Trigger a function based on time of day
6 replies to this topic
#1 MaikolPlan
MaikolPlan
Posted 11 September 2012 - 01:43 PM
Hi: I'm new to Netduino world and so far all my little experiments have gone well thanks to the great community in this forum. Now I have a question for you people. I need that my Netduino Plus can send an XML file at a given time of the day. My idea is that for example at 4 p.m there is a trigger that makes Netduino call one of the existing functions in my code, that sends the XML data to my server. I don't know how to create this trigger that calls the existing function. I have read about event handlers and delegates but doesn't know if they can serve my purpose. I code on C#. Thanks in advance. Mike
#2 65tux
65tux
  • 38 posts
Posted 11 September 2012 - 03:43 PM
Freaky - I'm working right now on doing almost the EXACT same thing. All I am planning to do is in the Main do a while(true) with sleeps to check to see if current time >= configured time, then spawn a thread to do my transactions. Will post code when I get it working.
#3 65tux
65tux
  • 38 posts
Posted 12 September 2012 - 06:06 PM
Hopefully this works - I stripped a bunch of my other code out because I actually have an array list with multiple time of day events, but this should make sense.
            TimeSpan ts;
			DateTime ShiftStart = DateTime.Today + new TimeSpan(16, 0, 0);  //schedule first event at 16:00:00 today
                DateTime now = DateTime.Now;
                ts = shft.ShiftStart.Subtract(now);
				if (ts.Ticks < 0 )
					//current time greather than event time, fire
					 Thread t = new Thread(MyWorker);
					t.Start();
					//set event time to tomorrow
					ShiftStart = ShiftStart + new TimeSpan(1, 0, 0, 0);
			   Thread.Sleep(10000);
#4 MaikolPlan
MaikolPlan
Posted 13 September 2012 - 01:54 AM
Thanks 65tux! I'll give your code a try. Also I would like to know if someone has accomplish to trigger this with event handlers. thanks,
#5 Patrick
Patrick
  • 54 posts
  • LocationTampa
Posted 15 September 2012 - 02:24 PM
I don't believe DateTime.Now() actually returns the current time as it does on the non-micro version of the .Net framework. The Netduino simply doesn't remember the system time when powered off (no battery) so you get a default value. You need to somehow set the system time when powered up - maybe from a time server - then that code should work. I've thought about this a bit but have never worked through a solution but it seems likely that someone would have. Sorry I can't be more help.
#6 JerseyTechGuy
JerseyTechGuy
  • 870 posts
Posted 15 September 2012 - 09:03 PM
You can do it via Time server or you can add a RTC Module (Real Time Clock). Set it once and forget it.
#7 Kem
Kem
  • 17 posts
Posted 16 September 2012 - 01:49 PM
What about setting a System.Threading.Timer to go at x milliseconds from now?
namespace DoThingAtEleven
            Debug.Print(DateTime.Now.ToString("HH:mm:ss"));
            DateTime needEventAt = DateTime.Today + new TimeSpan(23, 00, 0);
            long ticksToEleven = needEventAt.Ticks - DateTime.Now.Ticks;
            int millisecondsToEleven = (int)(ticksToEleven / TimeSpan.TicksPerMillisecond);
            Timer triggerAtEleven = new Timer(new TimerCallback(DoThingAtEleven), null, millisecondsToEleven, Timeout.Infinite);
        private static void DoThingAtEleven(object state)
            Debug.Print("It's time!");
            Debug.Print(DateTime.Now.ToString("HH:mm:ss");
