I have started this thread as a place to gather any wisdom regarding the dreaded deployment problems plaguing the Netduino.
These problems are extremely frustrating, and so any ideas would be greatly appreciated.
So, if you have discovered a way of bringing your Netduino back to life, or even better, stopping the problem all together, then please share it here.
For the record I have tried typing "plugh" and "xyzzy" to no avail (one for the old timers) :-)
My particular problems are the BSOD and failing to deploy. so far the only guaranteed solution is to do the following;
1 Cancel the deployment.
2 Unplug the USB.
3 Power down the project (my Netduino is a mounted as a sub board to a larger PCB that also powers it)
4 run mfdeploy
5 plug in USB
6 erase current programming (this is a few steps in mfdeploy)
7 if still not working, shutdown VS2010 (sometimes this gives BSOD)
8 if still not working reboot PC.
Regards
Rohan
Hints, Tips and Workarounds for Deployment Problems
Started by rhamer, Jun 15 2012 12:14 AM
1 reply to this topic
Posted 15 June 2012 - 12:14 AM
Posted 15 June 2012 - 04:56 AM
Declare a global flag APP_RUN and initalise it to true. Write your loops and timer handlers to exit when APP_RUN goes false, and attach a handler to the built-in button so you can set APP_RUN to false by pressing the button. This will give you a physical stop button for your application. You will find that if you stop your application first, deployment will be fast and reliable.
