UART communication Netduino Plus
28 replies to this topic
#1 efrain7805
efrain7805
  • 3 posts
Posted 12 July 2012 - 03:35 AM
I'm new to netduino need to establish a communication with COM1 netduino and PC serial Port area using "Tera Term" but communication does not work I press the letter "a" on the keyboard and returns me another character. I'm working with a Baude Rate of 9600. Alguine I can say I'm doing wrong? Thank you. I leave the source code.
using System.Text;
using System.Net;
using System.Net.Sockets;
using System.IO.Ports;
        static SerialPort serial;
        static OutputPort Led = new OutputPort(Pins.ONBOARD_LED, false);
            // initialize the serial port for COM1 (using D0 & D1)
            serial = new SerialPort("COM1",9600, Parity.None, 8, StopBits.One);
            // open the serial-port, so we can send & receive data
            serial.Open();
            // add an event-handler for handling incoming data
            serial.DataReceived += new SerialDataReceivedEventHandler(serial_DataReceived);
            // wait forever...
        static void serial_DataReceived(object sender, SerialDataReceivedEventArgs e)
            int bytesToRead = serial.BytesToRead;
            //start reading the stream
            if (bytesToRead > 0)
                // get the waiting data
                byte[] buffer = new byte[bytesToRead];
               serial.Read(buffer, 0, buffer.Length);
               serial.Write(buffer, 0, buffer.Length);
                Led.Write(true);
            Led.Write(false);
Edited by Chris Walker, 12 July 2012 - 04:40 AM.
added [code][/code] tags
Posted 12 July 2012 - 04:43 AM
Hi efrain7805, Can you confirm that you're using all the same settings on the PC (8 data bits, no parity, one stop bit)? Also, what kind of cable are you using to attach your Netduino to the PC? RS232? USB-TTL? Are you doing any voltage level conversion? Welcome to the Netduino community, Chris
#3 efrain7805
efrain7805
  • 3 posts
Posted 12 July 2012 - 01:37 PM
thanks for responding. The configuaracion of PC is equal to the program but I'm not using using a voltage level converter. I directly connect the P0, P1 and ground directly to the Port netduino plus 232 of the PC to the Pines 2,3,5. if I use a voltage level converter which recommend? once again thank you very much.
#4 nakchak
nakchak
  • 404 posts
  • LocationBristol, UK
Posted 12 July 2012 - 02:52 PM
Can you post the character you recvive when you type "a" into the console?
Do you get a character like this? ž or ×?
If so then you need to logically invert the RX or TX lines as what you are receiving back to the console is the logical inverse of the byte you expected.
i.e.
//The letter 'a' in ascii byte values is 0x61
//In binary this is 0110 0001
//If the RX or TX lines are not inverting the response you will get a value of 0x9E (158 decimal)
//i.e. the non inverted value would be 1001 1110
Can you set a breakpoint on the line
What do you see in the buffer, i.e. if you press the 'a' key you should see a byte array with a single entry with the value of 0x61 (or 97 if you haven't enabled hex view). If you see that then it seems likely that the culprit is the TX line which needs inverting, otherwise its the RX line.
I suspect as you are not using a voltage converter you are not getting the inversion done for free, so either use a voltage converter like a MAX232, or invert the RX and TX lines using a device like a 74HCT14N although i would recomend a purpose built RS232 level converter if you are likely to experience 12V serial signals which you would typically get from a PC serial port (although not always if you are using a USB serial port, dc-dc converters are expensive and 5v is enough to trigger most modern (later than 1980's) logic devices...)
Nak.
#5 efrain7805
efrain7805
  • 3 posts
Posted 17 July 2012 - 02:06 AM
friends, I connected the converter voltage levels and it worked excellent. I use max 3232. thank you again.
#6 Kentj
Kentj
  • 16 posts
Posted 18 July 2012 - 02:23 AM
I have been trying different examples all day. This one works the best but it still doesn't accept "SerialPort" saying "The type or namespace name 'SerialPort' could not be found (are you missing a using directive or an assembly reference?) What do I need?
#7 Kentj
Kentj
  • 16 posts
Posted 18 July 2012 - 01:30 PM
Also, I'm using COM2 since I need RTS and CTS. I have seen nothing on how to use them though. Where should I be looking? (A good reference?)
#8 Kentj
Kentj
  • 16 posts
Posted 20 July 2012 - 04:13 PM
Okay, I had to make "SerialPort" plural to accept it but it still doesn't work below in the program. On line with " serial = new SerialPorts("COM2", 9600, Parity.None, 8, StopBits.One); I get "Cannot create an instance of static class 'SecretLabs.NETMF.Hardware.NetduinoPlus.SerialPorts'"
#9 Chris Walker
Posted 20 July 2012 - 09:17 PM
Hi Kentj,
If you take the plural "s" out of "= new SerialPorts", does that work? I believe that the class you're looking for is System.IO.SerialPort rather than 'SerialPorts'.
#10 Kentj
Kentj
  • 16 posts
Posted 21 July 2012 - 12:49 AM
With "SerialPort" I get the error "Type or namespace name 'SerialPort' could not be found (are you missing a using directive or an assembly reference?)"
#11 Chris Walker
Posted 21 July 2012 - 01:34 AM
Hi Kentj,
Two quick questions...
1. Do you have Microsoft.SPOT.Hardware.SerialPort.dll added as a reference to your project?
2. Do you have the text "using System.IO.Ports;" at the top of your source code file?
#12 Kentj
Kentj
  • 16 posts
Posted 21 July 2012 - 04:23 PM
I have "using System.IO.Ports;" but how do you add "Microsoft.SPOT.Hardware.SerialPort.dll" to the references. I have "Microsoft.SPOT.Hardware" under which heading is "{}Microsoft.SPOT\ {}Microsoft.SPOT.Hardware\ {}System.IO.Ports" in references.
#13 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 21 July 2012 - 07:37 PM
Click on "Project -> Add reference" in the menu bar at the top. Now select Microsoft.SPOT.Hardware.SerialPort.
#14 Kentj
Kentj
  • 16 posts
Posted 22 July 2012 - 03:55 AM
Microsoft.SPOT.Hardware.SerialPort was not found anywhere on my computer with or without the .dll
#15 Chris Walker
Posted 22 July 2012 - 05:15 AM
Hi Kentj,
In "Add References", go to the ".NET" tab. The component name should be "Microsoft.SPOT.Hardware.SerialPort".
They're not necessarily in alphabetical order.
If it's not there, then your current project may not be a .NET Micro Framework project or the SDK might not be installed properly on your computer.
#16 Kentj
Kentj
  • 16 posts
Posted 23 July 2012 - 02:38 PM
There is nothing under the ".NET" tab. I re-downloaded .NET Micro Framework making sure it was for the Netduino Plus and not the Netduino Go. Got out of Visual Studio and back in again. Re-loaded my program which is a .NET Micro Framework project. and there still is nothing under the .NET tab.
#17 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 23 July 2012 - 02:55 PM
Hi Kentj, Could you please go to "Project -> Project Properties" and make a screenshot? It should look like this: Attached File  project_properties.png   30.86KB   37 downloads Also, go to "Project -> Add Reference...". I have this list, you should add the selected reference: Attached File  add_reference.png   34.13KB   38 downloads It won't be there if it's the wrong project type though. The actual DLL is found here: C:\Program Files (x86)\Microsoft .NET Micro Framework\v4.1\Assemblies\le\
#18 Kentj
Kentj
  • 16 posts
Posted 23 July 2012 - 03:24 PM
Sorry, I don't remember how to do a screen shot since I haven't done it since the '80s (DOS). The "Project Properties" screen looks the same though. The other one does not.
#19 Stefan
Stefan
    Moderator
  • 1965 posts
Posted 23 July 2012 - 03:30 PM
To make a screenshot, press the PrtScn button on your keyboard. That will add an image of the full screen in your clipboard. If you press Alt+PrtScn it will just do the active window.
Then go to an image editor, for example Microsoft Paint, paste (Ctrl+V) and store it to the disk.
I'm curious how it looks at your place. You got both SDKs installed? The general .NETMF SDK (http://netmf.codeple...oads/get/343358) and the Netduino SDK (http://www.netduino.com/downloads/)
#20 Kentj
Kentj
  • 16 posts
Posted 23 July 2012 - 03:42 PM
We'll try this.
