Collect data to a SQL database
Posted 21 July 2012 - 12:55 PM
Posted 21 July 2012 - 02:00 PM
Well, I mean that your Netduino is collecting data from some sensor, then a PC hosting a database has to get these data and store into it.
There are many ways to do it, and before all you should decide how to connect the Netduino with the PC.
Here is an example of moving data from the Netduino, but also to it. It uses a phone, but it's very easy to interface with a database. By the way, the phone itself could host a SQL database.
http://highfieldtale...-windows-phone/
Note that you should have a decent skill of programming for creating your project.
Posted 21 July 2012 - 03:10 PM
Posted 21 July 2012 - 11:23 PM
Hello Skarphedinn.
Thanks Mario. I'll look into this one Eventually this would be data from a sensor that is displayed on a webpage. The storage of the data is so it is possible to see data back in time. Can a phone really host a SQL data base? I thought there would be limitations there like there are in microcontrollers... Well, thanks again
Posted 21 July 2012 - 11:28 PM
Hello, thinking there is no SqlClient classes in MF (could be though I doubt it), I suggest you write a simple web service to run on the sql server machine (or one adjacent to that). Netduino would then make http request containing the data for the webservice to be stored in the sql database using conventional methods, i.e ADO.NET or what have, by the webservice.
There are examples of how to call a webservice from a Netduino plus here on the forum, just search for it.
Good luck!
Hi Hanzibal.
I have read there is no sqlClients available for MF. When you are talking about http request, are you referring to situation where the data is sent to the database via url (called injection, i think)? If so, it would work for me in this case, but I have another project in the future where users have to log in to their account to save data from the netduino. So for securiti reasons that would not be a good choice.
Skarphedinn.
Posted 22 July 2012 - 08:36 AM
What I suggested has nothing to do with so called "sql injection" which is a method of hacking into an sql database.When you are talking about http request, are you referring to situation where the data is sent to the database via url (called injection, i think)? If so, it would work for me in this case, but I have another project in the future where users have to log in to their account to save data from the netduino. So for securiti reasons that would not be a good choice.
Instead, I meant for you to implement one or more well defined web services that you can call from the Netduino. This will not prevent you from enforcing authentication on your Netduino web server.
Depending on what kind of searching, aggregations etc you want do on the historic data, you could settle for storing the readings on a simple SD card attached directly to the Netduino. You could then periodically harvest your data by attaching the SD card to the SQL machine and have it store it for safe keeping.
Posted 22 July 2012 - 05:52 PM
Get Toolbox from: http://netmftoolbox.codeplex.com
Add references to: Toolbox.NETMF.NET.dll and Toolbox.NETMF.NET.Integrated.dll
netduino code:
using Toolbox.NETMF.NET; Microsoft.SPOT.Net.NetworkInformation.NetworkInterface.GetAllNetworkInterfaces()[0].EnableDhcp(); // For DHCP HTTP_Client WebSession = new HTTP_Client(new IntegratedSocket("server", 80)); // creates a socket to the server. // Builds an url like: http://server/directory/netduino_upload.php?temp=1&pressure1=1&pressure2=1&light=1&pass=12345 string sendURL = "/directory/netduino_upload.php?temp=" + "1"; sendURL += "&pressure1=" + "1"; sendURL += "&pressure2=" + "1"; sendURL += "&light=" + "1"; sendURL += "&pass=" + "12345"; try { HTTP_Client.HTTP_Response Response = WebSession.Get(sendURL); // Requests the URL. if (Response.ResponseCode != 200) <insert code> // error else <insert code> // success Response = null; } catch (SocketException se) { Debug.Print("Socket Exception! Cant connect?"); Debug.Print(se.StackTrace); }
upload.php
<?php error_reporting (E_ALL ^ E_NOTICE); $temp = filter_var($_GET['temp'], FILTER_SANITIZE_NUMBER_FLOAT, FILTER_FLAG_ALLOW_FRACTION); $pressure1 = filter_var($_GET['pressure1'], FILTER_SANITIZE_NUMBER_FLOAT, FILTER_FLAG_ALLOW_FRACTION); $pressure2 = filter_var($_GET['pressure2'], FILTER_SANITIZE_NUMBER_FLOAT, FILTER_FLAG_ALLOW_FRACTION); $light = filter_var($_GET['light'], FILTER_SANITIZE_NUMBER_FLOAT, FILTER_FLAG_ALLOW_FRACTION); $pass = filter_var($_GET['pass'], FILTER_SANITIZE_NUMBER_FLOAT, FILTER_FLAG_ALLOW_FRACTION); if ($pass == 12345) { mysql_connect("host","login","password") or die ('I cannot connect to database because : '. mysql_error()); mysql_select_db("database"); $query="INSERT INTO Netduino(temp, pressure1, pressure2, light) values('$temp', '$pressure1', '$pressure2', '$light');"; mysql_query($query) or die("ERROR ".mysql_error()); echo "Database Updated "; } else { echo '<img src="accessdenied.jpg" />'; } ?>
Posted 22 July 2012 - 06:30 PM
Nice write-up!! I want to add one small detail, which makes it even a tiny bit better:
string sendURL = "/directory/netduino_upload.php?temp=" + 1; sendURL += "&pressure1=" + 1; sendURL += "&pressure2=" + 1; sendURL += "&light=" + 1; sendURL += "&pass=" + Tools.RawUrlEncode("XXX");
I added the RawUrlEncode method.
In PHP it's important to escape all values before it's added into the query, because characters like quotes have a function in a query.
But also, in the URL some characters could have a function, like & and ?
The RawUrlEncode method replaces this correctly, so all values can be used safely in a URL.
- icecold likes this
Posted 22 July 2012 - 06:47 PM
Hi icecold,
Thanks Stefan!
I used "XXX" as an example, it should be numbers to pass the filter.
I changed my post to make that clear.
Posted 22 July 2012 - 07:48 PM
Posted 22 July 2012 - 11:17 PM
I think I'll be able to get started now...
I know that Hanzibal I am not clear enough at times since English is not my first language. What I meant is exactly what Icecold saidWhat I suggested has nothing to do with so called "sql injection" which is a method of hacking into an sql database.
. But I guess there isn't that much of security issue since it is possible to use Tools.RawUrlEncode like Stefan pointed out.This works but as people already wrote its a bit dangerous for SQL-injections on my database
Again, thanks a bunch!
Skarphedinn.
Posted 23 July 2012 - 06:14 AM
That only fixes data transfer issues, no injection issuesBut I guess there isn't that much of security issue since it is possible to use Tools.RawUrlEncode like Stefan pointed out.
URL encoding is a clientside thing. Security issues should -always- be checked serverside.
Although I think you probably know that, I just wanted to point it out, to be sure
Posted 23 July 2012 - 08:01 AM
