UPD Problems
1 reply to this topic
#1 VanKurt
VanKurt
  • 19 posts
Posted 24 September 2012 - 08:35 PM
As my first Netduiono project I decided to exchange some data with my PC via ethernet (UDP).
I already got the Netdiuno sending some random data. On the PC I'm running wireshark to see the packets.
Here's my sending code on the Netduino:
            var serverSocket = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
            serverSocket.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.ReuseAddress, true);
            serverSocket.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.Broadcast, true);
            var remoteEndPoint = new IPEndPoint(IPAddress.Any, 50505);
            serverSocket.Bind(remoteEndPoint);
            var data = new byte[]{1,2,3};
                serverSocket.Send(data);
                Thread.Sleep(1000);
The only problem is: my desktop application does NOT receive those packets (while wireshark on the same machine does!).
Here's the receiving code on PC side:
        private void Form1_Load(object sender, EventArgs e)
            var broadcastAddress = new IPEndPoint(IPAddress.Any, 50505);
            this.udp = new UdpClient();
            this.udp.Client.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.ReuseAddress, true);
            this.udp.ExclusiveAddressUse = false; // only if you want to send/receive on same machine.
            this.udp.Client.Bind(broadcastAddress);
            this.udp.BeginReceive(new AsyncCallback(this.ReceiveCallback), null);
        void ReceiveCallback(IAsyncResult result)
I checked the following things:
- Netduino is up, running and sending (packets arrive in wireshark on my PC)
- Netduino and PC are on the same subnet (255.255.255.0)
- Netduino and PC both use UDP on port 50505
- Desktop app is running and UDPClient has been successfully started
But my ReceiveCallback is never called...
Is there someone here who has successfully done this? Any advice? Thanks!
#2 caEstrada
caEstrada
  • 84 posts
Posted 28 September 2012 - 12:51 PM
VanKurt, I wrote a simple program in VBNet 2010 to debug UDP comms. I have attached the Zip for that Solution. Sorry, commented in spanish but if you run step by step, will understand. I tested it with WireShark. In my case, the PC is the master and sends orders to N+. First, checks if N+ is available on the same network segment. Send me an email to send you the zipped version I already tested. Now, for N+, I have equivalent code to process PC commands using UDP Protocol: int REMOTE_PORT = 8888; string REMOTE_IP = "192.168.1.99"; IPAddress remoteip = IPAddress.Parse(REMOTE_IP); IPEndPoint remoteendpoint = new IPEndPoint(System.Net.IPAddress.Any, REMOTE_PORT); //Configura un socket para recibir Datagramas via Internetwork usando el protocolo UDP Socket udp = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp); //Vamos a procesar los broadcasts sin importar de cual estación vengan IPEndPoint broadcastEndPoint = new IPEndPoint(System.Net.IPAddress.Any, REMOTE_PORT); //Esta es la configuración para procesar comunicaciones UDP Broadcast, probado con el WireShark udp.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.ReuseAddress, true); udp.SetSocketOption(SocketOptionLevel.Socket, SocketOptionName.Broadcast, true); udp.SendTimeout = 100; if (udp.Available > 0) { //Separa en RAM tanto Bytes como sean necesarios byte[] byteReceiveBuffer = new byte[udp.Available + 20]; //Vamos a escuchar cualquier estación por el puerto definido //EndPoint remoteEndPoint = new IPEndPoint(System.Net.IPAddress.Any, REMOTE_PORT); EndPoint remoteEndPoint = new IPEndPoint(remoteip, REMOTE_PORT); //Cuantos bytes llegaron y copialos int iNumberOfBytes = udp.ReceiveFrom(byteReceiveBuffer, ref remoteEndPoint); //Convierte los bytes ahora a un string leible en humano char[] charReceiveBuffer = System.Text.UTF8Encoding.UTF8.GetChars(byteReceiveBuffer); //Envía una copia de los recibida udp.SendTo(byteReceiveBuffer, iNumberOfBytes, SocketFlags.Broadcast, remoteEndPoint); }
