Mini Upgrade Woes
#21
Posted 23 August 2012 - 05:35 AM
http://diybrewery.com
#22
Posted 30 August 2012 - 04:42 PM
#23
Posted 30 August 2012 - 05:18 PM
Here is the project source. If you switch it to NETMF 4.2, you should be able to deploy and run it on your Netduino Mini.Is there a prebuilt 4.2 transport selector anywhere I can download and deploy?
Please let us know how this works for you. We're making one other small change, and hope to have a revised RS232 firmware image shortly.
#24
Posted 03 September 2012 - 08:11 AM
Hi Chris
Not exactly good news. I was able to build and deploy it, but it doesn't seem to run. I have Putty running on both a USB/TTL adaptor connected to Tx0/Rx0 and on COM1 connected to DTX0/DRX0, and nothing seems to be coming out of either port.
I am going to try 'hard-setting' the transport port using the code in the selector as a guide, to see if that works.
Unfortunately it's been a busy weekend, so I wasn't able to do this yet.
SteveS
#25
Posted 03 September 2012 - 09:12 PM
Hi Chris
SteveS
I tried setting the interface to Com1 and Com2, neither of which seem to make the RS232 port work as the transport, so I guess I will need to wait for the new firmware.
SteveS
#26
Posted 03 September 2012 - 10:57 PM
#27
Posted 04 September 2012 - 07:59 AM
You're welcome. I've been a software developer for 30+ years, so I know how it is. Stuff happens.Hi SteveS,
Thanks for testing this. It might be seeing the same core issue. We'll pull it in and try to fix both at the same time.
As it happens, yes - I'll be doing some work on an N, rather than a mini for the next phase of my project.
Can you use TTL for deployment for the moment?
SteveS
#28
Posted 08 September 2012 - 10:00 PM
#29
Posted 08 September 2012 - 11:03 PM
#30
Posted 22 September 2012 - 05:31 AM
#31
Posted 23 September 2012 - 05:09 PM
