PC Xbee and Netduino Xbee communication
5 replies to this topic
#1 Shehab
Shehab
  • 7 posts
Posted 22 June 2012 - 12:12 AM
Hi All,
I hope I could get help with this project I have been reading a lot trying to get it to work. I am trying to communicate Netduino Plus that has an Xbee on top of it with a shield and a potentiometer connected to the A0 Pin for input, I created this Netduino application and i can debug and see different readings when I change the potentiometer:
using System.IO.Ports;
using System.IO;
namespace XBeeTest
                SerialPort serialPort = new SerialPort("COM1", 9600, Parity.None, 8, StopBits.One);
                serialPort.ReadTimeout = 0;
                  serialPort.Open();
                  // 1. connect the middle pin of the potentiometer to A0
                  // 2. connect the other pin of the potentiometer to GND
                  // 3. connect the other pin of the potentiometer to 3.3v
                  AnalogInput inputPort = new AnalogInput(Pins.GPIO_PIN_A0);
                  try
                              // read the value
                              int potentiometerValue = inputPort.Read();
                              // some required convertion
                              float analogConversion = (float)potentiometerValue / 1023 * 3.3f;
                              // then we will prepare sending the message
                    byte[] buffer = new byte[analogConversion.ToString().Length];
                              // convert the string to bytes
                    buffer = System.Text.Encoding.UTF8.GetBytes(analogConversion.ToString());
                              // write it to Xbee through serial
                    serialPort.Write(buffer, 0, buffer.Length);
                              // wait 500 seconds
                              Thread.Sleep(500);
                  finally
                      serialPort.Close();
I am assuming after I run this one on the Netduino plus with xbee, I can unplug it from the PC and connect it to the battery and it would still do the same right?
OK, at the other Xbee that I connect to the PC, I created a console app to read the serial port and print out the potentiometer readings and here is the code:
using System.Collections.Generic;
using System.Linq;
using System.Text;
namespace WirelessAlarm
    // Console program for receiving the data
    class Program
        static void Main(string[] args)
            SerialPort sensor = new SerialPort("COM3", 9600, Parity.None, 8, StopBits.One);
            int bytesToRead = 0;
            bool isPlaying = false;
            string message;
            sensor.Open();
            try
                    // check if there are bytes incoming
                    bytesToRead = sensor.BytesToRead;
                    string strbytesToRead = sensor.ReadExisting();
                    if (bytesToRead > 0)
                        byte[] input = new byte[bytesToRead];
                        // read the Xbee's input
                        sensor.Read(input, 0, bytesToRead);
                        // convert the bytes into string
                        message = System.Text.Encoding.UTF8.GetString(input);
                        // message contains the string we received from the Serial port
                        // TODO: put the code here to do something with the message
            finally
                sensor.Close();
for some reason, I get nothing on the console app in the "bytesToRead", what am I doing wrong? I hope this makes sense.
Shehab
#2 awaiK
awaiK
  • 90 posts
Posted 22 June 2012 - 05:07 AM
Are you sure your XBee configuration is correct? You need at least one XBee Cooridnator and one XBee Router or one XBee End Device. If you are using the AT-Command firmware, you need to pair your two XBees.
#3 Shehab
Shehab
  • 7 posts
Posted 22 June 2012 - 11:14 AM
Hi awaiK, I think you are right, I figured I need to configure the 2 Xbees together, do you have any documentation or tutorial? Here is the Xbee kit I bought: http://www.sparkfun.com/products/9897. one is connected to the Netduino and the other is on the Xbee explorer that connects to the PC. Thank you very much for your help.
#4 Gutworks
Gutworks
  • 363 posts
  • LocationOttawa, Ontario
Posted 27 June 2012 - 05:36 AM
Hi Shehab, I just got my Xbee working using a WPF application to communicate from the PC using COM3. At first I too could not get the Xbee's to communicate and discovered the Win7 had my Xbee placed on a random COM port. Once I fixed this I tested the communication via Putty and X-CTU. As soon as I get some sleep and can think and talk coherently I will post some examples and bit of a Xbee primer. Cheers, Steve
#5 Shehab
Shehab
  • 7 posts
Posted 27 June 2012 - 11:13 AM
Thank you Steve, I got it to work too, the only issue is that sometimes it just stops working. Please post your example if you can. Thanks, Shehab
#6 sebswed
sebswed
  • 45 posts
  • LocationSweden
Posted 10 April 2013 - 05:39 AM
Hi there.
Any chance one one of you guys could post the working code? I'm a complete beginner.
I do have 2 Xbee modules successfully talking in AT mode. I have a little Arduino Fio as Router in AT mode sending data to a coordinator connected to my PC but would like to receive this data on my Netduino 2+ instead.
ps. I downloaded Grommet but have no idea on how to import this into Visual C# 2010 Express.
Thanks in advance!
Netduino Plus 2 (v4.2.2.2)
