MotorShield Netduino Go
Posted 13 July 2012 - 11:34 AM
Posted 13 July 2012 - 10:22 PM
View my blog at ChrisHammond.com
Projects: Netduino Tank/Tracked Vehicle, DNNFoos, Random other bits
Posted 13 July 2012 - 10:28 PM
I haven't yet attempted with the updated SB firmware, but I can definitely confirm the issues without it
The PWM features on the Shield Base should be working well now. If you experience any issues, please let us know and we can fix them in the next beta.
Posted 16 July 2012 - 11:37 AM
Hey Chris
after updating shield base firmware netgo is showing nested class issue, mean when i made my project with nested class visual basic is not going in debugging mode. After rebooting it stop(not hang), it return to same state that was before pressing F5
please see it
Posted 16 July 2012 - 11:47 PM
Can you explain what you're experiencing in detail? I'm really sorry, but I do not understand what are seeing...but would like to help!after updating shield base firmware netgo is showing nested class issue, mean when i made my project with nested class visual basic is not going in debugging mode. After rebooting it stop(not hang), it return to same state that was before pressing F5
please see it
BTW, welcome to the Netduino community.
Posted 17 July 2012 - 06:07 AM
Hi Tanmay,
Hi Chris
Thanks for your reply.
I am attaching my code this is not working, mean visual studio is not going in debugging mode when i press F5 it reach to same state that was before pressing F5(Editing mode).
It happen after i updated shield firmware,may be firmware did some changes in main board internal code.
overall nested class program is not supporting in hardware
Posted 17 July 2012 - 06:25 AM
Where do you see that error?
Also, try updating your mainboard with this patch. It may fix the problem you're having...
http://forums.netdui...dpost__p__32007
Posted 17 July 2012 - 09:16 AM
Hi Tanmay,
i am adding text file that contain output window data for my program, now it is affecting on other working programs. I am not getting what can be problem i reinstalled .netmicroframe work along with visual studio 2010 express edition.
can you tell me procedure for flashing three file last time i did flashing with "tinyclr.dfu" but this time you gave me three different file
Posted 17 July 2012 - 09:20 AM
That line means that there is no application on your board. This is probably due to the mentioned flash-erase issue.Cannot find any entrypoint!
Please reflash your Netduino Go with the following firmware and then redeploy your application.
http://forums.netdui...2007#entry32007
Posted 17 July 2012 - 09:50 AM
Thanks chris
please tell me the procedure for flashing these files that you mention in earlier post. i did earlier flashing by "tinyclr.dfu" file that only contain single file.
Posted 17 July 2012 - 11:22 AM
The Netduino Go! Main Board? http://wiki.netduino...etduino-Go.ashxThanks chris
Posted 17 July 2012 - 01:55 PM
this step is for single file that i downloaded as per your instruction but in above Chris comment he included 3 file "config,boot and flash" so do i have to maintain any sequence or to set any particular address for specific file.
Posted 17 July 2012 - 06:37 PM
You can just do file by file. it'll automaticly know it's address.this step is for single file that i downloaded as per your instruction but in above Chris comment he included 3 file "config,boot and flash" so do i have to maintain any sequence or to set any particular address for specific file.
