Hello everyone,
anyone has experienced with the wiegand protocol?
I have to interface Netduino with an RFID reader (EM4100) and use the Wiegand protocol for serial communication.
I do not know where to start.
Wiegand protocol for EM4100 Rfid reader
Started by argian, Oct 24 2010 09:25 PM
Posted 24 October 2010 - 09:25 PM
Posted 24 October 2010 - 11:08 PM
I've made some test with a proximity card:
1) I've read with a usb Rfid reader, so i have this "0004959302"
2) I've read with the Rfid (EM4100) reader plugged in Rsr232 of my pc, and i obtain "2F004BAC46"
3) I've read with the Rfid (EM4100) reader and netduino and i have this array of byte
63, 51, 46, 198, 198, 25, 47, 95, 94, 25, 50, 121, 61, 126
The data structure should be this:
STX (02 HEX)
DATA (10 HEX)
CR
LF
ETX (03 HEX)
But I don't understand how can read card number (0004959302) from this byte array.
Posted 25 October 2010 - 08:37 AM
I've used a different RFID reader (ID innovations ID-20) and found the following:
- Make sure you have the baud rate set correctly. Rather than not working, the wrong baud rate can give you inconsistent data.
- My reader transmitted an ASCII encoded string rather than the hex I was expecting. i.e. rather than HEX 1E hex I got HEX 31, 45 - the codes for the characters "1" and "E".
I believe Wiegand is the physical format of the binary data rather than the data format. I uses one serial line to transmit a 0 and the other to transmit a 1 (or something like that). If the reader's transmitting in Wiegand it will require a little more than connection straight to the Netduino's UART. My reader had the option to transmit in Wiegand, ASCII or Magnetic stripe emulation. If you can get it working with serial to your PC then you're most of the way there. You may need a serial to TTL level convertor but the format should be OK.
Maybe a link to the exact device you're using might be helpful.
Posted 01 April 2013 - 03:25 PM
did u ever resolve this issue ?
