InterruptPort gives exception in Netduino Plus - Netduino Plus 2 (and Netduino Plus 1) - Netduino Forums
6 replies to this topic
#1 Victor M.
Victor M.
  • 39 posts
  • LocationRio de Janeiro, Brazil
Posted 30 August 2012 - 12:51 PM
I need help to understand what happening in my code. When I run it an error in this line occur:
InterruptPort FlowMeterPulse = new InterruptPort(Pins.GPIO_PIN_D1, false,
            	Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeHigh);
The error is:
An unhandled exception of type 'System.Exception' occurred in Microsoft.SPOT.Hardware.dll
The code is:
    	//Flow Meter Settings
    	public const int INTERRUPT_TIMER_MS = 30000;
    	public static long pulsebuffer = 0;
    	public static double TotalFlow;
    	public static TimerCallback timerDelegate = new TimerCallback(TimeProcessEvents);
    	public static Timer FlowMeterTimer;
   	// public static ;
        	FlowMeterPulse.OnInterrupt += new NativeEventHandler(FlowMeterPulse_OnInterrupt);
        	FlowMeterTimer = new Timer(timerDelegate, null, 0, INTERRUPT_TIMER_MS);
        	//Thread FlowManagerThread = new Thread(new ManagerInterrupt().Initialize);
        	//FlowManagerThread.Start();
        	Server WebServer = new Server(PinManagement.OnboardLED, 80);
            	PinManagement.OnboardLED.Write(true);
            	Thread.Sleep(100);
            	PinManagement.OnboardLED.Write(false);
            	Thread.Sleep(2400);
    	/// <summary>
    	/// </summary>
    	/// <param name="state"></param>
    	private static void TimeProcessEvents(object state)
        	double meanFlow = (double)((double)7.5 * (double)pulsebuffer  / (double)30);
        	TotalFlow += meanFlow * 0.5;
    	public static void FlowMeterPulse_OnInterrupt(uint data1, uint data2, DateTime time)
        	pulsebuffer++;
I'm using the .NETMF 4.2
#2 Igor Kondrasovas
Igor Kondrasovas
  • 105 posts
  • LocationPorto, Portugal
Posted 30 August 2012 - 09:51 PM
What if you declare FlowMeterPulse as static too? Does it help?
Igor.
Igor Kondrasovas
www.inovativatec.com
#3 Victor M.
Victor M.
  • 39 posts
Posted 31 August 2012 - 07:11 PM
Put FlowMeterPulse static did not solve my problem but a solve it making a new solution :blink:...
Tanks Igor.
#4 Fred Werneck
Fred Werneck
  • 3 posts
Posted 08 April 2013 - 02:24 AM
Victor,
Como você resolveu esse problema? Estou tentando usar o Web Server juntamente com um sensor DHT11 e está dando o mesmo erro.
Fred.
#5 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 08 April 2013 - 07:04 AM
Hi Fred, and welcome to the Netduino forums.
So you can get the best help, I would like to ask you to post in English. That way everyone will understand you and be able to help you out.
#6 Chris Walker
Posted 11 April 2013 - 01:19 AM
Hi Victor, For Netduino gen2, try using Port.InterruptMode.InterruptEdgeBoth instead. Then discard any "low" events. Also...I recommend using pins D0 and D2-D13 for interrupts. All of them have unique interrupt pins. D1 is the one digital pin that overlaps interrupts (with pin D9). Chris
#7 moses
moses
Posted 17 July 2013 - 07:50 PM
Hi. I am new to Netduino, help me for the codes for webserver and using  temperature and humidity sensor DHT11
