Netduino Mini Firmware v4.2.0 (Update 1)
12 replies to this topic
#1 Chris Walker
Posted 20 September 2012 - 05:20 AM
Version: 4.2.0 Update 1 (version 4.2.0.1)
This firmware requires use of the .NET Micro Framework v4.2 SDK (QFE2) and Netduino 4.2.0.1 SDK..
152KB Flash
70KB+ RAM
This firmware includes the following update:
1. PWM bugfix (period/frequency now set correctly)
2. RS232 firmware now enables deployment/debug over RS232
This firmware also includes the following prior updates:
1. Visual Basic is now a supported language for .NET MF
2. New core AnalogInput and PWM classes; backwards-compatible classes available via add-on assemblies.
3. New WinUSB drivers (to remedy BSOD issues in 4.2 beta)
4. Garbage collector now fully collects old objects
5. See netmf.codeplex.com for full details of all bugfixes
3. Plug your Netduino Mini into your PC using an RS232 or TTL UART cable.
4. In the Device section at top, select Serial. Select the serial port assigned to your RS232 or TTL UART cable.
Users of firmware version 4.2.0.0 or earlier may update to this new firmware:
1. Erase your Netduino Mini by applying 5V power to the gold ERASE pad
a. Power cycle your Netduino Mini
2. Flash TinyBooterDecompressor.bin using SAM-BA v2.12+
3. Flash TinyCLR using MFDeploy v4.2+
a. Click "Browse..." and select the TinyCLR files (ER_CONFIG and ER_FLASH).
b. Press "Deploy". It will take a few minutes to update your Netduino Mini.
There are two versions of firmware attached to this post. If you want to use the TTL port for debugging, then flash the TTL version of the TinyBooterDecompressor firmware using SAM-BA. Then flash TinyCLR (ER_FLASH and ER_CONFIG) using MFDeploy on the Netduino Mini's TTL serial pins.
#2 Jack Chidley
Jack Chidley
  • 98 posts
Posted 11 October 2012 - 11:03 AM
I have 3 new Minis and I am using the Keyspan to flash them with both RS232. RS232 TinyBooterDecompressor.bin and firmware work perfectly. However, I can't get the TTL versions to work. My procedure is to flash the (TTL) TinyBooterDecompressor.bin with the Keyspan over RS232. But then I cannot ping the mini via MFDeploy using TTL, so I can't deploy the TTL firmware (I assume that you have to use TTL to do the deployment). I am using both the USB BUB II and Arduino USB adapters. Same result for both. Jack
#3 Chris Walker
Posted 11 October 2012 - 04:13 PM
Hi Jack,
Very odd. What happens if you flash the RS232 version of TinyBooter...and then use it to flash the TTL version of TinyCLR?
#4 Jack Chidley
Jack Chidley
  • 98 posts
Posted 13 October 2012 - 09:31 AM
Used the RS232 tinybooter and MFDeploy to flash the TTL firmware. Can't ping it, can't get device config, can't program it. Reflashed with RS232 versions of everything. Works perfectly. Any ideas?
Edited by Jack Chidley, 13 October 2012 - 09:54 PM.
#5 DaveRVW
DaveRVW
  • 37 posts
Posted 21 October 2012 - 06:37 PM
Jack, recheck your TTL connection including power. I was able to flash my mini using both the RS232 and TTL versions of TinyBooterDecompressor successfully with SAM-BA v2.11, and then after powering off/on successfully pinged using MFDeploy and deployed ER_CONFIG, ER_FLASH successfully. The COM connections for MFDeploy changed accordingly. I am using a FTDI TTL223R 5V cable (USB to TTL), and a FTDI <-> Serial adapter (USB to 232) for the two connections.
Any ideas?
#6 lb7000
lb7000
Posted 29 May 2013 - 03:08 AM
Where can I find the source code for NetduinoMini_Firmware_4.2.0.1_RS232.zip?
#7 Marc B
Marc B
  • 3 posts
Posted 08 October 2013 - 08:39 AM
I have 5 NetduinoMini. Since I've uploaded four of them with the firmware 4.2.0.1(RS232) the reset pin doesn't work anymore. However it works fine with the one that still has the firmware 4.2.0.0(RS232).
1. Does someone have the same issue with firmware 4.2.0.1(RS232)?
2. Link for downloading the firware 4.2.0.0(RS232) is broken. Does someone know where I can find it?
Thx,
Marc
#8 andrew6071
andrew6071
  • 18 posts
  • LocationUK
Posted 26 May 2014 - 12:06 AM
I'm trying to upgrade my mini, to 4.2 but i'm not having much luck.
I've got a smartfun ft232r breakout board connected up to pins 11 and 12, but can't get sa-mba 2.12 patch 6 (<-- could the patch 6 bit be the problem) to recognise the device
All I get is communications error, I can see the breakout board sending data but not receiving anything.
Any help would be appreciated
oh and i'm running on a windows 8.1 64bit box
Andrew
#9 andrew6071
andrew6071
  • 18 posts
  • LocationUK
Posted 26 May 2014 - 12:18 AM
I suspect the problem is that I need to connect using the rs232 connection instead, not sure if my pc has a serial connection so I guess I need a usb to serial adaptor ??
I assume my break out board wont work ?
Andrew
#10 andrew6071
andrew6071
  • 18 posts
  • LocationUK
Posted 28 May 2014 - 11:26 PM
Ok, I've managed to flash the ttl tinybootloader but I can't ping the device
Does it matter that i'm powering the mini from the ttl board, is it worth using a proper 5v power supply instead ?
what happens if I use the rs232 bootloader instead ? Does it mean I can't use ttl to deploy anymore ? Can I switch between ttl and rs232 as I did in the first instance ?
Andrew
#11 beerygaz
beerygaz
  • 3 posts
Posted 17 October 2014 - 01:33 PM
I'm trying to upgrade to 4.20.  I've managed to upgrade the TinyBooterDemopressor using SAM-BA but that's as far as I can get.  I can't use MFDeploy (4.3.1.0) to ping or deploy the new RS232 Firmware
#12 Chris Walker
Posted 02 November 2014 - 04:16 PM
Hi beerygaz,
Did you flash the Netduino Mini with RS232 or TTL firmware?  Also--the NETMF 4.3 SDK has some unique timing issues.  If you can't get it to work at all, try uninstalling the 4.3 SDK and installing 4.2 instead.
Or go grab the special version of MFDeploy we made for changing deployment ports (which uses an earlier SDK's serial transport code):
http://forums.netdui...b-and-com1com2/
#13 kiwi65
kiwi65
  • 23 posts
Posted 16 April 2015 - 02:51 AM
beerygaz, I'm struggling with the same problem... new TinyBootCompressor.bin installed ok (I tried 4.2.0.0 and 4.2.0.1). Then, despite all the obvious success other have from there.... my Win8.1 MFDeploy can't see the Mini, and I tried MFDeploy.exe from 4.2, 4.3.1 and also the special version Chris linked to. Frustrating.
Did you manage to get your Mini running 4.2?
home    hardware    projects    downloads    community    where to buy    contact Copyright © 2010-2014 Secret Labs LLC  |  Legal   |   CC BY-SA
