simple timer
1 reply to this topic
#1 mr_sargent
mr_sargent
  • 4 posts
Posted 13 May 2012 - 07:15 PM
Hello All,
I'm a little new to c# and hoping someone can help me with a timer problem I have. I would like an input to start a timer. I also need to know if the timer is currently running. While the timer is running I would like to count how many times an input has activated. Once the timer is complete I need to see if the inputs have activated the correct number of times.
Below is an example of my code that I know is incorrect. Could someone comment on how I could find various states of the timer and how I would get one started with an input?
Thanks.
using System.Net;
using System.Net.Sockets;
using System.Threading.Timer;
using Microsoft;
using System.Text;
using System.Resources;
namespace Glue_detection_application
            //initialize timer
            Timer timer1 = new Timer(TimerWindow,null,0,5000);
            //count values for senors
            int Sens2Count = 0;
            int Sens3Count = 0;
            //declare I/O
            OutputPort led = new OutputPort(Pins.GPIO_PIN_D0, false);
            InputPort Sens1 = new InputPort(Pins.GPIO_PIN_D1,false,Port.ResistorMode.Disabled);  //trigger timer
            //declare interupts
            InterruptPort Sens2 = new InterruptPort(Pins.GPIO_PIN_D2, false, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeHigh);
            InterruptPort Sens3 = new InterruptPort(Pins.GPIO_PIN_D3, false, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeHigh);
            //define interrupt methods
            Sens2.OnInterrupt += new NativeEventHandler(Sens2_OnInterrupt);
            Sens3.OnInterrupt += new NativeEventHandler(Sens3_OnInterrupt);
                bool SensorActivate = Sens1.Read();
                if (SensorActivate)
                    timer1.start();
                if(/* timer is done */)
                    if ((Sens2Count!= 2) || (Sens3Count!=3)
                        led.Write(true);
                        Sens3Count = 0;
                        Sens2Count = 0:
                    else
                        led.Write(false);
                        Sens2Count=0;
                        Sens3Count=0;
        static void Sens3_OnInterrupt(uint data1, uint data2, DateTime time)
         //if in timer window
            Sens2Count++;
        static void Sens2_OnInterrupt(uint data1, uint data2, DateTime time)
            Sens3Count++;
#2 Teets
Teets
  • 16 posts
Posted 26 June 2012 - 11:51 PM
Hello All,
Thanks.
using System.Net;
using Microsoft;
using System.Text;
            //initialize timer
            int Sens2Count = 0;
            int Sens3Count = 0;
            //declare I/O
            //declare interupts
                if (SensorActivate)
                    timer1.start();
                        led.Write(true);
                        Sens3Count = 0;
                        Sens2Count = 0:
                    else
                        led.Write(false);
                        Sens2Count=0;
                        Sens3Count=0;
            Sens2Count++;
            Sens3Count++;
The big thing about C# is the event handlers. Instead of looping through code and constantly checking the state of a port, you can add an event handler and have the port tell you when its state has changed. I rewrote your code to take advantage of event handlers. You'll also notice I moved the variables outside the Main() function and made them static so they can be seen by the events.
I haven't debugged the code, but it should be what you're looking for....
namespace TimerSample
        // Input that triggers the timer
        static InputPort Sens1 = new InputPort(Pins.GPIO_PIN_D1, false, Port.ResistorMode.Disabled);
        // Output to do stuff with
        static OutputPort led = new OutputPort(Pins.GPIO_PIN_D0, false);
        // Interrupts that we need to track
        static InterruptPort Sens2 = new InterruptPort(Pins.GPIO_PIN_D2, false, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeHigh);
        static InterruptPort Sens3 = new InterruptPort(Pins.GPIO_PIN_D3, false, Port.ResistorMode.Disabled, Port.InterruptMode.InterruptEdgeHigh);
        // The timer
        static Timer timer = null;
        // Input counts
        static int Sens2Count = 0, Sens3Count = 0;
            // Watch for when the input is triggered
            Sens1.OnInterrupt += new NativeEventHandler(Sens1_OnInterrupt);
            // Watch for when the interrupts are triggered
                // Do stuff
        static void Sens1_OnInterrupt(uint data1, uint data2, DateTime time)
            // If the timer isn't started...
            if (timer == null)
                // ... then start the timer
                timer = new Timer(timerDelegate, null, 0, 5000);
            else
                // Stop the timer
                timer = null;
            // Up the count
            Sens2Count++;
            // Up the count
            Sens3Count++;
        static TimerCallback timerDelegate = new TimerCallback(TimesUp);
        private static void TimesUp(object state)
            // Check the sensor counts
            if (Sens2Count != 2 || Sens3Count != 3)
                led.Write(true);
                Sens3Count = 0;
                Sens2Count = 0;
            else
                led.Write(false);
                Sens2Count = 0;
                Sens3Count = 0;
Let me know if you have any questions...
NICK
