N+ hangs sometimes when try to receive Time
9 replies to this topic
#1 Ellen
Ellen
  • 65 posts
  • LocationRotterdam, Netherlands
Posted 14 August 2012 - 09:03 AM
Hello,
How can i resolve hanging my N+ when i want to sync my Netduino with a time server.
Function call:
Utility.SetLocalTime(NTPTime("time-a.nist.gov"))
"time-a.nist.gov" : ntp ok, time,daytime busy, not recommended
He will sometimes hang when receive :
s.Receive(ntpData)
I can choose out of many servers but that is for now not the point.
http://tf.nist.gov/tf-cgi/servers.cgi
How to resolve?
Thanks in advance, Ellen
        Private Shared Function NTPTime(ByVal TimeServer As [String]) As DateTime
            Dim ep As New IPEndPoint(Dns.GetHostEntry(TimeServer).AddressList(0), 123)
            Dim s As New Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp)
            Dim ntpData As Byte() = New Byte(47) {}
            Array.Clear(ntpData, 0, 48)
            ntpData(0) = &H1B
            s.SendTimeout = 5000
            s.SendTo(ntpData, ep)
            s.Receive(ntpData)     'with debugging, HERE he will stop.'
            Dim offsetTransmitTime As Byte = 40
            Dim intpart As Long = 0
            Dim fractpart As Long = 0
            For i As Integer = 0 To 3
                intpart = (intpart << 8) Or ntpData(offsetTransmitTime + i)
            Next
            For i As Integer = 4 To 7
                fractpart = (fractpart << 8) Or ntpData(offsetTransmitTime + i)
            Next
            Dim milliseconds As Long = CLng(intpart * 1000 + (fractpart * 1000) / &H100000000L)
            s.Close()
            Dim timeSpan__1 As TimeSpan = TimeSpan.FromTicks(CLng(milliseconds) * TimeSpan.TicksPerMillisecond)
            Dim dT As New DateTime(1900, 1, 1)
            dT += timeSpan__1
            'daylight saving'
            If dT.Month < 3 OrElse dT.Month > 10 Then
                Return dT.AddHours(1)
            End If
            If dT.Month > 3 AndAlso dT.Month < 10 Then
                Return dT.AddHours(2)
            End If
            If dT.Month = 3 Then
                '      in march'
                If (dT.Day - CInt(dT.DayOfWeek)) < 25 Then
                End If
                If (CInt(dT.DayOfWeek) = 0) AndAlso (dT.Hour < 2) Then
                End If
            End If
            '      in october'
            End If
            End If
        End Function
Posted 14 August 2012 - 09:27 AM
Hi Ellen, Is your app hanging on Utility.SetLocalTime or on the NTPTime call? What does the NTPTime code look like? Chris
#3 Ellen
Ellen
  • 65 posts
Posted 14 August 2012 - 10:32 AM
Hi Ellen,
No he hangs on a earlier somewhere on this forum copied NTPTime call (source code I had included above), at s.Receive(ntpData)
I think i need to call the Socket.ReceiveTimeout Property because the default value is 0, which indicates an infinite time-out period. Specifying -1 also indicates an infinite time-out period.
In other words, with a ?bad connection? i can wait until i have gray hair. :blink:
#4 skarphedinnos
skarphedinnos
  • 26 posts
  • LocationIceland
Posted 24 October 2012 - 12:39 AM
Hi. I have been trying this NTP for couple of days now. I have the same problem, the program hangs on s.Receive(ntpData). I have tried various NTP servers, both server names and ip addresses. The ND is connected to ethernet on laptop using bridged connection between the ethernet and wifi. If I put some NTP server name I can see it's IP while debugging. BTW I'm using latest firmware(4.201). Any ideas? Or can someone post code with NTP server that is currently working? Thanks, Skarphedinn.
#5 fesp
fesp
  • 6 posts
Posted 05 March 2013 - 06:43 AM
Did you ever solve this? I'm facing the same problem...
#6 Chris Walker
Posted 05 March 2013 - 07:28 AM
Hi fesp,
Are you using a Netduino Plus or a Netduino Plus 2? If NP2, it also incorporates the built-in NETMF classes for NTP. Chris
#7 fesp
fesp
  • 6 posts
Posted 05 March 2013 - 08:11 PM
It's a Netduino Plus (4.2.0.1). I just ordered an NP2 and it should be arriving tomorrow. But I'd really like to get it working with this device. I have seen it working before, but that was probably with an earlier firmware version. Can it be related to that?
#8 baxter
baxter
  • 415 posts
Posted 05 March 2013 - 09:39 PM
Hi fesp,
Attached is a routine using the NIST DayTime protocol it uses TCP and port 13. It has always been reliable for me on startup for both the Plus 1 and 2 to set the Netduino clock. It is setup for 3 servers and tries each server three times.
Baxter
Call it like this,Try    Using NIST_Time As DayTimeNIST = New DayTimeNIST("utcnist2.colorado.edu", -8)        NIST_Time.UTC_offset = -8        NIST_Time.GetTimeFromNIST()        Debug.Print("Clock set: " & NIST_Time.successful)        Debug.Print("Server used: " & NIST_Time.TimeServer)        Debug.Print("Time from NIST  " & NIST_Time.networkDateTime)        Debug.Print("Current time set from DayTimeNIST: " & DateTime.Now.ToString)    End UsingCatch    Debug.Print("no IP Address")             End Try============Imports Microsoft.SPOTImports Microsoft.SPOT.HardwareImports SecretLabs.NETMF.Hardware'Imports SecretLabs.NETMF.Hardware.NetduinoPlusImports SecretLabs.NETMF.Hardware.NetduinoImports System.ThreadingImports System.NetImports System.TextImports System.Net.SocketsImports Microsoft.SPOT.Net.NetworkInformation''' <summary>''' Set Netduino Plus time using NIST Daytime Protocol''' Upon return from getTimeNIST, the clock is running''' with the correction for daylight savings or''' standard time and the input UTC offset.''' </summary>''' <remarks></remarks>Public Class DayTimeNIST    Implements IDisposable    Private disposed As Boolean = False    'these servers are always reliable for Daytime protocol    Private Servers() As String = {"wwv.nist.gov", "utcnist2.colorado.edu", "utcnist.colorado.edu"}    Private ServerIndex As Integer = 0 'server index    Private buffer(51) As Byte 'Size of Daytime Protocol response    Public Sub New()        Me.TimeServer = Servers(ServerIndex)        ServerIndex += 1    End Sub    Public Sub New(ByVal tServer As String, ByVal offsetUTC As Integer)        Me.TimeServer = tServer.Trim        Me.UTC_offset = offsetUTC    End Sub    Public Property TimeServer As String    Public Property UTC_offset As Integer = -8 'Default: Pacific Time (US & Canada)    Public Property successful As Boolean = False    Public Property networkDateTime As String    Public Sub GetTimeFromNIST()        'format of Daytime string: JJJJJ YR-MO-DA HH:MM:SS TT L H msADV UTC(NIST) OTM        Dim nBytes As Integer = 0        Dim count As Integer = 0        Dim StdTime As Integer = 0        Dim s1() As String = {}        Dim s2() As String = {}        Dim s3() As String = {}        Dim success As Boolean = False        ' Connect to timeserver         Do While (nBytes = 0)            count += 1            Using s As Socket = New Socket(AddressFamily.InterNetwork, SocketType.Stream, ProtocolType.Tcp)                s.ReceiveTimeout = 500                Dim ep As IPEndPoint = New IPEndPoint(Dns.GetHostEntry(Me.TimeServer).AddressList(0), 13)                s.Connect(ep)                nBytes = s.Receive(buffer)                s.Close()            End Using            If (nBytes <> 0) Then                Dim Response As String = Encoding.UTF8.GetChars(buffer)                s1 = Response.Split(" "c)                s2 = s1(1).Split("-"c) 'yr, mo, day                s3 = s1(2).Split(":"c) 'hr, min, sec                Dim DST As Integer = CInt(s1(3))                'Set the correct daylight or standard time                If (DST = 0 Or DST > 51) Then 'on standard time                    StdTime = 0                ElseIf (DST <= 50 And DST > 1) Then                    StdTime = 1                End If                Dim dt As DateTime = New DateTime(2000 + CInt(s2(0)), CInt(s2(1)), CInt(s2(2)),                                          CInt(s3(0)), CInt(s3(1)), CInt(s3(2))).AddHours(Me.UTC_offset + StdTime)                Utility.SetLocalTime(dt)                Me.networkDateTime = Response                Me.successful = True                Exit Do            End If            Debug.Print("count = " & count.ToString)            If (count = 3) Then                If (ServerIndex <= 2) Then                    Me.TimeServer = Servers(ServerIndex)                    ServerIndex += 1 'point to next server                    Debug.Print("Trying a different server : " & Me.TimeServer)                    count = 0                Else                    Debug.Print("tried 3 servers something is wrong")                    Me.successful = false                    Exit Do                End If            End If            Thread.Sleep(5000) 'per NIST instructions do not query more than once every 4 sec        Loop    End Sub#Region "IDisposable Support"    Private disposedValue As Boolean ' To detect redundant calls    ' IDisposable    Protected Overridable Sub Dispose(disposing As Boolean)        If Not Me.disposedValue Then            If disposing Then                ' TODO: dispose managed state (managed objects).                Debug.Print("disposing Daytime Client ")                Debug.Print("GC: " & Debug.GC(True).ToString)            End If            ' TODO: free unmanaged resources (unmanaged objects) and override Finalize() below.            ' TODO: set large fields to null.        End If        Me.disposedValue = True    End Sub    ' TODO: override Finalize() only if Dispose(ByVal disposing As Boolean) above has code to free unmanaged resources.    'Protected Overrides Sub Finalize()    '    ' Do not change this code.  Put cleanup code in Dispose(ByVal disposing As Boolean) above.    '    Dispose(False)    '    MyBase.Finalize()    'End Sub    ' This code added by Visual Basic to correctly implement the disposable pattern.    Public Sub Dispose() Implements IDisposable.Dispose        ' Do not change this code.  Put cleanup code in Dispose(ByVal disposing As Boolean) above.        Dispose(True)        GC.SuppressFinalize(Me)    End Sub#End RegionEnd Class
#9 fesp
fesp
  • 6 posts
Posted 06 March 2013 - 07:38 PM
Thanks Baxter, that works! I guess I'll be using this code from now on.
Wonder if the problem has anything to do with TCP vs UDP...
#10 baxter
baxter
  • 415 posts
Posted 06 March 2013 - 11:06 PM
Glad to help...
I think it does. I recall some issues with UDP. They may have gone away with the latest software.
