Need Help with DFRduino motor Shield
Posted 26 September 2012 - 02:20 AM
Posted 26 September 2012 - 06:12 AM
Posted 26 September 2012 - 03:08 PM
Hi kaiser and welcome to the forums!
What kind of motors do you use, and what kind of power source?
On your image I see just USB connected. USB doesn't give any power to the Vin pin, hence the motors won't get power too. I -think- that's the problem.
Yes, that's what I doubt too. I will order a power supply for it and see if it works.
Posted 28 September 2012 - 05:50 PM
Posted 28 September 2012 - 10:11 PM
Posted 28 September 2012 - 10:29 PM
Kaiser,Hello guys,
I plug a 9V power to the netduino this time and try to run the program again, it didn't work yet.
I noticed there're 4 LEDS near the Motor pin.
when I set MotorDriver.SetState(HBridge.Motors.Motor2, 50); it always red light on, if I gave MotorDriver.SetState(HBridge.Motors.Motor2, -50); the green light on.
However, when I mount the Motor on the pin, there's no more green light, the RED light always ON with some sound and I feel hot from L298P chip. I'm afraid if the chip will explode![]()
Any guys have idea how will it comes? Please HELP!
Without a picture of what you have wired up it is hard to be sure what you actually have.
But in general if a chip is hot you are drawing excessive current or the chip is not heat sinked properly.
The best i could tell you are pulling power from the 5vdc regulator on the Netduino, that regulator has a maximum output of 800 milli amps. That is sufficent for a small 5 volt servo. Anything more should have its own power, normally more than 5 volts depending on the motor. The 2 amp DFRobot shield can handle 5 to 35 vdc on the screw terminals, 6.5 to 12 vdc on the vin connection i.e. barrel connector of the Netduino and uses 5 vdc for logic power from the 5 vdc regulator.
Please take a look at Stefans Wiki page for this DFRobot Motor Shield and the DFRobot Wiki link that is on that page. It explains the difference between PwrIn and Vin and shows how to set the jumpers.
As far as the LEDs by looking at the schematic 2 LEDs are used for each motor, one for forward the other for reverse. If the LED goes out with the motor connected it is likely due to the load dropping the voltage that is needed to lite the LED i.e. you have overloaded the power supply (bad thing
Good luck,
Chuck
Posted 28 September 2012 - 11:15 PM
Posted 29 September 2012 - 12:21 AM
I wouldn't say nothing was wrong and I am not trying to be an A##hole. The condition that you had is called a locked rotor. The current can be over 10 times normal maximum current for the motor, which in turn can burn up a motors windings, commutator, controller or rectifiers of the power supply.Finally, I made it. It turns out that nothing wrong with the wiring and programming. The root cause is my track were too tight and motor cannot be drive properly... I used the twin gearbox and chassis made by Tamiya. When I took off the track, it runs OK!
Next step, I'd like to consider if I need switch to external power maybe give two 9V battery connected in parallel way.
Thank you guys, you do give me a lot of help!
The thing is it sounds like no damage occurred, and we all can learn something out of the trials.
You did a no load test without the motor, a no load test with motor connected but not connected to the tracks would of saved you some time and frustration. I'll need to remember to do that when I start building a robot.
Glad you got it working.
Chuck
Posted 24 June 2014 - 01:03 AM
I am trying to use the HBridge class.
In particular, Toolbox.NETMF.Hardware.HBridge
The first and third arguments for this are:
Toolbox.NETMF.Hardware.IPWMPortThis is described at:
http://netmftoolbox....rdware.IPWMPort
I can't seem to get MS Visual Studio C# 2010 to recognize this.
How do you do this?
Thanks, Charlie
Posted 24 June 2014 - 08:52 AM
IPWMPort is just an interface. You could load Toolbox.NETMF.Hardware.Netduino and use the Netduino.PWM() as pin.
See also:
Posted 24 June 2014 - 12:17 PM
I did install the software found at:
http://netmftoolbox....ses/view/123723
This is:
.NET Micro Framework Toolbox v0.3From within MS Visual Studio, I input the C# code found at:
http://netmftoolbox.... L298N and L293
I finally got the HBridge to be recognized after I included Toolbox.NETMF.Hardware.HBridge.
I have tried to include:
(in order to get the IDE to recognize Netduino.PWM(...)), but, so far, to no avail.
Is the link you have above:
accessible to me once I install the software found at:
Or do I have to go someplace else?
Thanks, Charlie
Posted 24 June 2014 - 03:03 PM
No, should be in the same package.
If you download the samples, and open DFRobot Motorshield.sln, you'll also see a sample code.
Posted 24 June 2014 - 03:10 PM
Regarding: "If you download the samples, and open DFRobot Motorshield.sln, you'll also see a sample code."...
OK...I'll try this.
