My Netduino refuses to reset ...
Posted 15 September 2012 - 11:12 AM
Posted 17 September 2012 - 04:40 PM
After that, when I try to debug some code on the Netduino with Visual Studio, it says "The debugging target is not in a initialized state; rebooting..." and nothing more happens.
I started the see the same message after I upgraded to 4.2 firmware.
I found a workaround. Once the message appears, unplug the USB cable on the Netduino side and plug it again. Visual Studio enters debug mode like nothing happened...
aalmada
Posted 17 September 2012 - 06:23 PM
Posted 20 September 2012 - 05:24 PM
Is anyone else experiencing the VS hang with message "The debugging target is not in a initialized state; rebooting..."?
Posted 20 September 2012 - 08:09 PM
Were you using 4.2.0.0 before? The only code change was the setting of the PWM base clock so this shouldn't be affected.I upgraded to 4.2.0.1 and the problem got worst. The unplug and plug USB cable doesn't make it work anymore.
Posted 21 September 2012 - 09:33 AM
That's what I thought so I also think it's strange. Could it be something in the upgrade process gone bad?
I followed the instructions from http://wiki.netduino...ep-by-step.ashx and http://wiki.netduino...ep-by-step.ashx
I have .NET MF SDK 4.2 (QFE2) and Netduino SDK v4.2.0 (August 2012) 64-bit installed.
When I execute an application from VS, it deploys correctly but it hangs with the "rebooting" message on the status bar.
aalmada
Posted 21 September 2012 - 10:05 AM
Posted 21 September 2012 - 10:56 AM
I use a commercial version of VS2010 (Visual Studio 2010 Professionnal) and not Visual Studio 2010 Express.
I also use Visual Studio 2010 Professional.
Posted 21 September 2012 - 11:36 AM
Posted 26 May 2013 - 11:11 AM
I'm using VS 2010 Express and I have the same error. VS cannot deploy and I recerive "[color=rgb(40,40,40);font-family:helvetica, arial, sans-serif;]No response from device[/color]" when I ping it.
I try to unplug and re-plug arduino after VS deploy error but it doesn't work.
Note: I have installed only 4.2
