Microsecond timing
Posted 21 July 2012 - 07:10 AM
Posted 21 July 2012 - 07:14 AM
Posted 21 July 2012 - 10:55 AM
Posted 21 July 2012 - 12:07 PM
Is there a way to get microsecond level timing from the netduino+?
Why you need "us" ? Netduino have troubles when you reduce so much the interruption time and events. Around 100ms the periodic count start to be very unstable and the oscillate between 80ms and 120ms. This problem occur because your code staying on the high level code and the code of bootloader and .NET Microframework stay under it. To make some type of aplication you need to use other processor or try to put you code compiled with the bootloader.
Other solution for this problem is use other processor to manage fast process.
Posted 21 July 2012 - 02:29 PM
Or to see if there's a native class for the kind of job you want to do, like CW2 pointed out.Other solution for this problem is use other processor to manage fast process.
If you want to drive a specific chip, you could bitbang, but also use native SPI, I2C, PWM or UART classes.
Posted 23 July 2012 - 07:59 AM
Posted 12 April 2013 - 06:42 AM
You may be able to squeeze less than 20% of error out if you cause the processor to use interrupts.
See this article
http://www.codeproje...recision-in-NET
Posted 26 April 2013 - 02:51 PM
Dear all
what i did in order to overcome this error is the following:
I made some tests in order to find how many ticks are for each microsecond. I calculated the ticks for 1 microsec to 1 sec in some discrete steps. I assumed that the greatest the time is the greatest the precision for the ticks counting so for various tests for 1 sec i found that there are about 10,1 ticks per 1 microsec (eg 1010347 ticks for 100ms (100000microsec) thus 1010347/100000=10,10347 ticks per microsec.
long startTick = Utility.GetMachineTime().Ticks; Thread.Sleep(1); long endTick = Utility.GetMachineTime().Ticks; long Delta = endTick - startTick; Debug.Print("1ms:" + Delta.ToString()); startTick = Utility.GetMachineTime().Ticks; Thread.Sleep(10); endTick = Utility.GetMachineTime().Ticks; Delta = endTick - startTick; Debug.Print("10ms:" + Delta.ToString()); startTick = Utility.GetMachineTime().Ticks; Thread.Sleep(100); endTick = Utility.GetMachineTime().Ticks; Delta = endTick - startTick; Debug.Print("100ms:" + Delta.ToString()); startTick = Utility.GetMachineTime().Ticks; Thread.Sleep(1000); endTick = Utility.GetMachineTime().Ticks; Delta = endTick - startTick; Debug.Print("1s:" + Delta.ToString());
Then i wrote a function that creates a delay in microseconds.
double ticksPerMicrosec=10; // this came after calculation (see above) public static void WaitMicroseconds(double microseconds) { long ticks = Utility.GetMachineTime().Ticks; while ((Utility.GetMachineTime().Ticks - ticks) < (microseconds * ticksPerMicrosec)) ; }
- YuvaRaja likes this
Posted 23 May 2013 - 01:47 PM
I found a link for Microsecond delay in the Netduino.
http://www.j2i.net/b...-Framework.aspx
But this is only for netduino and depends upon the Hardware also.
