Socket Exception
8 replies to this topic
#1 Adam Clifford
Adam Clifford
  • 18 posts
Posted 06 June 2012 - 10:00 PM
Hi All,
I am trying to run a web service that I have built in connection with a project I am building. However I cannot for the life of me get my netduino to actually talk to my service.
Here is the code, does it look bad?
using (var request = (HttpWebRequest)WebRequest.Create(url))
                request.Method = "GET";
                request.Accept = "application/json";
                request.UserAgent = "OomooTweetNetduino";
                try
                    using (var response = (HttpWebResponse)request.GetResponse())
                        if (response.StatusCode == HttpStatusCode.OK)
                            Debug.Print(response.StatusCode.ToString());
                            var textStream = response.GetResponseStream();
                            byte[] buffer = new byte[textStream.Length];
                            var count = textStream.Read(buffer, 0, int.Parse(textStream.Length.ToString()));
                            char[] chars = Encoding.UTF8.GetChars(buffer);
                            //var s = new string(chars).TrimEnd('
                            Debug.Print(new string(chars));
                    return true;
                catch (Exception e)
                    WriteAllErrors(e);
                    return false;
#2 Mario Vernari
Posted 07 June 2012 - 05:17 AM
Hello Adam. Not clear where is the problem, though. The above service is supposed to be hosted in a normal server (e.g. PC), while the client is the Netduino, right? If so, who is raising the exception? Again, could you check the TCP data flow with Wireshark or any similar tool? Cheers
#3 Adam Clifford
Adam Clifford
  • 18 posts
Posted 07 June 2012 - 10:14 AM
Hi Mario,
The service is currently on the web, it is a simple REST service that returns JSON based on the requests.
My Netduino is trying to consume it.
the point at which I get the error is
it errors out and doesn't hit the next lines.
the inner exception is of type SocketExeption.
Adam
#4 nakchak
nakchak
  • 404 posts
  • LocationBristol, UK
Posted 07 June 2012 - 11:09 AM
Hi Adam
What is the URL you are using?
Excuse the bleeding obvious but...
If the url in your netduino code is localhost (which resolves to 127.0.0.1 aka local loopback address) then you are attempting to connect the netduino to itself, if thats the case try using the machine name or IP address of your computer running the REST service.
Another option is to use the lighter weight (in terms of RAM usage) http client in the netmf toolbox which i personally use to connect to various RESTful webservices as i have run into issues with ram utilisation and garbage collection using the standard netmf webrequest object.
Also what is the inner exception message?
Nak.
#5 Adam Clifford
Adam Clifford
  • 18 posts
Posted 07 June 2012 - 01:43 PM
Hi Nak, I have tried the http_Client and I got the same response, I cant remember the full request URL off of the top of my head as i am in work, but i will respond when I get home in a couple of hours. Adam
#6 Adam Clifford
Adam Clifford
  • 18 posts
Posted 07 June 2012 - 04:52 PM
Here is the url I am trying to get to
var url = "http://www.adam-clifford.co.uk/api/values/GetTweetHeaders/efc5adb9f17040e1bcbade6e210a467b";
#7 nakchak
nakchak
  • 404 posts
Posted 07 June 2012 - 07:52 PM
I assume the gateway and dns server settings are correct on your nd+?
#8 nakchak
nakchak
  • 404 posts
Posted 07 June 2012 - 07:58 PM
I forgot to add that i would do initial testing on your lan, by installing iis 7/iis express and running the service locally, that way you can control the environment better and if needs be wireshark the network to see what is going on. Also what if any are the inner exception(s) messages?
#9 Adam Clifford
Adam Clifford
  • 18 posts
Posted 08 June 2012 - 07:04 PM
these are the exceptions
-		e	{System.Net.WebException}	System.Exception {System.Net.WebException}
+		InnerException	{System.Net.Sockets.SocketException}	System.Exception {System.Net.Sockets.SocketException}
		m_HResult	4278190080	int {uint}
