Serious problem on my Netduino board
Posted 23 October 2010 - 01:37 PM
Paolo Patierno
Microsoft MVP on Windows Embedded & IoT
Azure Advisor
Twitter : @ppatierno
Linkedin : paolopatierno
Blog : DevExperience
Blog : Embedded101
Posted 23 October 2010 - 01:51 PM
I had a problem with start debugging in Visual Studio 2010....Vs didn't connect to the board.
I have tried to upgrade firmware on Netduino but the MFDeploy blocking on "Connecting to TinyCLR...".
So I have disconnected my Netduino board....
Now when I insert Netduino in USB port I get the following message on my status bar :
USB device not recognized
I have uninstalled and installed the Netduino SDk but it doesn' work !
I can't connected to the board with MFDeploy !
Help !!!
Paolo.
Don't worry
You probably need to reflash the firmware. Here the step-by-Step procedure to do it http://forums.netdui...e-does-not-fix/
Pascal
Posted 23 October 2010 - 02:09 PM
Don't worry
Pascal
I have discovered the problem...I try to work with VMWARE !!
On real PC it works !
Paolo
Paolo Patierno
Azure Advisor
Blog : Embedded101
Posted 23 October 2010 - 04:14 PM
Hi Paolo,
VMWare Fusion can be finicky. We added partial support (deployment with limited debugging) in a firmware update. If you're running old firmware, you may want to update your board anyway...
Posted 25 October 2010 - 06:48 AM
Hi Paolo,
What is the firmware version with this update ?
Paolo
Paolo Patierno
Azure Advisor
Blog : Embedded101
Posted 25 October 2010 - 06:51 AM
I believe we added limited VMWare Fusion support in v4.1.0.3.
Posted 25 October 2010 - 06:55 AM
Excuse me Chris but I have read that vmware fusion is for Mac, i have vmware workstation...is it also supported ?
Paolo
Paolo Patierno
Azure Advisor
Blog : Embedded101
Posted 25 October 2010 - 07:18 AM
Not sure: we haven't tested VMWare Workstation. We recommend running on a native machine, generally...we're trying to support VMs where/as possible to provide the best experience, but that will be support which develops more and more over time.
Posted 25 October 2010 - 07:21 AM
Ok...I will work on native machine...it works fine on it !
Paolo
Paolo Patierno
Azure Advisor
Blog : Embedded101
