by this installation Can anyone help with how to install the NetduinoPlus templates into the Visual 2012 without having to take Visual Studio 2010 off my machine. Thanks John
#2 Anthony Glenwright
Anthony Glenwright
  • 71 posts
Posted 28 September 2012 - 03:43 AM
Assuming that your missing templates & error message are happening because VS2012 wasn't installed when you installed the micro framework & netduino SDK, have you tried re-installing the micro framework and netduino SDKs (or if they have a "repair" option, try that)?
#3 supra
supra
  • 210 posts
  • LocationOntario, Canada
Posted 28 September 2012 - 03:49 AM
@Feeney
Here is link:
myLink
Netduino will be released 4.3 after window 8 and vs2012 will be coming this October or November.
Hopefully Netduino 4.3 coming December or January 2013
We will be waiting for announcement by Chris.
#4 John Feeney
John Feeney
  • 55 posts
Posted 28 September 2012 - 02:02 PM
So I guess the final answer is to leave VS 2010 installed and wait until later this year for Micro 4.3 and Netudino install update to be able to run on VS 2012. John
#5 Coyttl
Coyttl
  • 61 posts
  • LocationSilver Spring, MD, USA
Posted 28 September 2012 - 02:46 PM
Go into your VS2010 folder (by default My Documents\Visual Studio 2010) and then go into \Templates\ProjectTemplates\C# copy the "Micro Framework" directory to the same directory in your My Documents\Visual Studio 2012 directory. You should be then good to go. :) I'm not 100% sure about the location of the VS2012 'My Documents' directory, since I haven't upgraded mine yet (work requirements) but it's extremely likely that VS2012 doesn't use the same templates directory as VS2010, so you'll have to copy them over manually. --Me.
#6 John Feeney
John Feeney
  • 55 posts
Posted 29 September 2012 - 01:15 AM
--Me.
Hi Coytti
If you look at my original questiona at the top .... that is what I did. I copied the templates from VS2010 to VS2012. So I can select the NetduinoPlus template. But when it goes to open then I get the error.
Either a registery issue or .Net Micro 4.1/4.2 want work with 2012.....I now think it is the latter of those two.
John
#7 Coyttl
Coyttl
  • 61 posts
Posted 29 September 2012 - 02:24 AM
D'oh! Sorry about that - I missed that, somehow when I read it I skipped over that and only read the part about getting the error. Shoot - was hoping that was the cause, I like easy fixes. :(
#8 not4now
not4now
  • 12 posts
  • LocationSanto Domingo, Domincan Republic
Posted 29 October 2012 - 05:29 AM
--Me.
I installed the MF 4.3 beta and this steps where the only thing missing to continue making projects with my N+, worked like a charm! :D
Thanks a lot!
#9 rmartin
rmartin
  • 4 posts
Posted 06 June 2013 - 07:01 PM
Hi, I have Netduino uno, I use Visual Studio 2010 Pro and Now I want to use Visual Studio 2012 Pro
I follow the sugest write before
copy the Template c# MIcroframework....
I start a new project and I receive this error
Can you help me
Fabio
Posted Image
#10 rmartin
rmartin
  • 4 posts
Posted 14 June 2013 - 11:03 AM
any ideas?
