POE?
Posted 28 September 2010 - 10:00 AM
Posted 28 September 2010 - 12:06 PM
It will be nice to power the board through Power Over Ethernet.
It's an important feature that I really need on my domotic project, is it plane ?
I've never tried it... but you could start here:
http://www.freetroni...net-for-arduino
They also have a shield for PoE too.
Posted 28 September 2010 - 12:47 PM
Try this out:
http://www.trendnet....TPE-102S&cat=58
Posted 28 September 2010 - 11:40 PM
Try this out:
POE is way different in voltage specifications then required by the netduino, it is designed to deliver 15watts or more at 44 to 57 volts. So way past the 12v max for netduino.
Not to say someone could come with a inline tap that could bring it down to something reasonable.
Posted 29 September 2010 - 12:11 AM
Well, it used to be outrageously expensive. It appears you can get an 8 port PoE gigabit switch for $139 now or so.
Edited by Steven Behnke, 29 September 2010 - 12:15 AM.
Posted 30 September 2010 - 10:46 AM
Did you look at that link? The trendnet device that I linked to features:
Supports Adjustable Output 5V, 7.5V, 9V, 12V
Posted 30 September 2010 - 11:38 AM
It's all kind of moot unless the netduino has both the code (firmware) and the hardware to support taking in the power.
(Although I think it would be a cool feature to have!)
Posted 30 September 2010 - 12:14 PM
Actually, it is possible to supply power via VIN pin, voltage slightly above 6V should be enough to get stable 5V line. Power from USB connector is automatically disconnected when VIN voltage is detected (either from power jack or VIN pin, which are physically connected).the hardware to support taking in the power.
Posted 30 September 2010 - 12:28 PM
No firmware or hardware needed...
I think everyone is misunderstanding my link. The device I posted extracts power from an powered ethernet line and then converts it to one of the voltages for powering devices that don't support POE.
The netduino has a 7.5 - 12 VDC power input in the lower left the unit. The trendnet device has a power output. Run a cable from the trendnet power output to the power input on the netduino.
- Splits power and data from a single Ethernet cable into two separate sources
- Use this with a TRENDnet PoE switch to power and network a non Power over Ethernet device
- Save on installation and equipment costs
Posted 30 September 2010 - 12:55 PM
Oh - I thought it was an injector - I see what you're saying. Now THAT is a pretty neat piece of tech. An ethernet power supply. I might have to pick up one of those.
Sorry - as a network engineer I'm used to the host device pulling power off the pins and not adding a separate board.
Posted 05 October 2010 - 10:46 PM
