Netduino Plus Firmware v4.2.0
60 replies to this topic
#1 Chris Walker
Posted 14 August 2012 - 11:31 AM
Version: 4.2.0 (version 4.2.0.0)
This firmware requires use of the .NET Micro Framework v4.2 SDK (QFE2) and Netduino 4.2.0.1 SDK.
64KB Flash
42KB+ RAM (50% more RAM than 4.1.0.6)
1. 50% more RAM: 42KB (4.2.0.0) vs. 28KB (4.1.0.6)
2. Visual Basic is now a supported language for .NET MF
3. New core AnalogInput and PWM classes; backwards-compatible classes available via add-on assemblies.
4. New WinUSB drivers (to remedy BSOD issues in 4.2 beta)
5. Garbage collector now fully collects old objects
6. See netmf.codeplex.com for full details of all bugfixes
To find the current version of your Netduino Plus firmware:
3. Plug your Netduino Plus into your PC using a Micro USB cable.
4. In the Device section at top, select USB instead of Serial. Your Netduino Plus should appear in the drop-down; if not, select it.
Users of firmware version 4.2.0.0 RC5 or earlier may update to this new firmware:
1. Erase your Netduino Plus by applying 3V3 power to the gold ERASE pad
a. Detach and reattach your Netduino Plus (power cycle)
2. Flash TinyBooterDecompressor.bin using SAM-BA v2.12+
3. Flash TinyCLR using MFDeploy v4.2+
a. Click "Browse..." and select the TinyCLR files (ER_CONFIG and ER_FLASH).
b. Press "Deploy". It will take a few minutes to update your Netduino Plus.
c. Detach and reattach your Netduino Plus (power cycle)
After flashing, to set your network settings using MFDeploy.
a. Start your Netduino Plus in TinyBooter mode by holding the pushbutton while plugging it into your PC using a MicroUSB cable.
b. Select the Target > Configuration > Networking menu. Re-enter your IP address settings and MAC address.
#2 Ellen
Ellen
  • 65 posts
  • LocationRotterdam, Netherlands
Posted 15 August 2012 - 07:59 PM
Chris, You did not tell that also Netduino SDK 4.2.0.1 and .NET Micro Framework SDK v4.2Q2 is needed Without windows can not recognize the Netduino. Ellen
#3 Chris Walker
Posted 15 August 2012 - 08:00 PM
Hi Ellen,
Good point! The updated SDK includes the necessary WinUSB drivers.
I just added "Netduino SDK 4.2.0.1" to the pre-requisites note in the first post.
Thank you for pointing this out.
#4 GregR
GregR
  • 32 posts
  • LocationKeller, Tx
Posted 15 August 2012 - 09:34 PM
Hi Ellen,
I installed the latest version and it is showing up as 4.2.0002
Is that not the correct version?
Greg
#5 Chris Walker
Posted 15 August 2012 - 10:32 PM
Hi GregR,
You have the correct version. The version number you're seeing is from the setup file and is due to a feature of InstallShield. We'll see if there's a way to sync these version numbers in the future to avoid any confusion.
#6 Ellen
Ellen
  • 65 posts
Posted 16 August 2012 - 08:04 AM
Is there in this version 4.2.0.1 support for the SD HC 8 gieg card? Dim fs As FileStream = File.Create("\jj.txt") error: An unhandled exception of type 'System.IO.IOException' occurred in System.IO.dll If there is not than i can stop with finding out. gr Ellen
#7 Chris Walker
Posted 16 August 2012 - 08:13 AM
Hi Ellen,
error:
gr Ellen
The .NET MF team updated the SD card drivers in .NET MF 4.2. If there are any cards which worked with 4.1.1 but aren't working with the official 4.2 release, we want to make sure we get those supported.
Can you please provide the manufacturer and model number of your card, and we'll try to get one here to test against?
#8 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 16 August 2012 - 08:21 AM
error:
gr Ellen
Hi Ellen,
The mountpoint is not correct, I think you want:
Dim fs As FileStream = File.Create("\SD\jj.txt")
#9 Ellen
Ellen
  • 65 posts
Posted 19 August 2012 - 06:50 PM
Hi Ellen,
It took a while....
Chris, Stefan, I start with the bottom line, There is no way that we could read or write from the mini SDcard. I think there is a lot to re-write and test in the system.dll
What we did: purchased a second N+ and a second 4 gieg mini SDcard. Just to exclude that the first N+ or card was broken.
We did test it in the most unthinkable way and code, mixed...in ...out...power recycle...format....other computer, ....you name it, we did it.
Those who have a working SDcard must see themselves as the lucky ones. If there is someone who can tell ... with these steps and program code it must go well...
Ellen
#10 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 19 August 2012 - 08:12 PM
Hi Ellen, I just checked with Chris and tested it on my own Netduino Plus. SDHC is not yet supported in 4.2. The only firmware it is supported in right now is 4.1.1.1 beta. Community member Kodedaemon worked on the SDHC support in the previous release, but Microsoft has made some major changes to SD support so they must be re-evaluated. I must say I sympathize with you, I wished SDHC support would be in this release too, but until then, you are stuck with <=2GB cards (which are still widely available and cheap btw!)
#11 gfcwfzkm
gfcwfzkm
  • 52 posts
  • LocationBrig-Glis, Switzerland
Posted 19 August 2012 - 09:52 PM
When i click on MFDeploy on "Device Capabilities", the program say: Not Supported Is there a error or is that normal? in RC5 i became all infos mfg gfc
#12 Chris Walker
Posted 19 August 2012 - 10:29 PM
Hi gfc,
Press ping...are you in TinyBooter mode or TinyCLR mode?
If you're in TinyBooter mode, then unplug and reattach your Netduino... That will boot into TinyCLR mode and you can list the Device Capabilities then.
#13 Ellen
Ellen
  • 65 posts
Posted 20 August 2012 - 07:42 AM
Hi Ellen,
Thanks Stefan, Chris,
Now we have clearness in this case. Now i can stop thinking about what did I wrong, what didn't I see. I buy a 2gieg and let you know.
Ellen
#14 Fred
Fred
  • 302 posts
  • LocationUK
Posted 20 August 2012 - 12:12 PM
I'm also getting some flaky behaviour after a 4.2 upgrade on a N+. I've poked around a fair bit but was going to do some more before posting, but your issues sound similar to mine.
I ensured earlier versions of everything (SAM-BA, .NET MF, Netduino SDK) were removed and the latest installed. I completely erased, flashed TinyBooter using SAM-BA 2.12 and then the new firmware via the 4.2 QFE2 version of MFDeploy.
I could get Device Capabilities but teh device would often hang afterwards. I would get "not supported in this version" when trying to set the IP address in MFDeploy. That finally stuck, but it's now being very reluctant to connect in Visual Studio. I've totally erased and reflashed a couple of times. I'll do some more prodding and poking when I get a chance, but I've got lots on at the moment and it may get left for a while.
#15 Chris Walker
Posted 20 August 2012 - 01:34 PM
Hi Fred,
Netduino acts a bit differently with the new WinUSB drivers than with the old MFUSB drivers.
For instance, you need to be in TinyBooter mode (by pressing and holding the pushbutton while plugging in your Netduino) to change the IP settings. Also, to even enumerate as a WinUSB device in MFDeploy or Visual Studio...it can't have an open connection in another instance of either program.
When you have time...if you can give us a bit more info on the experience you're having we can walk through it and hopefully help sort out what's happening.
#16 Fred
Fred
  • 302 posts
  • LocationUK
Posted 20 August 2012 - 04:11 PM
I wasn't aware of that. I'll give it a go and see what difference that makes. Does that mean we have to press the button and reset every time we want to program and debug? My plus appears fine as "Netduino" in device manager - I just can't do much with it.
#17 Chris Walker
Posted 20 August 2012 - 04:35 PM
Hi Fred,
No, you don't need to reset to deploy, program, or debug. The Netduino will take care of that automatically.
As opposed to MFUSB, the WinUSB drivers make a single connection to the NETMF board and then hold onto it. TinyBooter and TinyCLR are two separately applications running on the Netduino, and both of them need to grab onto that WinUSB connection to perform their duties.
When a Netduino running 4.2 firmware boots, it looks to see if the pushbutton is being held down. If so, then TinyBooter grabs the WinUSB connection so you can change settings on or do maintenance to your Netduino. If the button isn't being held down then it starts up TinyCLR and lets it grab the WinUSB connection instead.
When you change settings from MFDeploy, if TinyCLR is running then it tries to reboot the board to switch to the TinyBooter application. The board reboots but TinyBooter can't grab the WinUSB connection (since it was established with TinyCLR).
So to change settings...boot into TinyBooter mode by holding the pushbutton during boot. To deploy and debug applications, just use your Netduino like before... The only behavioral change is switching into TinyBooter for IP settings/flashing/maintenance.
#18 Fred
Fred
  • 302 posts
  • LocationUK
Posted 20 August 2012 - 09:01 PM
:) This seemed to be the key to it! I'm now sorted. Without pressing the onboard button when plugging in before using MFDeploy it seems that you can reflash the firmware but end up with a badly behaving Netduino. Very odd.
#19 andersborg
andersborg
  • 53 posts
Posted 21 August 2012 - 10:59 AM
Revised: It worked if I moved to another USB port (??!?!). After SAM-BA has detected the USB driver and I've selected at91sam7x512-ek and then click "Connect", SAM-BA pops up "Error in startup script" "Error h_handle returned zero" etc. I'm using Windows 7 64, .NET 4.2 and SDK 4.2. Any idea what could cause this to happen? Cheers, Anders
#20 Chris Walker
Posted 21 August 2012 - 12:44 PM
Hi Anders,
Cheers,
Anders
That's very odd. So it did work alright after moving the Netduino to another USB port?
Also, are you using SAM-BA v2.12+? The earlier versions had some issues with Win7 x64.
